Author Topic: Autonumber sheets in Revit  (Read 605 times)
diarmuid
« on: February 14, 2012, 07:13:19 am »
When i add a new sheet to a project, and i fill in the sheet number (say the drawing would be number 008).  If i create an additional new sheet it will auotnumber it to 9 (and not 009) is there any way to retain the 3 digit format other than just renaming the number (which is ok i suppose but it would be a "nice to have")
Any help would be appreciated.
Regards
Diarmuid
If you want to win something run the 100m, if you want to experience something run a marathon
M@yhem
  • Pain is temporary. Quitting is forever.
Re: Autonumber sheets in Revit
« Reply #1 on: February 22, 2012, 08:57:22 am »
I think you're SOL.   :|
diarmuid
« Reply #2 on: February 22, 2012, 08:58:53 am »
 :lmao: :lmao: :lmao: :lmao:
Se7en
« Reply #3 on: February 22, 2012, 09:09:22 am »
Creating a new sheet "works" for me (I get the leading zeros). ...?
I created sheets both ways with the same results; that is to say:
1. In a "drawing list" schedule right click and add a "New row" (now that `new row' item will appear in the "new sheet dialog").
2. View --> New Sheet
huh? I don't think I did anything special.
“Common sense is not so common.” ~Voltaire
--> Donate to TheSwamp.org <--
