Hello
I know it's an old post but I have one problem with the attached lisp
it works well with normal blocks but unfortunately dynamic blocks are not selected
I do not know lisp and this program would be very helpful to me
Could you help me?
I'm attaching a test file with my dynamic block
block name "E_dyn"
tag "NR"
(defun c:ssnum ( / num_l num_h )
(and
(setq num_l (getreal "\nEnter min value: "))
(setq num_h (getreal "\nEnter max value: "))
(sssetfirst nil (_SelectBlockIfAttInRange "E_dyn" "NR" num_l num_h))
Krzysiek
