Author Topic: StringToColorTest  (Read 261 times)
  • Mesozoic Relic
StringToColorTest
« on: March 08, 2012, 07:17:33 pm »
In response to :
http://forums.autodesk.com/t5/NET/Changing-the-Color-Line-type-and-Line-weight-using-Net/td-p/3362911
Just playing around :
One option to convert a string value to an integer representing an AutoCAD color index (ie: 0 to 256)
Allow the user to enter the color Name or enter an integer.
This could be used to return the Color object .
Code solution is attached.
Any comments ?
Code - C++: [Select]
  1. // (C) CodeHimBelonga kdub
  2.
  3. using System;
  4. using System.Windows;
  5. using Autodesk.AutoCAD.ApplicationServices;
  6. using Autodesk.AutoCAD.DatabaseServices;
  7. using Autodesk.AutoCAD.EditorInput;
  8. using Autodesk.AutoCAD.Runtime;
  9. using StringToColorTest;
  10. using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
  11.
  12. [assembly: CommandClass(typeof (StringToColor))]
  13.
  14. namespace StringToColorTest
  15. {
  16.    public class StringToColor
  17.    {
  18.        [CommandMethod("DoIt")]
  19.        public void StringToColorTest_01()
  20.        {
  21.            Editor ed           = AcadApp.DocumentManager.MdiActiveDocument.Editor;
  22.            string colorString  = AskUserForColorString(ed);
  23.            int colorIndex      = ColorIndexFromString(colorString);
  24.
  25.            MessageBox.Show( "Color String : " +
  26.                                        colorString +
  27.                                        "\nTranslates to Integer : " +
  28.                                        colorIndex.ToString(),
  29.                              "StringToColorTest_01");
  30.        }
  31.
  32.        //
  33.        //
  34.        public string AskUserForColorString(Editor ed)
  35.        {
  36.            PromptStringOptions strOpts = new PromptStringOptions("\nEnter Color: ");
  37.            strOpts.AllowSpaces         = false;
  38.            PromptResult res            = ed.GetString(strOpts);
  39.
  40.            if (res.Status != PromptStatus.OK)
  41.            {
  42.                return "ByLayer";
  43.            }
  44.            return res.StringResult;
  45.        }
  46.
  47.        //
  48.        //
  49.        public int ColorIndexFromString(string colorString)
  50.        {
  51.            int result = -1;
  52.            if (int.TryParse(colorString, out result))
  53.            {
  54.                result = ((result >= 0) && (result <= 256) ? result : 256);
  55.            }
  56.            else
  57.            {
  58.                try
  59.                {
  60.                    MyColors colorIndex =
  61.                        (MyColors) Enum.Parse(typeof (MyColors), colorString, true);
  62.                    if (Enum.IsDefined(typeof(MyColors), colorIndex))
  63.                    {
  64.                        result = (int) colorIndex;
  65.                    }
  66.                }
  67.                catch (ArgumentException)
  68.                {
  69.                    AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
  70.        "Blooper !!");
  71.                    return 256;
  72.                }
  73.            }
  74.            return result;
  75.        }
  76.
  77.        //
  78.        //
  79.        private enum MyColors
  80.        {
  81.            ByBlock = 0,
  82.            Red     = 1,
  83.            Yellow  = 2,
  84.            Green   = 3,
  85.            Cyan    = 4,
  86.            Blue    = 5,
  87.            Magenta = 6,
  88.            White   = 7,
  89.            Grey    = 8,
  90.            ByLayer = 256
  91.        };
  92.    }
  93. }
  94.
« Last Edit: March 08, 2012, 07:28:22 pm by Kerry »
Discipline : absolutely none at all.
--> Donate to TheSwamp <--
  • Mesozoic Relic
Re: StringToColorTest
« Reply #1 on: March 12, 2012, 02:15:30 am »
ahhh ... no-one found the bugs  :-D
