The project at work is moving along and so far we're all pleased with it. The next phase will be to jump to one of the layout tabs, which will already be formatted and have the title block on it for 11 x 17 paper. Eventually we will want to use 17 x 22 paper.
I would like to create code which will jump to Layout Tab 1, create a viewport, set the scale to say 1" = 1'-0", and then position the objects that the code created in model space centered or to at least some desired view position in the viewport. Oh, yes, I guess after that I should lock the viewport. As I speak through this it sounds like it might be easier to manually create the viewport, set the scale and view to the model space area. The objects created in model space are created by VLISP code and are the same three orthographic views of the product, the size of course will change, but the scale of 1"=1'-0" should allow them to fit comfortably in the viewport on 11 x 17 or 17 x 22 paper.
Just a few pointers should help me get off in the right direction on this.
