Author Topic: Xlines revisited  (Read 2298 times)
krampaul82
Xlines revisited
« on: April 06, 2012, 08:49:04 AM »
The following xline code does not change to the layer sketch before the command is executed were as it does on the other xline lisps with input from Lee-Mac Programming
(see post xlines dated march 27) Any help appreciated
;  THIS FUNCTION WILL WILL PLACE A USER SPECIFIED ANGLED XLINE ON THE SKETCH LAYER (NO-PLOT) AT THE USERS PICK POINT.
;  IF IT DOES NO EXIST IT WILL MAKE THE LAYER AND CHANGE TO IT BEFORE IT EXECUTES THE COMMAND
;  IT WILL THEN CHANGE BACK TO THE LAYER YOU WERE PREVIOUSLY ON AND THE END THE COMMAND. (THANKS TO LEE-MAC PROGRAMMING FOR ERROR HANDLING AND LAYER MANIPULATION)
(defun c:clang (/ *error* sysvar values )
;; Error Handler to reset System Variables if things go wrong
    (defun *error* ( msg )
        (mapcar 'setvar sysvar values)
        (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
;; Store current System Variables
    (setq sysvar '(CMDECHO CLAYER OSMODE)
          values  (mapcar 'getvar sysvar)
;; Set System Variables
    (setvar 'CMDECHO 0)
    (setvar 'OSMODE  0)
;; If "Sketch" layer exists...
    (if (tblsearch "LAYER" "Sketch")
        ;; Unlock it, Thaw it, Turn it On, and set it current
        (command "_.-layer" "_U" "Sketch" "_T" "Sketch" "_ON" "Sketch" "_S" "Sketch" "")
        ;; Otherwise create it (also sets it current)
        (command "_.-layer" "_M" "Sketch" "_C" "_Cyan" "Sketch" "")
;; Tell user what's about to happen...
   (prompt "Once you enter a value This puts a An angled xline at your pick point...") (terpri)
;; Create the Angled XLine:
   (command "xline" "a" "PAUSE" )[color=red] ;I am thinking this line might be causing the problem? [/color]
   ;; Reset System Variables
Krushert
  • FREE BEER Tomorrow!!
Re: Xlines revisited
« Reply #1 on: April 06, 2012, 09:33:06 AM »
Very interesting.  I see what you mean.  I removed the the table search function an inserted one of my brute force code for creating code and it still did not work.  I have to enter a meeting, so I can not take it any further until later this afternoon.  Hopelfully someone will come along see the the quirky item that is causing the hiccup.
Cheers.
« Reply #2 on: April 06, 2012, 09:51:01 AM »
Change:
to:
(command "_.xline" "_a")
(while (= 1 (logand 1 (getvar 'CMDACTIVE)))
    (command pause)
'pause' is a symbol (not a string), with a value of "\" (meaning pause for user input).
« Reply #3 on: April 06, 2012, 09:55:42 AM »
Looking at the code more thoroughly, you might want to change it to this:
    (setq sysvar '(CMDECHO CLAYER)
    (setvar 'CMDECHO 0)
    (prompt "\nOnce you enter a value this puts a an angled XLine at your pick point...")
    (setvar 'CMDECHO 1)
        (command pause)
Since the XLines are now being placed by the user, there is no need to change the OSMODE setting.
krampaul82
« Reply #4 on: April 06, 2012, 10:08:41 AM »
 :kewl:
Thank You for the replies
I used your corrected code (Lee-Mac Programming) and it works as intended.
Again, Thank You!
« Reply #5 on: April 06, 2012, 10:31:58 AM »
You're welcome, I hope you can learn from the code  :-)
Krushert
« Reply #6 on: April 06, 2012, 01:27:58 PM »
I know I did.  Thanks.  and now to make my code look a little lest brutish.  :lol:
« Reply #7 on: April 07, 2012, 07:11:15 AM »
Good stuff  8-)
