Author Topic: Change width of columns in a table  (Read 2244 times)
antistar
« on: February 22, 2012, 08:59:02 AM »
I have several tables with four columns of equal width value.
I'm looking for a routine that when selecting a table to change the width of the columns by applying a different value for each.
Does anyone know if this is possible?
Thanks in advance.
« Last Edit: February 22, 2012, 09:39:36 AM by antistar »
Re: Change width of columns in a table
« Reply #1 on: February 22, 2012, 09:55:03 AM »
Investigate the SetColumnWidth method
antistar
« Reply #2 on: February 22, 2012, 02:21:18 PM »
Lee, thanks for your reply. I'm searching the forums.
As I understand it "SetColumnWidth" is used in routines to parameterize table columns that have yet to be inserted. I need to change columns from tables that are already inserted.
« Reply #3 on: February 22, 2012, 02:38:35 PM »
I would suggest that you read about the method in the VLIDE Help Documentation.  :-)
From the VLIDE Help:
Quote from: VLIDE Help
SetColumnWidth Method
Sets the column width for the column at the specified column index in the table.
This method applies to a VLA Table Object, hence the Table must already exist.
