Hi, I would like some help please
I need to be able to change all those 3 dynamic block with their visibility states.
If you select all 3 in the drawing you can change the value of then in properties/ custom/visibility1
in this code here :
(setq fleche '
("LC CHARGE 290" "LC B-T 290" "LC C-P 290")) (initget 1 "74m 70m 64m 60m 54m 50m 44m 40m") (setq b
-radius
(getkword "\n Donner le rayon de la flèche : "))
;(initget 1 "170 210 290 550")
;(setq tower-serie(getkword "\nDonner le modele de la grue : "))
(setq dbp
(vla
-getdynamicblockproperties fleche
)) (vla-put-value bp B-Radius)
All Help will be greatly appreciated thank !
Cheers & Beers
