Yeah ... now it is perfect
Excellent
So can we make it with ssget function for multiple selection set and getting them all within one base point ?
This task is not possible using ssget as it requires a subentity selection; however, the change to the Block Definition will be reflected across all Block References, so it may be better to have the code extract the nested block for all references - I'll see what I can do when I get some time.
