Hello Swamp Members,
We are still using the VBA application provided by Autodesk with AutoCAD 2012. Most of the routines run OK however, I am having problems with one program that does "Batch Pltting" of AutoCAD drawings and interfaces with our database to input plot records we use to generate invoices for reimbursable plotting. With my limited VB knowledge, I can not get the routine to run properly and I was hoping someone with more expertise could look at the code and see if they could indentify problem areas that would cause problems.
Any assistance would be appreciated......Thank you in advance for your anticipated cooperation regarding this matter....!
Regards,
Vince
