Author Topic: Is anyone using ILSpy?  (Read 13943 times)
TheMaster
« on: March 28, 2012, 03:23:43 PM »
The beta of version 2.0 has been online for a few months and
after playing with it, I'm ready to say 'adios Reflector'.
There's even a version that runs on Metro.
Best of all, its open sourced and you can hack on it to your heart's content.
http://build.sharpdevelop.net/BuildArtefacts/#ILSpyMaster
« Last Edit: March 28, 2012, 03:27:23 PM by TheMaster »
Re: Is anyone using ILSpy?
« Reply #1 on: March 28, 2012, 03:42:36 PM »
Thanks for the heads up Tony - an alternative is handy.
I've had a look at dotPeek from JetBrains ... good, but not up to Reflector yet.
TheMaster
« Reply #2 on: March 28, 2012, 08:50:05 PM »
Speaking of Reflector, here's some interesting observations:
 http://community.sharpdevelop.net/blogs/dsrbecky/archive/2011/02/19/ilspy-ensuring-correctness.aspx
« Last Edit: March 28, 2012, 08:57:42 PM by TheMaster »
exmachina
« Reply #3 on: March 28, 2012, 08:59:02 PM »
Red Gate Reflector some times do not show code ofuscated with Red gate Smartassembly. Why?  :lmao:
 The best free "decompiler" is Telerick JustDecompile
Jeff H
« Reply #4 on: March 28, 2012, 10:02:06 PM »
Especially when looking at acdbmgd.dll & acmgd.dll
JustDecompile is hands down the best at decompiling the code to this
Thanks for that link!!
Wish I would of known about this before I paid for Reflector.
exmachina
« Reply #5 on: March 28, 2012, 10:53:57 PM »
Sorry. I do not understand, perhaps because I do not speak English : Il & C#
exmachina
« Reply #6 on: March 28, 2012, 11:07:35 PM »
 :oops: :oops: :oops: Ok. You're right
TheMaster
« Reply #7 on: March 29, 2012, 04:16:45 AM »
Refector is only accurate with IL produced by the Microsoft C# compiler.
IL produced via any other means (e.g., another language) may not
be accurately decompiled.
Hate to disagree :grin:
Can you debug managed code with JustDecompile ?
ILSpy 2.0 (beta) is a debugger as well as a decompiler.
You can set breakpoints, launch an executable or attach
to a running process, and step through any code in any
assembly that's loaded, regardless of whether it is your
code, the .NET framework, or AutoCAD's managed runtime.
When a breakpoint is hit, you can examine the call stack,
see the values of  arguments, etc. (no locals/watch window
yet, but that's planned).
Also, it looks like Telerik still has some work to do.
JustDecompile showing the source for System.Linq.Enumerable.ZipIterator:
Code - C#: [Select]
  1.
  2. Current member / type: System.Collections.Generic.IEnumerable`1<TResult> System.Linq.Enumerable::ZipIterator(System.Collections.Generic.IEnumerable`1<TFirst>,System.Collections.Generic.IEnumerable`1<TSecond>,System.Func`3<TFirst,TSecond,TResult>)
  3. File path: C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\System.Core.dll
  4. Product version: 2012.1.214.2
  5. Multiple invocations of finally method
  6.    at ˆ..ˆ(€ handlerInfo, Queue`1 bfsQueue, ILogicalConstruct currentNode)
  7.    at ˆ..‡(€ handlerInfo)
  8.    at ˆ..ƒ(BlockLogicalConstruct theBlock)
  9.    at ˆ.Ž–.‰()
  10.    at ˆ.Ž–.Process(DecompilationContext context, BlockStatement body)
  11.    at Telerik.JustDecompiler.Decompiler.DecompilationPipeline.Run(MethodBody body, ILanguage language)
  12.    at Telerik.JustDecompiler.Decompiler.Extensions.DecompileYieldStateMachine(MethodBody body, ILanguage language, YieldFieldsInformation& fieldsInformation)
  13.    at .‹.()
  14.    at .‹.Match(StatementCollection statements)
  15.    at .‹.Process(DecompilationContext context, BlockStatement body)
  16.    at Telerik.JustDecompiler.Decompiler.DecompilationPipeline.Run(MethodBody body, ILanguage language)
  17.    at Telerik.JustDecompiler.Decompiler.Extensions.(DecompilationPipeline pipeline, ILanguage language, MethodBody body, DecompilationContext& context)
  18.    at Telerik.JustDecompiler.Decompiler.Extensions.Decompile(MethodBody body, ILanguage language, DecompilationContext& context)
  19.    at Telerik.JustDecompiler.Languages.BaseImperativeLanguageWriter.Write(MethodDefinition method)
  20.    at Telerik.JustDecompiler.Languages.BaseLanguageWriter.Write(IMemberDefinition member, Boolean showCompilerGeneratedMembers)
  21.    at JustDecompile.CodeViewer.CodeWriter.Write() in c:\Builds\126\Behemoth\JustDecompile Production Build\Sources\UI\JustDecompile.CodeViewer\Writers\CodeWriter.cs:line 32
  22.    at JustDecompile.CodeViewer.ViewModels.CodeViewerViewModel.(AssemblyMemberNode member, CancellationToken cancellationToken) in c:\Builds\126\Behemoth\JustDecompile Production Build\Sources\UI\JustDecompile.CodeViewer\ViewModels\CodeViewerViewModel.cs:line 170
  23.
  24. mailto: JustDecompilePublicFeedback@telerik.com
  25.
  26.
ILSpy showing the same method:
Code - C#: [Select]
  1.
  2. // System.Linq.Enumerable
  3. private static IEnumerable<TResult> ZipIterator<TFirst, TSecond, TResult>(IEnumerable<TFirst> first, IEnumerable<TSecond> second, Func<TFirst, TSecond, TResult> resultSelector)
  4. {
  5.         using (IEnumerator<TFirst> enumerator = first.GetEnumerator())
  6.         {
  7.                 using (IEnumerator<TSecond> enumerator2 = second.GetEnumerator())
  8.                 {
  9.                         while (enumerator.MoveNext() && enumerator2.MoveNext())
  10.                         {
  11.                                 yield return resultSelector(enumerator.Current, enumerator2.Current);
  12.                         }
  13.                 }
  14.         }
  15.         yield break;
  16. }
  17.
  18.
« Last Edit: March 29, 2012, 05:03:03 AM by TheMaster »
TheMaster
« Reply #8 on: March 29, 2012, 04:21:22 AM »
Were you using the assemblies from the SDK or the production
assemblies in the AutoCAD folder?
exmachina
« Reply #9 on: March 29, 2012, 05:26:48 AM »
@ TheMaster
"Red Gate Reflector some times do not show code ofuscated with Red gate Smartassembly. Why?":
Easy :SmartassemblyAttribute
ILSpy
http://wiki.sharpdevelop.net/ILSpy.ashx
Debug? where you see that?.
Why anyone needs debug 3rth party assemblies?: only for hacking or cracking.  And read carefully at ILSpy - Further Down the Road:
Assembly editing capabilities (similar to Reflexil <- This is an Hackers Tool
kaefer
exmachina
« Reply #11 on: March 29, 2012, 07:09:00 AM »
@ kaefer
Thanks, i proves it.
Jeff H
« Reply #12 on: March 29, 2012, 09:34:08 AM »
The ones located in same location as acad.exe not the sdk's or ones that are just the signatures.
Draftek
« Reply #13 on: March 29, 2012, 09:44:50 AM »
Thanks Tony.
TheMaster
« Reply #14 on: March 29, 2012, 02:09:44 PM »
Why does anyone need to debug 3rd party assemblies?
Why does Visual Studio allow you to debug .NET framework code?
