Author Topic: Attaching Images in Bricscad 12 via .NET Code  (Read 904 times)
User48
  • Mosquito
« on: March 22, 2012, 07:47:58 pm »
Anyone have an example of loading/inserting an image object in Bricscad .NET code?  I'm using code that has always worked well in WellKnownCAD but produces an "Attempted to read or write protected memory" error on the .Load method in BCAD (Teigha.DatabaseServices.RasterImageDef.Load).
nullptr
  • Bricscad
  • AKA Daniel
Re: Attaching Images in Bricscad 12 via .NET Code
« Reply #1 on: March 22, 2012, 08:43:59 pm »
can you show your code?
User48
  • Mosquito
« Reply #2 on: March 23, 2012, 10:14:29 am »
Not radically different that an example on this site:
http://www.theswamp.org/index.php?topic=31863.msg392684#msg392684
I used the above, commented the .ActiveFileName because it was returning "Not Implemented" and it also failed with the same error code.  I'm beginning to think there is a bug in the API ?
nullptr
  • Bricscad
  • AKA Daniel
« Reply #3 on: March 23, 2012, 09:48:31 pm »
try moving the load method after ImageDic.SetAt.
User48
  • Mosquito
« Reply #4 on: March 24, 2012, 03:38:30 pm »
That made the difference, thanks.
huiz
  • Certified Prof C3D
« Reply #5 on: November 27, 2012, 04:05:13 am »
If I use the mentioned code in BricsCAD, the images are loaded and shown but the size is 0 in width and height. I also can't change this setting in the properties dialog.
In AutoCAD the code works well.
Anyone who has added images succesfully in BricsCAD?
nullptr
  • Bricscad
  • AKA Daniel
« Reply #6 on: November 29, 2012, 05:04:26 am »
this works for me
   [CommandMethod("doit")]
    static public void doit()
      Database db = doc.Database;
        ObjectId dictId = RasterImageDef.GetImageDictionary(db);
        if (dictId.IsNull)
          dictId = RasterImageDef.CreateImageDictionary(db);
        DBDictionary dict = tr.GetObject(dictId, OpenMode.ForWrite) as DBDictionary;
        RasterImageDef rid = new RasterImageDef();
        rid.SourceFileName = "c:\\Capture.tif";
        ObjectId defId = dict.SetAt("Capture", rid);
        rid.Load();
        tr.AddNewlyCreatedDBObject(rid, true);
        RasterImage ri = new RasterImage();
        ri.ImageDefId = defId;
        ri.ShowImage = true;
        ri.Orientation = new CoordinateSystem3d(Point3d.Origin,Vector3d.XAxis,Vector3d.YAxis);
        BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
        btr.AppendEntity(ri);
        tr.AddNewlyCreatedDBObject(ri, true);
        ri.AssociateRasterDef(rid);
        tr.Commit();
Cheers
huiz
« Reply #7 on: November 29, 2012, 07:12:46 am »
You do not scale the image in your code, that is the problem I face.
  RasterEnt = New RasterImage
  RasterEnt.SetDatabaseDefaults(ThisDoc.Database)
  RasterEnt.ShowImage = True
  Matrix = New Matrix3d
  Matrix = Matrix3d.Scaling(Scale / RasterDef.Size.X, New Point3d(0, 0, 0))
  RasterEnt.TransformBy(Matrix)
This does not seem to work in BricsCAD, but does in AutoCAD.
nullptr
  • Bricscad
  • AKA Daniel
« Reply #8 on: November 29, 2012, 08:47:06 am »
This one with scaling seems to work fine.
        if (dictId.IsNull)
        rid.Load();
        ri.Orientation = new CoordinateSystem3d(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis);
        ri.TransformBy(Matrix3d.Scaling(3 / rid.Size.X, new Point3d(0, 0, 0)));
        tr.Commit();
« Last Edit: November 29, 2012, 08:54:10 am by eNotEnoughBeer »
huiz
« Reply #9 on: November 29, 2012, 03:25:00 pm »
Unfortunately your code doesn't help me neither. If I use your function the images have both a width and height of 1, while they should not be square. At least it is better than 0, the result of the previous function, but still not good.
Thanks anyway for your help :-)
  • Mesozoic Relic
« Reply #10 on: November 29, 2012, 05:06:18 pm »
huiz,
if you debug and step through your ( Dans) code ; what us the value of rid.Size.X ??
Discipline : absolutely none at all.
--> Donate to TheSwamp <--
nullptr
  • Bricscad
  • AKA Daniel
« Reply #11 on: November 29, 2012, 08:10:27 pm »
My code? I used your scaling scheme verbatim, well except in a more performant  C# version.  :lol:
Seriously though,  The default seems to be inserted with a uniform matrix, your you'll need to create a scaling matrix that fits your needs... I'll just use the image width and height for now, you might want to use a ratio or whatever.. I'll leave that up to you : )
        if (dictId.IsNull)
        rid.Load();
        double[] _xform = new double[16];
        _xform[0] = rid.Size.X;
        _xform[5] = rid.Size.Y;
        _xform[10] = 1.0;
        _xform[15] = 1.0;
        Matrix3d smatrix = new Matrix3d(_xform);
        ri.TransformBy(smatrix);
        ri.TransformBy(Matrix3d.Scaling(3 , new Point3d(0, 0, 0)));
        ri.Orientation = new CoordinateSystem3d(ri.Orientation.Origin, ri.Orientation.Xaxis, ri.Orientation.Yaxis);
        tr.Commit();
huiz
« Reply #12 on: November 30, 2012, 02:07:17 pm »
Well, VB.Net reads good too :-)
  Public Sub AddRaster(RasterFile As String, InsPoint As Point3d, Scale As Double, Layer As String)
    Dim doc As acAppServ.Document = acAppServ.Application.DocumentManager.MdiActiveDocument
    Dim db As Database = doc.Database
    Using tr As Transaction = db.TransactionManager.StartTransaction()
      Dim dictId As ObjectId = RasterImageDef.GetImageDictionary(db)
      If dictId.IsNull Then
      End If
      ' Filename from path.
      Dim RasterName As String = RasterFile.Substring(RasterFile.LastIndexOf("\") + 1)
      RasterName = RasterName.Substring(0, RasterName.IndexOf("."))
      Dim dict As DBDictionary = TryCast(tr.GetObject(dictId, OpenMode.ForWrite), DBDictionary)
      Dim rid As New RasterImageDef()
      rid.SourceFileName = RasterFile
      Dim defId As ObjectId = dict.SetAt(RasterName, rid)
      rid.Load()
      tr.AddNewlyCreatedDBObject(rid, True)
      Dim ri As New RasterImage()
      ri.ShowImage = True
      ri.TransformBy(Matrix3d.Scaling(Scale / rid.Size.X, New Point3d(0, 0, 0)))
      ri.Orientation = New CoordinateSystem3d(InsPoint, Vector3d.XAxis, Vector3d.YAxis)
      Dim btr As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
      tr.AddNewlyCreatedDBObject(ri, True)
      tr.Commit()
    End Using
This proc is what I have sofar. The images are placed in the correct coordinate, but both with and height are set to 1. The real size of the image is 5110x3486, that should be scaled to 365x250 units. The debugged value of (Scale /rid.Size.X) is 0.0714 (that is correct). So the image scale should be 0.07, but after placing the images have a scale of 0.00055.
If I compare this to AutoCAD, there I have a function where I use twice a TransformBy method, one for Scaling and one for Displacement. If I use that in BricsCAD, only the Displacement is applied, the Scaling result in a width and height of zero.
nullptr
  • Bricscad
  • AKA Daniel
« Reply #13 on: December 01, 2012, 02:59:27 am »
You know I was just joking with you right? hmm maybe the veebee joke are getting long in the tooth  :|
  • Mesozoic Relic
« Reply #14 on: December 01, 2012, 03:54:39 am »
You'll have a reason to dust off the veebeea joke book again next year Dan.  :|
nb: Please note that I have nothing against vb users ...
Added: how's the Bricscad .net implementation progressing ??
