Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Convert Drawing from Color Based to Style Based
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Convert Drawing from Color Based to Style Based (Read 1519 times)
cmwade77
Swamp Rat
on:
March 05, 2012, 04:08:32 PM »
Ok, I need to be able to convert drawings from color based (.ctb) to style based (.stb)
without
using converpstyles.
Does anyone have any ideas?
Logged
Matt__W
Seagull
I like my water diluted.
Re: Convert Drawing from Color Based to Style Based
Reply #1 on:
March 05, 2012, 04:26:06 PM »
Why are you against using the command that designed to do that??!?
Logged
Autodesk Expert Elite
Owner/FAA sUAS Pilot @
http://skyviz.io
cmwade77
Swamp Rat
Reply #2 on:
March 05, 2012, 04:29:26 PM »
It is currently failing in some cases and I want a redundant system in the event that it fails. It basically boils down to a bug in AutoCAD and I am attempting a brute force method to go around it.
Last Edit: March 05, 2012, 04:51:42 PM by cmwade77
Logged
cmwade77
Swamp Rat
Reply #3 on:
March 06, 2012, 05:29:42 PM »
I have figured out a work around for this case.
Basically, I open a drawing that is setup for style based plotting and insert the other drawing as an exploded block. It works, but is not the way that I would like to have accomplished this.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
