Author Topic: Layer Lisp question  (Read 3354 times)
One Shot
Layer Lisp question
« on: February 17, 2005, 04:14:24 PM »
:?: Is there a lisp routine that can turn on just layers of an active session.   I don't think that I expalined my self correct.  What I whant to do is to turn on all layers except for the laeyers that are associated to Xrefs?
Thank you,
Brad
whdjr
Layer Lisp question
« Reply #1 on: February 17, 2005, 04:46:40 PM »
In the layers dialog box is a built-in filter for all xrefs.
sinc
Layer Lisp question
« Reply #2 on: February 17, 2005, 04:47:45 PM »
Do you really need to do that in Lisp?  Why not just change it in the Layer Manager?  Use the "Show All XRef Dependent Layers" layer filter, and invert the filter.  Then select all and change whatever you want.
whdjr
Layer Lisp question
« Reply #3 on: February 17, 2005, 04:55:17 PM »
oops...I forgot about inverting the selection, but sinc picked it up for me.
Thanks sinc :?
Layer Lisp question
« Reply #4 on: February 17, 2005, 05:34:32 PM »
Well, here's something you can call from a button or the command line that eliminates the need for the time consuming Layer dialog:
(defun c:off-xr ()
  (command "-layer" "on" "*" "off" "*|*" "")
One Shot
Layer Lisp question
« Reply #5 on: February 17, 2005, 05:47:35 PM »
Quote from: Jeff_M
(defun c:off-xr ()
Thank you,
that works great.
What I need is to have the Xref layers that are off to stay off and the rest of the drawing turn on.
whdjr
Layer Lisp question
« Reply #6 on: February 17, 2005, 05:57:13 PM »
If you have the Expresstools use:
LAYOFF
LAYON
LAYFRZ
LAYTHW
One Shot
Layer Lisp question
« Reply #7 on: February 17, 2005, 06:06:55 PM »
Quote from: whdjr
LAYOFF
LAYON
LAYFRZ
LAYTHW
I know about the Expresstool.  But it still does not do what I want to do.
whdjr
Layer Lisp question
« Reply #8 on: February 17, 2005, 06:15:02 PM »
Sorry...that's the second time I have miss read THIS thread. :?  :shock:  :oops:
Layer Lisp question
« Reply #9 on: February 17, 2005, 06:23:11 PM »
In my opinion all you need to do is learn how to use wildcards:
To turn on all layers that are not xrefs (command line):
-layer[enter]
on[enter]
~*|*[enter][enter]
However, in the spirit of swamp helpfulness a quick and dirty ...
(defun TurnLayersOnOff ( spec onIsNotNil / state clayer name )
        (eq :vlax-false
            (setq state
                (if onIsNotNil
                    :vlax-true
                    :vlax-false
        (setq clayer (getvar "clayer"))
    (setq spec (strcase spec))
    (vlax-for layer
        (vlax-get-property
            (vlax-get-property
                (vlax-get-acad-object)
               'ActiveDocument
           'Layers
            (wcmatch
                (setq name
                    (strcase
                        (vlax-get-property
                            layer
                           'Name
                spec
            (if clayer
                (if (eq clayer name)
                    (setq clayer nil)
                    (vlax-put-property
                        layer
                       'LayerOn
                        state
                (vlax-put-property
                    layer
                   'LayerOn
                    state
Still requires knowledge of wildcards for effective use, but now you can precan some stuff on menus ad nauseum.
Some examples ...
;;  all layers off
(TurnLayersOnOff "*" nil)
;;  all layers on
(TurnLayersOnOff "*" t)
;;  all xref layers off
(TurnLayersOnOff "*|*" nil)
;;  all xref layers on
(TurnLayersOnOff "*|*" t)
;;  all non xref layers off
(TurnLayersOnOff "~*|*" nil)
;;  all non xrefs layers on
(TurnLayersOnOff "~*|*" t)
etc.
:D
hudster
Layer Lisp question
« Reply #10 on: February 18, 2005, 03:58:37 AM »
Maybe you could adapt this routine
;;Multi services layer freeze routing
;;By Andy Hudson
;;Adapted from original code by Ronjop
;;Posted on www.theswamp.org
(defun C:MULTI (/ cmd att clay p)
  ;;GET USER VARIABLES
  (setq cmd  (getvar 'cmdecho)
att  (getvar 'attdia)
clay (getvar 'clayer))
  ;;SET LAYER TO ZERO
  (COMMAND "-LAYER" "THAW" "0" "SET" "0" "" "")
  (setvar 'cmdecho 0)
  (setvar 'attdia 1)
  ;;Set the drawing series numbers allowed
  (initget 0 "62 63 64 65 66 FA SEC 1")
  (setq P (cond ((getkword "\nEnter Drawing Series: 62 63 64 65 66 FA SEC <<Enter for all layers>>: "))
("1")))
  ;;All layers on
    (if (= P "1")
      (progn (command ".-layer" "thaw" "*" "")))
  ;;62 SERIES only
        (if (= P "62")
      (progn (command ".-layer" "t" "*62*" "F" "*63*" "F" "*64*" "F" "*65*" "F" "*66*" "F" "*68*" "F" "*95*" "F" "*96*" "T" "*DADO*" "")))
  ;;63 SERIES only
        (if (= P "63")
      (progn (command ".-layer" "t" "*63*""F" "*62*" "F" "*64*" "F" "*65*" "F" "*66*" "F" "*68*" "")))
  ;;64 SERIES only
        (if (= P "64")
      (progn (command ".-layer" "t" "*64*" "F" "*62*" "F" "*63*" "F" "*65*" "F" "*66*" "F" "*68*" "F" "*95*" "F" "*96*" "T" "*DADO*" "")))
  ;;65 SERIES only
    (if(= P "65")
      (progn (command ".-layer" "t" "*65*" "F" "*62*" "F" "*63*" "F" "*64*" "F" "*66*" "F" "*68*" "F" "*95*" "F" "*96*" "")))
  ;;66 SERIES only
        (if (= P "66")
      (progn (command ".-layer" "t" "*66*" "F" "*62*" "F" "*63*" "F" "*64*" "F" "*65*" "F" "*DADO*" "F" "*68*" "F" "*95*" "F" "*96*" "")))
  ;;68_FA SERIES only
        (if (= P "FA")
      (progn (command ".-layer" "t" "*68_FA*" "F" "*62*" "F" "*63*" "F" "*64*" "F" "*65*" "F" "*66*"  "F" "*68_SEC*" "F" "*95*" "F" "*96*" "")))
  ;;68_SEC SERIES only
        (if (= P "SEC")
      (progn (command ".-layer" "t" "*68_SEC*" "F" "*62*" "F" "*63*" "F" "*64*" "F" "*65*" "F" "*66*"  "F" "*68_FA*" "F" "*95*" "F" "*96*" "")))
  ;;RESET USER VARIABLES
  (setvar "cmdecho" cmd)
  (setvar "attdia" att)
  (setvar "clayer" clay)
  ;;CLEAN EXIT
Layer Lisp question
« Reply #11 on: February 18, 2005, 09:59:48 AM »
-layer[enter]
on[enter]
~*|*[enter][enter]
Good stuff MP. I knew the *|* but didn't know about the ~.
So basically One Shot can get what he needs by:
^C^C.-layer;on;~*|*;thaw;~*|*;;
I learn something new every day here :D
Thanks,
Ron
