Author Topic: Dim Mode !!?  (Read 11075 times)
Andrea
Dim Mode !!?
« on: February 21, 2005, 11:24:33 AM »
Hi all.
I'm trying to doing something like this...
(setq SDC_dimscale (getvar "dimscale")
        SDC_dimstyle (getvar "dimstyle")
        SDC_cecolor (getvar "cecolor")
        SDC_clayer (getvar "clayer")
(setvar "dimscale" 2)
(setvar "dimstyle" "standard1")
(setvar "cecolor" 4)
(setvar "clayer" "dim")
(command "_dim1")
(setvar "dimscale" SDC_dimscale)
(command "_-dimstyle" "_R" SDC_dimstyle)
(setvar "cecolor" SDC_cecolor)
(setvar "clayer" SDC_clayer)
But..not working..
and i have no idea how to do something like this..
any idea ?
By the way....
I have the text screen avery time using this line..
Keep smile...
sinc
Dim Mode !!?
« Reply #1 on: February 21, 2005, 11:47:33 AM »
Just to let you know, I'm using one of the other color schemes for this web site (the blue one, I forget what they called it).  It makes your blue code very hard to read.  Using the "Code" window instead of custom colors works much better for everyone trying to read your post...
sinc
Dim Mode !!?
« Reply #2 on: February 21, 2005, 11:48:46 AM »
Quote from: sinc
I see at the bottom of the web page that I'm using the "Cobalt 2.0" theme...
CADaver
Re: Dim Mode !!?
« Reply #3 on: February 21, 2005, 11:53:52 AM »
Quote from: Andrea
(command "_dim1")
But..not working..
any idea ?
Could be that "_dim1" is looking for a dim command to follow.
Andrea
Re: Dim Mode !!?
« Reply #4 on: February 21, 2005, 12:20:17 PM »
Quote from: CADaver
Quote from: Andrea
(command "_dim1")
But..not working..
any idea ?
I Know...
But i need to set variables before using DIM commands AND reset these variables when DIMMODE was ended.
any help ??
Keep smile...
nivuahc
Dim Mode !!?
« Reply #5 on: February 21, 2005, 12:24:37 PM »
In that instance, dimmode hasn't ended.
Even if you changed it to
(command "_dim1" "")
It would be doing something. As it is, it's waiting for a command at the point that you have it.
CADaver
Re: Dim Mode !!?
« Reply #6 on: February 21, 2005, 12:30:14 PM »
Quote from: Andrea
I Know...
any help ??
You need to build what you need done with the dim1 command into the routine.
Andrea
Dim Mode !!?
« Reply #7 on: February 21, 2005, 12:36:28 PM »
So there is no solution ??
I can't believe..
even using reactors or something like that ?
Keep smile...
nivuahc
Dim Mode !!?
« Reply #8 on: February 21, 2005, 01:08:30 PM »
Andrea, pay attention...
The line that you have
(command "_dim1")
puts Autocad into Dim mode and waits for a command. You are not supplying a command.
You need to have something else, either end dim mode by pressing enter such as
or whatever it is that you want to do while in dim mode.
Now, the only reason I can see that you are not getting what we are trying to say is that you want to have Autocad change those settings (what you did before the (command...) bit), then you want to be able to do whatever, and then you want Autocad to change your settings back when you're finished. If that is the case, and the whatever part is going to be different each time you run it, then you either need to buy the "clairvoyency" module for Autocad or you need to use a reactor.
[EDIT: And I moved your thread into the appropriate forum and deleted the duplicate you setup.]
Andrea
Dim Mode !!?
« Reply #9 on: February 21, 2005, 01:14:52 PM »
ok thanks..
so I do I use reactor for making this...?
Keep smile...
nivuahc
Dim Mode !!?
« Reply #10 on: February 21, 2005, 01:19:45 PM »
Well there is a great thread, right in this forum, that talks all about reactors.
You can find it by following this link
You might want to take note of who started that particular thread, if it's any help.
CADaver
Dim Mode !!?
« Reply #11 on: February 21, 2005, 01:23:13 PM »
Quote from: Andrea
ok thanks..
No not necessarily, just complete the lisp you've already started.  What is it you want dim1 to do? Code it in.
Andrea
Dim Mode !!?
« Reply #12 on: February 21, 2005, 01:33:46 PM »
Quote from: CADaver
Quote from: Andrea
ok thanks..
CADaver,
The LISP is for detecting the DIM mode....
Keep smile...
nivuahc
Dim Mode !!?
« Reply #13 on: February 21, 2005, 01:37:54 PM »
Quote from: CADaver
Quote from: Andrea
ok thanks..
I think what Andrea is trying to accomplish is
1. Make the changes to the Dim settings
2. Allow the user to do whatever, (not something specific, only something to do with Dimensioning, which is completely up to the user).
3. Change the settings back when the user is finished Dimensioning (whenever that may be).
Please correct me if I am wrong Andrea.
Andrea
Dim Mode !!?
« Reply #14 on: February 21, 2005, 02:06:07 PM »
exact nivuahc....
But i can't do-it............(for the moment)   :?
Keep smile...
