Author Topic: Civil 3D Styles | Get Count Failed  (Read 3057 times)
BlackBox
« on: March 27, 2012, 08:53:51 AM »
Recently, I asked for some help with Civil 3D Styles, and thanks to Jeff - I now have a DLL which does what I am after... for Civil 3D 2012... my Civil 3D 2011 deployment however does not like using the DLL for some reason.
Here's a link to download the file I am using: C3D Style Tools.zip
Whereas for others the DLL works fine in 2011, so I'm trying to deduce what is causing this issue on my end, and am getting nowhere. Any assistance would be greatly appreciated.
Netload is fine, CommandMethod invocation is fine, and I am prompted for the appropriate string, then it fails, citing 'Get Count Failed'... Here is the error I receive:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
Autodesk.Civil.CivilException: Get Count Failed
   at Autodesk.Civil.DatabaseServices.Styles.StyleCollectionBase.get_Count()
   at Autodesk.Civil.CollectionEnumerator<Autodesk::Civil::DatabaseServices::Styles::StyleCollectionBase\,Autodesk::AutoCAD::DatabaseServices::ObjectId>..ctor(StyleCollectionBase pCollection)
   at Autodesk.Civil.DatabaseServices.Styles.StyleCollectionBase.GetEnumerator()
   at StyleTools.StylesCreatedByUpdate.ListCollection(Type objectType, PropertyInfo pf, Object myStylesRoot)
   at StyleTools.StylesCreatedByUpdate.ListRoot(Object root)
   at StyleTools.StylesCreatedByUpdate.createdbycommand()
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5448 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
acdbmgd
    Assembly Version: 18.1.0.0
    Win32 Version: 18.1.115.0.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AcdbMgd.DLL
System
    Win32 Version: 2.0.50727.5453 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
msvcm90
    Assembly Version: 9.0.30729.4940
    Win32 Version: 9.00.30729.4940
    CodeBase: file:///C:/WINDOWS/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c/msvcm90.dll
System.Xml
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.5011 built by: Win7SP1
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/WINDOWS/assembly/GAC_64/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.0.269.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AdApplicationFrame.DLL
AdWindows
    Assembly Version: 3.0.270.0
    Win32 Version: 3.0.270.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AdWindows.DLL
PresentationFramework.Aero
    Win32 Version: 3.0.6920.4902 built by: NetFXw7
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
acmgd
    Win32 Version: 18.1.208.0.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/acmgd.DLL
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.5420 built by: Win7SP1
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AcWindows.DLL
AcWindows.resources
    Win32 Version: 18.1.49.0.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/en-US/AcWindows.resources.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AcCui.DLL
AecMgdReverse
    Assembly Version: 6.5.353.0
    Win32 Version: 6, 5, 353, 0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AecMgdReverse.DLL
AecRibbon
    Win32 Version: 6.5.353.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AecRibbon.DLL
AcMapResourceManagement
    Assembly Version: 14.0.206.0
    Win32 Version: 14.0.206.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AcMapResourceManagement.DLL
AcMapSurveyMan
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AcMapSurveyMan.DLL
Autodesk.Gis.Map.SurveyUI
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/Autodesk.Gis.Map.SurveyUI.DLL
System.Windows.Forms
    Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/Autodesk.Gis.Map.Survey.DLL
Autodesk.Map.Platform.Core
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/Autodesk.Map.Platform.Core.DLL
OSGeo.MapGuide.PlatformBase
    Assembly Version: 2.2.0.4206
    Win32 Version: 1.0.0.4206
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/OSGeo.MapGuide.PlatformBase.DLL
OSGeo.MapGuide.Foundation
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/OSGeo.MapGuide.Foundation.DLL
OSGeo.MapGuide.Geometry
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/OSGeo.MapGuide.Geometry.DLL
Autodesk.Gis.Map.Survey.Resource
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/Autodesk.Gis.Map.Survey.Resource.DLL
AcMapRibbonWrapper
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AcMapRibbonWrapper.DLL
Autodesk.Gis.Map.Shared
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/Autodesk.Gis.Map.Shared.DLL
AmbercoreEngine
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AmbercoreEngine.DLL
AmberCore.IsdCodecAPI.Core
    Assembly Version: 5.0.0.343
    Win32 Version: 5.0.0.343
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AmberCore.IsdCodecAPI.Core.DLL
AeccMgdReverse
    Win32 Version: 8,0,2222,0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AeccMgdReverse.DLL
AeccUiWindows
    Assembly Version: 8.0.2222.0
    Win32 Version: 8.0.2222.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AeccUiWindows.DLL
AeccUiWindows.resources
    Assembly Version: 8.0.1439.0
    Win32 Version: 8.0.1439.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/en-US/AeccUiWindows.resources.DLL
AeciRibbon54Res
    Assembly Version: 18.1.15.1
    Win32 Version: 18.1.015.1
    CodeBase: file:///C:/Program%20Files/adsk_raster_design_2011/AeciRibbon54res.dll
Redland.NET
    Assembly Version: 0.9.17.6
    Win32 Version: 0.9.17.6
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/Redland.NET.DLL
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AcWindows.dll
AeccWindows
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AeccWindows.DLL
AeccDbMgd
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AeccDbMgd.DLL
AecBaseMgd
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AecBaseMgd.DLL
ManagedMC3
    Assembly Version: 4.11.0.0
    Win32 Version: 4.12.0.0
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/ManagedMC3.DLL
9w5jbjmj
AcLayer
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AcLayer.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/en-US/AcLayer.resources.DLL
AeccUiMgd
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AeccUiMgd.DLL
UIAutomationProvider
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Accessibility
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AcCommandToolTips
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AcCommandToolTips.DLL
AcCommandToolTips.resources
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/en-US/AcCommandToolTips.resources.DLL
VerticalTips
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/VerticalTips.DLL
AeccUiTooltipContent
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/AeccUiTooltipContent.DLL
AeccUiTooltipContent.resources
    CodeBase: file:///C:/Program%20Files/adsk_c3d_2011/en-US/AeccUiTooltipContent.resources.DLL
PresentationUI
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationUI/3.0.0.0__31bf3856ad364e35/PresentationUI.dll
PresentationFramework.Luna
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Luna/3.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
C3D StyleTools
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/_remote_drives/R/cad/support/water/common/app/style_tools/C3D%20StyleTools.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Re: Civil 3D Styles | Get Count Failed
« Reply #1 on: March 27, 2012, 09:49:56 AM »
Is this a 32 bit install? Are you still using the modified acad.exe.config? Does this error occur with all drawings?
BlackBox
« Reply #2 on: March 27, 2012, 10:05:04 AM »
64 Bit (Windows 7), OOTB acad.exe.Config, and it does not fail with every drawing.
Having just tested this, acad.dwt fails, but "_AutoCAD Civil 3D (Imperial) NCS.dwt" is successful.
If no QNEW is specified, does C3D default to acad.dwt? I did confirm the the 2011 profile has no DWT set as QNEW, whereas 2012 is set for NCS as above. Works in 2012 , not in 2011... The template may be my issue.
BlackBox
« Reply #3 on: March 27, 2012, 10:08:18 AM »
Additional testing shows that our corporate template also fails, but the template that I've been preparing does not... Mine used "_AutoCAD Civil 3D (Imperial) NCS.dwt" as a starting point. Not sure about the corporate template.
Edit - What doesn't make sense is that even in acad.dwt there are styles... albeit 'standard' ones, but they're there. Why would the code fail at 'Get Count' because the styles are from acad.dwt?
« Reply #4 on: March 27, 2012, 10:15:42 AM »
OK, I can duplicate the error by changing my QNEW template to none, then choosing the acad3d.dwt to start a new drawing from. Not sure why these generic dwt's would ever be used to start a C3D drawing with, but I will see if there's a way to trap this issue.
BlackBox
« Reply #5 on: March 27, 2012, 10:25:06 AM »
Confirmed that the issue is the template, and not the acad.exe.Config file, as I've restored Kean's configuration to allow remote sources, and get same results as above.
I agree that one should have a QNEW specified, but unfortunately there seems to be a distinction between even which template is used as a starting point for one's corporate template. For example, I opened acad.dwt, added a new surface style, then attempt CreatedByUpdate and still result in fatal error.
I am beginning to suspect that the corporate template was started by acad.dwt and not the NCS template (which is odd, given that we're NCS based, but still). I need to try to pinpoint what about any given template would cause this... that may be asking too much. LoL
« Reply #6 on: March 27, 2012, 10:30:42 AM »
Looks like the problem is with drawings brought forward and have not had certain commands run to instantiate certain styles.....the first error I'm seeing is occurring on the ProfileDesignCheckSetCollection, and it's being thrown due to the collection has not been initialized. I think I know how to work around this, stay tuned.
huiz
  • Certified Prof C3D
« Reply #7 on: March 27, 2012, 10:34:22 AM »
If you use a template without styles, there might not be a stylecollection, and so you can't use the count method.
You better check first if there is any style collection.
 Try
      Dim tmpCounter As Integer
      tmpCounter = <your style collection here>.Count
 Catch ex As Autodesk.Civil.CivilException
     ' Some error, there are no styles.
     ' <print your ex.message>
  End Try
« Reply #8 on: March 27, 2012, 10:40:46 AM »
Yes, this now works by adding 2 lines of code....
Code - C: [Select]
  1.         private static void ListCollection(Type objectType, PropertyInfo pf, object myStylesRoot)
  2.         {
  3.
  4.             object res = objectType.InvokeMember(pf.Name,
  5.                             BindingFlags.GetProperty, null, myStylesRoot, new object[0]);
  6.             if (res.Equals(null))
  7.                 return;
  8.
  9.             StyleCollectionBase scBase = (StyleCollectionBase)res;
  10.             //added the following to eliminate error thrown when a collection has not yet been initialized
  11.             try { int i = scBase.Count; }
  12.             catch { return; }
  13.
  14.             foreach (ObjectId sbid in scBase)
  15.             {.......
  16.
I've added a message with attachment to the original thread.
« Last Edit: March 27, 2012, 10:49:29 AM by Jeff_M »
airportman
  • i customize when required
« Reply #9 on: January 05, 2021, 12:18:02 PM »
Jeff - have you created an update dll for this since version 2012?
I'm looking for a way to export my C3D Template contents to either a CSV or another database type format.
Trying to build a framework document for tracking.
Perception is a state of mind  -/ Twitter = @hochanz -/ Intel i7 - 3.07GHz -/ 12GB Ram -/ Nvidia Quadro FX 1800
« Reply #10 on: January 05, 2021, 06:17:55 PM »
Not sure how that dll would help you export anything. There used to be a Sample program to Export text file of all the style names that was included with C3D. I still have my modified copy, which creates an XML file instead. A DLL compiled for C3D 2016 (and works with all newer releases) is attached. If you need it to output more data for each style, I can post the source code for you to modify as needed.
