Author Topic: eNotOpenForWrite error during db.SaveAs  (Read 2959 times)
TJK44
« on: March 05, 2012, 02:22:03 PM »
I am trying to SaveAs the current open dwg with a new name, I try to use this code but it errors out saying eNotOpenForWrite and AutoCAD then crashes. This is the code I'm using, not sure what I'm missing.
        Using curDb As Database = HostApplicationServices.WorkingDatabase
            curDb.SaveAs(dirname, True, DwgVersion.Current, curDb.SecurityParameters)
        End Using
Re: eNotOpenForWrite error during db.SaveAs
« Reply #1 on: March 05, 2012, 02:47:30 PM »
Are you calling that from a pallete or form (ie: in Application context) ... if so you may need to try document locking.
Your code looks fine otherwise.
added:
Are you using a 'Session' Flag ?
« Last Edit: March 05, 2012, 02:52:24 PM by Kerry »
TJK44
« Reply #2 on: March 05, 2012, 03:03:23 PM »
Thanks Kerry, this fixed it. It was being called from a form.
            Using doclock As DocumentLock = document.LockDocument()
            End Using
        End Using
