Author Topic: Reorder Xrefs in xref manager  (Read 1757 times)
TJK44
« on: February 15, 2012, 11:27:36 AM »
More of a general question, is there a way to reorder the xrefs in the in the xref manager? I ask because I am creating a table in autocad that follows the structure of the xref manager. Sometimes well want the order in the table to be able to be changed because of the way we are using the data in the table.
Thanks,
Ted
kaefer
Re: Reorder Xrefs in xref manager
« Reply #1 on: February 15, 2012, 12:53:53 PM »
More of a general question, is there a way to reorder the xrefs in the xref manager?
Sure. Just click on a column header to sort them.
The only hard-coded order I can see as remotely relevant is the order in which objects are stored in the drawing database. Even that could be changed with the DBObject.SwapIdWith method. An example for reordering attributes (defs and refs) can be found at Through the Interface.
