Hello vnanhvu,
I think you don't need a special lisp to solve this problem.
- please copy our own acad.pgp and all other lisp routine you will need to an
extra folder.
- copy the current profile and set the copied profile current. (All profiles were saved in the registry of the current user, so if your colleague will start AutoCAd on the same client, he can't see the extra profile). You will find a detailed description in the following link:
http://www.studica.com/blog/default-profile-switching-in-autocad-2011 - In the Options window, select the Files tab. Click to "Add" and choose out the new
extra folder. In the next step you have to move the
extra folder to the first position with the "Move up" Button
- If you start AutoCAD the next time, AutoCAD will use the first acad.pgp which it can find. This should be your own acad.pgp. You can test this with following command:
(findfile "acad.pgp")That's it.
Best regards,
jsalzer
