Author Topic: Syntax for calling commands from autocad  (Read 4253 times)
SIDESHOWBOB
« on: February 23, 2012, 01:22:49 PM »
Yet another newbie question here, but if I define this
  1. (defun C:test (i) (* 2 i))
How do I pass the argument on the autocad command line?  Tried brackets, spaces, etc - no luck!
Re: Syntax for calling commands from autocad
« Reply #1 on: February 23, 2012, 01:25:49 PM »
Don't use "C:" with functions that have arguments.
alanjt
  • Standby for witty remark...
« Reply #2 on: February 23, 2012, 01:26:32 PM »
eg.
Command: (defun test (i) (* 2 i))
TEST
Command: (test 5)
10
Dropbox
SIDESHOWBOB
« Reply #3 on: February 23, 2012, 01:30:01 PM »
Ah, I see you are both right.  You can call functions from the command line with (test 2) same as you would from the lisp prompt.  But if you do so, autocad does not hide internal lisp functions from you!  I thought I was supposed to be able to hide anything without a C: ... never mind :)
« Reply #4 on: February 23, 2012, 01:41:34 PM »
Not sure what you mean by "hiding". Are you talking about scope?
Just in cast you stumble upon...I'll add this (It's not "proper" so I wasn't going to mention it but you're a developer so you can add as many grains of salt to this as necessary):
Command: (defun C:test2 (i) (* 2 i))
C:TEST2
Command: (c:test2 2)
4
However, use this form instead (don't use the above).
  1. (defun test (i) (* 2 i))
« Reply #5 on: February 23, 2012, 01:42:14 PM »
You can if you 'compile' the code to a VLX with a separate namespace, the function won't be available outside of the namespace (unless exported using vl-doc-export)
FYI, concerning the 'c:' prefix, it merely makes the function available at the command-line, but since 'c:test' is just another symbol, the following does work (though, its not good practice):
Command: (defun c:test ( i ) (* 2 i))
C:TEST
Command: (c:test 2)
4
« Reply #6 on: February 23, 2012, 01:47:11 PM »
*lol* There's an echo in here!
alanjt
« Reply #7 on: February 23, 2012, 02:09:51 PM »
an echo in here!
Dropbox
« Reply #8 on: February 23, 2012, 05:40:18 PM »
And what's wrong with this?
    (defun C:test (/ i)
      (if (setq i (getreal "\nEnter number:"))
        (* 2 i)
When you hit the space bar after test the prompt will appear, enter your number and hit enter.
« Reply #9 on: February 23, 2012, 05:51:02 PM »
Nothing at all :-)
Though I think the OP was enquiring as to how to pass arguments to LISP functions  :-)
« Reply #10 on: February 23, 2012, 06:00:30 PM »
Procedurally or semantically?
I think the OP wanted to learn how to call another AutoLisp function.
« Reply #11 on: February 23, 2012, 06:09:51 PM »
Yes.
« Reply #12 on: February 23, 2012, 08:14:10 PM »
*lol*
SIDESHOWBOB
« Reply #13 on: February 24, 2012, 05:37:14 AM »
Nothing, in fact I see that's the answer I need.  While I may have been asking how to call lisp functions from the autocad command line, what I really wanted to know was how to package up my lisp scripts for users to run conveniently. Ta ;)
