Author Topic: command SPLINE versus (command "_SPLINE") in AutoCAD 2012  (Read 1973 times)
Harrie
« on: March 06, 2012, 10:22:16 AM »
When I type SPLINE in AutoCAD 2012, then I get:
Command: SPLINE
Current settings: Method=CV   Degree=3
Specify first point or [Method/Degree/Object]:
When I type (command "_SPLINE") in AutoCAD 2012, then I get:
_SPLINE
Specify first point or [Object]:
There are no options for Method and Degree!
How can I, use the method of 'Çontrol Vertices' with Lisp?
« Last Edit: March 06, 2012, 10:27:46 AM by Harrie »
alanjt
  • Standby for witty remark...
Re: command SPLINE versus (command "_SPLINE") in AutoCAD 2012
« Reply #1 on: March 06, 2012, 10:27:58 AM »
What is CMDECHO set as?
You have to understand that commands issued normally and commands issued with (command "NAME"..) will react and display differently.
Dropbox
« Reply #2 on: March 06, 2012, 10:42:55 AM »
Does (initcommandversion) have any effect?
Harrie
« Reply #3 on: March 06, 2012, 12:27:01 PM »
Yes,
Thanks Lee Mac.
« Reply #4 on: March 06, 2012, 02:26:58 PM »
Excellent, you're welcome  :-)
