Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Problem with Properties
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Problem with Properties (Read 391 times)
Avanti
Newt
on:
March 19, 2012, 05:58:46 pm »
I have a new computer using 2009. Everything seems to be working but all I get in the properties window is drawing properties. If I select anything the box is completely blank.
Help! What am I doing wrong?
Thanks,
Avanti
Logged
Bryco
Water Moccasin
Re: Problem with Properties
Reply #1 on:
March 20, 2012, 08:53:18 am »
I seem to remember having that problem w/ inventor installed before cad. I had to uninstall inventor then reinstall
Logged
dgorsman
Swamp Rat
Reply #2 on:
March 20, 2012, 09:19:51 am »
PICKFIRST system variable?
Logged
try {GreatPower;}
catch (notResponsible)
{NextTime(PlanAhead);}
finally
{MasterBasics;}
Avanti
Newt
Reply #3 on:
March 20, 2012, 11:34:53 am »
Thanks, I didn't even think of that. I was laid-off for two years and am gradually getting back up to speed.
Logged
Avanti
Newt
Reply #4 on:
March 23, 2012, 06:07:05 am »
Oh, how I wish it was the Pickfirst problem, but that's not it.
Hasn't anyone else had this problem?
Logged
MUQTAR
Newt
Reply #5 on:
March 23, 2012, 08:54:01 am »
Re Install the autocad
Logged
RobDraw
Swamp Rat
Take a little time to stop and smell the roses.
Reply #6 on:
March 23, 2012, 09:00:19 am »
Does it happen in every file?
Logged
Rob "The Cleaner" aka "The Creator of Sheets"
Senior Mechanical Designer
Building Systems
Avanti
Newt
Reply #7 on:
March 23, 2012, 09:37:54 am »
AutoCAD has been reinstalled and it's the same in all files. I'm baffled.
Logged
MUQTAR
Newt
Reply #8 on:
April 13, 2012, 11:14:19 am »
Check your system variables PICKFIRST set to 1.
Logged
MUQTAR
Newt
Reply #9 on:
April 13, 2012, 11:16:10 am »
IIIRC, this can be caused by registry cleaners that wipe out some needed data. A Repair or Reinstall should fix it, unless of course the offending program is wiping it again.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
