Hi Lee .
Many thanks for your hard work on the thread .
Both routines gave me the same result (error) ;
Command: enb
Select Nested Block: ; error: Exception occurred: 0xC0000005 (Access Violation)
; warning: unwind skipped on unknown exception
My thoughts were to make a selection set of blocks and check every Block for a specific block name (one or two blocks) and insert
the same block(s) in the same location in Model space to be able later on to make another selection set of these blocks and move
them to another drawing with the same base point .
The hard part of the routine for me is that the translation of coordinates from Block Definition to model Space .
Thanks a lot
