Author Topic: "DCLIP" as like "XCLIP"  (Read 3120 times)
ProfWolfMan
« on: March 22, 2012, 10:51:14 PM »
Hi all,
Anyboy try a routine as like "XCLIP" command for curent drawing objects.
I am in a situation to develop a command which is going to trim/remove all entities in the drawing except selected rectangular region.
Kindly share your thoughts on these area.
Thanks for your support.
-Ganesan M
huiz
  • Certified Prof C3D
Re: "DCLIP" as like "XCLIP"
« Reply #1 on: March 23, 2012, 03:29:03 AM »
Xclip does not remove objects from the drawing so it is not the same as a dclip function like you describe.
There is/was a tool in the Express Tools which did the same, cutting everything inside a polyline. I can not find it anymore, I thought it was named CookieCutter.
You can also have a look here, where you can find an excellent lisp tool to cut and trim inside or outside a polyline.
http://www.theswamp.org/index.php?topic=24646.0;all
ProfWolfMan
« Reply #2 on: March 23, 2012, 05:29:50 AM »
Thank you very much to point that routine.
