Author Topic: Masked Text and Grid Lines  (Read 1137 times)
RobDraw
« on: February 09, 2012, 02:19:38 pm »
Sometimes the text mask blocks grid lines, sometimes it doesn't, on the same views. Thoughts, suggestions?
Rob "The Cleaner" aka "The Creator of Sheets"
Senior Mechanical Designer
Building Systems
Re: Masked Text and Grid Lines
« Reply #1 on: February 09, 2012, 02:22:17 pm »
Draworder?
Offset of the Textmask to the Lines?
Command: TEXTMASK
Initializing...
Current settings: Offset factor = 0.3500, Mask type = Wipeout
Select text objects to mask or [Masktype/Offset]:
The above is from autocad knowledge...does Revit have similar settings?
RobDraw
« Reply #2 on: February 09, 2012, 02:28:47 pm »
Yes, but no that is not the issue. Please note the red duct tag masks the duct but not the grid line running through it.
Building Systems
M@yhem
  • Pain is temporary. Quitting is forever.
« Reply #3 on: February 09, 2012, 02:52:58 pm »
Edit the tag family and change the text for the label from opaque to transparent.
RobDraw
« Reply #4 on: February 09, 2012, 02:54:52 pm »
I didn't make myself "clear". I want the text to mask the grid lines.
Building Systems
M@yhem
« Reply #5 on: February 09, 2012, 02:59:19 pm »
It depends on which was drawn first.  In the attached image I drew the horizontal and vertical grid lines before placing a duct tag.  I then drew a grid line at an angle and lo and behold, it's not being masked by the duct tag because it's "above" the tag.
RobDraw
« Reply #6 on: February 09, 2012, 03:02:04 pm »
More information for you. My grid lines are from a linked model.
Building Systems
M@yhem
« Reply #7 on: February 09, 2012, 03:03:15 pm »
Are they copy/monitored?
RobDraw
« Reply #8 on: February 09, 2012, 03:04:06 pm »
No.
Building Systems
M@yhem
« Reply #9 on: February 09, 2012, 03:28:22 pm »
Why not?
RobDraw
« Reply #10 on: February 09, 2012, 03:30:22 pm »
I don't know.
Building Systems
RobDraw
« Reply #11 on: February 09, 2012, 03:55:50 pm »
Matt, you are onto something with the order thingy. Until recently I was using the Architectural grid and the structural one was not visible. If I cut and paste back into place, all is well.
Building Systems
« Reply #12 on: February 09, 2012, 04:03:14 pm »
Does Revit, really not support or posses a "Draw Order" function?
M@yhem
« Reply #13 on: February 09, 2012, 04:03:20 pm »
"Cut and paste"???  You're cutting the grids from one model to another??
M@yhem
« Reply #14 on: February 09, 2012, 04:03:50 pm »
Only for detail views.
