When I open a new drawing, by default all 3D objects look like the attached ‘bad’ jpg with the white background what it looks like when printed or a print preview and the black background in model space. There is a per drawing setting switch that is active so that they can look like the ‘good’ jpg, what is that command? Short of moving everything into a blank drawing template that already is set up like the good way, there is no way that I know of to change the way the piping looks.
I have one more question. How can you turn front/back clipping on or off without going into the 3DCLIP command?
Thanks in advance.
