Author Topic: Remove duplicate Strings in List  (Read 12543 times)
« on: February 22, 2005, 12:07:39 AM »
Anyone have any alternatives to these ??
(setq full_list  (list "c" "a" "b"  "a" "d" "b" "c" "e"))
( RemoveDuplicateStrings full_list) ;;->> ("c" "a" "b" "d" "e")
( SortAndRemoveDuplicateStrings full_list) ;;->> ("a" "b" "c" "d" "e")
;;option
(vl-sort ( RemoveDuplicateStrings full_list) '<)  ;;->> ("a" "b" "c" "d" "e")
(defun SortAndRemoveDuplicateStrings (stringlist / newlist lastin)
  ;;kwb 20050221
  (foreach var (vl-sort stringlist '<)
    (if (/= var lastin)
      (setq newlist (cons (setq lastin var) newlist))
  (reverse newlist)
(defun RemoveDuplicateStrings (stringlist / newlist)
  ;;kwb 20050221
  (foreach var stringlist
    (if (not (vl-position var newlist))
      (setq newlist (cons var newlist))
  (reverse newlist)
I'm brain dead, and would appreciate any insight ..
.. probably time for MP's benchmarker too.
« Reply #1 on: February 22, 2005, 08:41:07 AM »
Here is an alternate 'Remove Duplicates'
Did not record the author
;---Remove Duplicate members from a list.
;   Given list = '(1 1 2 3 4 "a" "b" "a")
;   Returns '(1 2 3 4 "a" "b")
(defun Remove_Dup (LST / CL)
  (mapcar
    '(lambda (X)
        ( (member X LST)
            ( (not (member X CL))     ;if element not already in CL
              (setq CL (cons X CL))
          ) ; end cond.
      ) ; end cond.
    ) ;end lambda
    LST
  ) ; end mapcar
  (reverse CL)
) ;end defun
« Reply #2 on: February 22, 2005, 09:08:16 AM »
Perhaps it could be simplied to this:
(defun remove_dup (lst / cl)
  (mapcar
    '(lambda (x)
       (if (not (member x cl)) ;if element not already in CL
         (setq cl (cons x cl))
    lst
  (reverse cl)
) ;end defun
Which is what you have :shock:
« Reply #3 on: February 22, 2005, 10:03:12 AM »
Not quite what I have.
CAB, This will rock you a little perhaps   < or not >  ...
The REMOVE_DUP2  is the same as yours, with the MEMBER changed to VL-POSITION.
.. so the difference will be in the MAPCAR and LAMBDA where I used FOREACH
The test list was a list of duplicate DWG name strings [  2 instances of 25  for a total of 50 ]
Benchmarking ................Elapsed milliseconds / relative speed for 8192 iteration(s):
    (REMOVE_DUP FULL_LIST).................5938 / 3.1203 <slowest>
    (REMOVE_DUP2 FULL_LIST)................4236 / 2.2260
    (REMOVEDUPLICATESTRINGS FULL_LIST).....1903 / 1.0000 <fastest>
« Reply #4 on: February 22, 2005, 10:09:23 AM »
So what your saying is that Mapcar is slower.
« Reply #5 on: February 22, 2005, 10:13:09 AM »
uhmmmmm ..
I'm just looking at the numbers Se7en.
« Reply #6 on: February 22, 2005, 10:16:24 AM »
Oh, and Michael .. I flipped the report list around on my benchmark version so that the fastest was the lowest ratio .. and the slowest shows the larger number < elapsed time >.
« Reply #7 on: February 22, 2005, 10:17:02 AM »
No it doesn't rock me. I was just providing an alternative which I found somewhere else.
When I removed some of the code it looked similar to yours but using the mapcar / lambda
as you pointed out. I didn't think it would out preform yours because you obviously were
proud enough to put you name in the code. I just offered it up as food for thought as you
said "I'm brain dead, and would appreciate any insight .."
Sorry it wasn't what you were looking for.
« Reply #8 on: February 22, 2005, 10:17:55 AM »
Well your right in this instance.
Mapcar is recursive by nature, foreach isnt. Therefore every time you are using a mapcar+lambda you are waiting for the intrip. to add a function definition to the stack.
« Reply #9 on: February 22, 2005, 10:22:20 AM »
Hi CAB.
Wasn't dissing you  :D
 ... or the routine
and I was seriously looking for feedback, not a pat on the back.
The problem is sometimes I get my head burried in code and miss the 'obvious' alternatives, hence the post.
« Reply #10 on: February 22, 2005, 10:30:15 AM »
Kerry, run this with the same paramaters as before and cross your fingers. I want to see if we can speed up this process a bit.
   (defun workhorse (x)
       (setq cl (cons x cl))))
  (mapcar 'workhorse lst)
  (reverse cl)
« Reply #11 on: February 22, 2005, 10:47:02 AM »
Wrapping it like that doesn't help, sorry.
    (REMOVE_DUP FULL_LIST).................5978 / 3.0609 <slowest>
    (REMOVE_DUP2 FULL_LIST)................4347 / 2.2258
    (REMOVE_DUP_Se7en FULL_LIST)...........3765 / 1.9278
    (REMOVEDUPLICATESTRINGS FULL_LIST).....1953 / 1.0000 <fastest>
« Reply #12 on: February 22, 2005, 10:48:39 AM »
Compare the performance of this --
(defun RemoveDuplicates ( lst / temp )
    (vl-remove-if
       '(lambda (x)
                ((vl-position x temp) t)
                ((setq temp (cons x temp)) nil)
        lst
Against preceeding variants using this list --
(setq lst '(1 2 3 4 5 6 7 8))
(repeat 10
    (setq lst
        (append lst lst)
Also (Kerry) please tell me about the speedometer in your vehicle.
:cheesy:
« Reply #13 on: February 22, 2005, 10:55:15 AM »
Even more amusing is the performance of this --
(defun RemoveDuplicates ( lst / foo temp )
    (defun foo (x)
    (vl-remove-if
       'foo
        lst
« Reply #14 on: February 22, 2005, 10:59:46 AM »
But it looks like it did. If I'm reading your benchmark correct. I imporved the preformance of the procedure by over 60% by just changing one thing. (using a NAMED procedure instead of an UNNAMED.) Am i right?
