Author Topic: CIRCLES IN A CURVE  (Read 2154 times)
sandrex
CIRCLES IN A CURVE
« on: February 29, 2012, 06:26:05 PM »
Hello forum, I'm new vlisp.
As I can do circles around a curve at different distances.
« Last Edit: March 01, 2012, 02:14:49 PM by sandrex »
danallen
Re: CIRCLES IN A CURVE
« Reply #1 on: February 29, 2012, 06:31:09 PM »
make a block of a circle, then use DIVIDE or MEASURE, and the "block" option
Dan
sandrex
« Reply #2 on: February 29, 2012, 06:43:05 PM »
heló Dan.
An example please.
danallen
« Reply #3 on: February 29, 2012, 07:50:35 PM »
draw a circle, type "BLOCK", select the circle and make it a block
draw your curve, is it a spline?
type DIVIDE, select your curve, type BLOCK, enter the name of your block, and finish the command options
irneb
« Reply #4 on: March 03, 2012, 01:04:54 AM »
If you've got ACad 2012 you can achieve the same through the new array command. It has an option to array along a path (any path: arc, polyline, spline, line, etc.). No need to first change the circle into a block. And you can adjust the spacing / number of array items by dragging grips / using the properties palette after the fact, no need to redo the divide/measure if you want a change.
irneb
« Reply #5 on: March 03, 2012, 01:30:04 AM »
E.g. the old way would be to use the Divide / measure commands (see video capture). Also shown the new array command with path.
fixo
« Reply #6 on: March 03, 2012, 09:43:04 AM »
Found it in my code storage, se if this is working for you
;;------------------------------------ DIVC.LSP ----------------------------------;;
;; fixo () 2012 * all rights released
;; edited 3/3/12
;; used Nueva carpeta.dwg
(defun C:DIVC(/ *error* acsp adoc closed cnt curve en leng num oname p rad sset step)
    (defun *error* (msg)
      (vla-endundomark (vla-get-activedocument
              (vlax-get-acad-object))
    (cond ((or (not msg)
       (member msg '("console break" "Function cancelled" "quit / exit abort"))
  ((princ (strcat "\nError: " msg)))
(setq adoc (vla-get-activedocument
      acsp (vla-get-block(vla-get-activelayout adoc)))
  (vla-startundomark adoc )
(while (not sset)
    (setq sset (ssget '((0 . "*LINE,ARC,ELLIPSE,ARC,CIRCLE")))
(initget 7)
(setq num (getint "\nNumber of circles? : ") )
(initget 7)
(setq rad (getdist "\nRadius ? : ") )
(while (setq en (ssname sset 0))
  (setq curve (vlax-ename->vla-object en))
  (setq oname (vla-get-objectname curve))
  (cond ((eq "AcDbArc" oname)
(setq leng (vla-get-arclength curve)))
((or (eq "AcDbEllipse" oname) (eq "AcDbSpline" oname))
(setq leng (vlax-curve-getdistatparam
      curve
      (vlax-curve-getendparam curve)))
(if (equal (vlax-curve-getendparam curve) (* pi 2) 0.0001)
   (setq closed T)
   (setq closed nil))
;;ellipse
((eq "AcDbCircle" oname)
(setq leng (vla-get-circumference curve))
(setq closed T)
((eq "AcDbLine" oname)
(setq leng (setq leng (vla-get-length curve)))
(setq closed nil)
((eq "AcDbPolyline" oname)
   (if (eq :vlax-true
   (vl-catch-all-apply '(lambda () (vla-get-closed curve))))
     (setq closed T)
     (setq closed nil)))
  (setq step (if closed
       (/ leng num)
       (/ leng (1- num))))
  (setq cnt 0)
  (repeat num
    (setq p (vlax-curve-getpointatparam
      curve
      (vlax-curve-getparamatdist curve (* step cnt))))
    (vlax-invoke acsp 'addcircle p rad)
    (setq cnt (1+ cnt))
  (ssdel en sset)
  (*error* nil)
(princ "\n\t---\tStart command with \"DIVC\"\t---")
(or (vl-load-com)
    (princ))
~'J'~
trogg
« Reply #7 on: March 03, 2012, 11:21:46 AM »
Don't forget Allan's code "Copy Along Curve"
http://www.theswamp.org/index.php?topic=32789.0
