Author Topic: acaddoc and S::STARTUP  (Read 14558 times)
zride91
« on: January 31, 2012, 02:04:19 PM »
I've gone through multiple references, and they all make this seem so easy...
I am re-doing my acaddoc.lsp because I just found out it has not been running correctly because I did not include the S::STARTUP function
It appears that lines 2-7 work OK, but I can not tell if the items in the S::STARTUP are working.  The AutoCAD output seem to throw all the commands into one line, and the startup.scr that should be run in line 14 is not running.
Below is the acaddoc.lsp so far:
  1. ;;acaddoc.lsp to run with every file opened in AutoCAD Civil 3D
  2. (autoload "LaunchGrading.lsp" '("LaunchGrading")) ;;load lisp for toolpalette
  3. (autoload "LaunchUtility.lsp" '("LaunchUtility")) ;;load lisp for toolpalette
  4. (autoload "LaunchDS.lsp" '("LaunchDS")) ;;load lisp for toolpalette
  5. (load "disablenavcube.lsp" "disablenavcube FAILED to load") ;;loads lisp to disable viewcube in 2D display styles
  6. (setvar "layereval" 0) ;;turns off evaluation for unreconciled layers
  7. (setvar "proxygraphics" 1) ;;saves proxy image with drawing
  8. (defun-q BAstartupLD ( / userpref userpref1)
  9.         (command "._purge" "r" "*" "_n") ;;purge regapps
  10.         (command "-scalelistedit" "_r" "_y" "_e");;reset scale list
  11.         (command "._AeccConvertVBARulesToDotNet" "_y") ;;converts VBA pipe networks and structures to .NET
  12.         (c:disablenavcube) ;;runs lisp to disable viewcube in 2D display styles
  13.         (setq userpref (strcat (getvar "ROAMABLEROOTPREFIX") "SUPPORT\\")) ;;defines userpref variable for use in next line
  14.         (if (setq userpref1 (findfile (strcat userpref "Startup.scr")))(command "_.script" (strcat userpref "Startup.scr"))) ;;if found, will run user startup script
  15.         (princ)
  16.         )
  17. (setq S::STARTUP (append S::STARTUP BAstartupLD))
  18. ;;;acaddoc.lsp end
  19.
Below is the simple script I have as startup.scr just to see if it works (it should just draw a circle, which it is not):
_.circle 0,0,0 5
Below is the output I get in AutoCAD when opening a new file, which is concerning:
Regenerating model.
AutoCAD menu utilities loaded.
AutoCAD menu utilities loaded.._purge r * _n -scalelistedit _r _y _e
._AeccConvertVBARulesToDotNet _y _.script
C:\Users\dwahl\AppData\Roaming\Autodesk\C3D 2011\enu\SUPPORT\Startup.scr
When the script is run manually it runs fine.  As shown above, it appears to be loading the script OK, but it doesn't actually produce the circle.
Any suggestions??
Thank you!
Re: acaddoc and S::STARTUP
« Reply #1 on: January 31, 2012, 03:22:11 PM »
Make sure you have only one acaddoc.lsp file in your system.
AND there is only one Startup.scr
« Last Edit: January 31, 2012, 03:25:32 PM by CAB »
zride91
« Reply #2 on: January 31, 2012, 03:48:59 PM »
Thanks CAB.  The script is being called with full file path, there is only one startup.scr in that location being called, it's all verified in the AutoCAD output.  I have multiple acaddoc.lsp files on our network (one for each AutoCAD version we use (Civil 3D, AutoCAD, and MEP)).  The 2nd support path in AutoCAD is pointing to the appropriate acaddoc.lsp file (there are no acaddoc.lsp file in 1st path).  When I modify the acaddoc.lsp file, the output in autoCAD changes accordingly, which would indicate things are pointing to the right files I think.  It just seems AutoCAD isn't treating the lines in the S::STARTUP function as individual commands.  Would AutoCAD normally throw everything together in the output as I showed above?  I feel like I'm just missing a space or extra line break or something.  I've tried all sorts of things, just couldn't get the circle to come in...  the navcube goes away so I know the acaddoc.lsp is working at least through line 5 and the variable set also verify that things are OK up to the S::STARTUP function.  I've tried simplifying line 14 to just:
  1. (command "_.script" (strcat userpref "Startup.scr"))
I get same results.
BlackBox
« Reply #3 on: January 31, 2012, 04:07:05 PM »
I'm not sure what you have within your Script file, but consider temporarily renaming it, and create a new (with original name), and put something simple to confirm the Script is in fact loading/executing properly:
(princ "\n** Script is working normally ** ")
This will allow you to rule in/out if the Script is the source of your problem or not.
zride91
« Reply #4 on: January 31, 2012, 04:12:20 PM »
RenderMan, thank you.  I do have the script somethign very simple just to verify it works:
_.circle 0,0,0 5
That's all that is in the file.  The script works fine when run manually, I get a circle.  I do not get a circle automatically when opening a file.
I can try more specifically with the line of code that you provided, but I believe it's actually MORE complicated that what I already have :)
zride91
« Reply #5 on: January 31, 2012, 04:23:56 PM »
Yeah, it's still not loading the script, I tried as suggested.  New script file with new name with the line you provided.
Below is the updated acaddoc.lsp:
  8. (defun-q BAstartupLD ( / scrloc scrloc1)
  13.         (setq scrloc (strcat (getvar "ROAMABLEROOTPREFIX") "SUPPORT\\")) ;;defines scrloc variable for use in next line
  14.         (if (setq scrloc1 (findfile (strcat scrloc "TESTSCRIPT.scr")))(command "_.script" (strcat scrloc "TESTSCRIPT.scr"))) ;;if found, will run user startup script
  15.         (princ)
  16.         )
  19.
Below is AutoCAD output when first launching (it's still trying to load AutoCAD menus after running the S::STARTUP function):
Loading AEC Base...
Loading AEC Base Extended...
Loading AEC Base UI...
Loading AEC Project Base...
Loading AEC Base GUI...
Loading AEC Schedule Data...
Loading AEC Project UI...
Loading AEC Utilities...
Customization file loaded successfully. Customization Group: BA_CUSTOM
Customization file loaded successfully. Customization Group: CIVIL
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: TOOLBASEDRIBBON
Customization file loaded successfully. Customization Group: TASKBASEDRIBBON
Customization file loaded successfully. Customization Group: EXPRESS
Loading AECC Base...
Initializing....
There are no valid MS Jet providers installed......Done.
Loading AECC Land...
Loading AECC Subentity Selection...
Loading Modeler DLLs.
Loading AECC Pipe Part...
Loading AECC QTO......
Loading AECC Pipe Network...
Loading AECC Roadway...
Loading AECC Survey...
Loading AEC Schedule...
Loading AECC Plan Production...
Loading AECC Building Site...
Loading AECC Point Cloud...
Regenerating model.
*Cancel*
Loading AECC Hydrology...
Loading AECC Base UI...
Loading AECC Event Viewer...
Loading AECC Land UI...
Loading AECC QTO UI...
Loading AECC Pipe Network UI...
Loading AECC Roadway UI...
Loading AECC Survey UI...
Loading AECC Plan Production UI...
Loading AECC Publish UI...
Loading AECC AeccUiHydrology...
Loading AECC Mapcheck...
Loading AECC Mapcheck UI...
Loading AECC Building Site UI...
Loading AECC Point Cloud UI...
Loading AECC Management UI...
Loading AECC Model UI...
Loading AECC Land Manager Items...
Loading AECC Pipe Network Manager Items...
Loading AECC Roadway Manager Items...
Loading AECC Survey Manager Items...
Loading AECC Plan Production Manager Items...
Loading AECC Building Site Manager Items...
Loading AECC Point Cloud Manager Items...
_.filedia
1
_.pickfirst
1
_.proxynotice
0
_.proxyshow
1
_.backgroundplot
0
_.attdia
1
_.attreq
1
r
_n
-scalelistedit
_r
_y
_e
_y
_.script
C:\Users\dwahl\AppData\Roaming\Autodesk\C3D 2011\enu\SUPPORT\TESTSCRIPT.scr
AutoCAD menu utilities loaded.*Cancel*
Command: _RIBBON
Command: COMMANDLINE
Command: TOOLPALETTES
Command: Toolspace
Command:
Below is the AutoCAD output when opening a new file:
Regenerating model.
« Last Edit: January 31, 2012, 04:27:38 PM by zride91 »
« Reply #6 on: January 31, 2012, 05:12:52 PM »
You may want to try this:
and if you catch the error then try to catch each command cal to get the offender.
(defun-q BAstartupLD ( / scrloc scrloc1 err)
   (setq err (vl-catch-all-apply
    '(lambda ()
(if (vl-catch-all-error-p err) ; yes, error
   (princ (strcat "\n" (vl-catch-all-error-message err)))
zride91
« Reply #7 on: February 01, 2012, 04:45:03 PM »
Thank you CAB.
I ran this as my acaddoc, and I am getting the same results, no more, or no less.
I did open VLIDe and opened my acaddoc while opening a new file in AutoCAD, and I was presented with the following Question:
assignment to protected symbol: C:AI_MOLC Enter break loop?
« Reply #8 on: February 01, 2012, 05:22:39 PM »
http://www.theswamp.org/index.php?topic=16779
zride91
« Reply #9 on: February 02, 2012, 08:28:25 AM »
Thank you Lee Mac.  Glad this has nothing to do with the lisp.
TimSpangler
  • CAD Naked!!
« Reply #10 on: February 02, 2012, 12:25:02 PM »
We use something like this:
  8. (defun  S::STARTUP ( / scrloc scrloc1)
  15.         (princ)
  16.         )
  17. ;;;acaddoc.lsp end
  18.
ACA 2015 - Windows 7 Pro
zride91
« Reply #11 on: February 06, 2012, 12:31:03 PM »
Hi Tim,
Does your version work OK for you?
I'm just trying to set some corprate wide items, then run a script if it exists that the user can edit for user specific items if they want to do anythign of the such.
Thanks,
Dave
GDF
« Reply #12 on: February 06, 2012, 02:13:31 PM »
FYI     This is what I use:
;;; Following is a list of AutoCAD, Express Tools, and user-defined files in
;;; the order they are loaded when you first start the program. Go to AutoCAD
;;; Help and search for "support file loading" (including quotes) and the
;;; top result is "Order of support file loading" which nets the following:
;;;      <File For:>       <Use By:>
;;;      acad2000.lsp       AutoCAD
;;;      acad.rx          User
;;;      acad.lsp       User
;;;      acad2000doc.lsp       AutoCAD
;;;      acetutil.fas       Express Tools
;;;      acaddoc.lsp       User
;;;      mymenu.mnc       User
;;;      mymenu.mnl       User
;;;      acad.mnc       AutoCAD
;;;      acad.mnl       AutoCAD
;;;      acetmain.mnc       Express Tools
;;;      acetmain.mnl       Express Tools
;;;      s::startup       User
;;; Note: If the user-defined function S::STARTUP is included in the acad.lsp or
;;; acaddoc.lsp file or a MNL file, the function is called when you enter a new
;;; drawing or open an existing drawing. Thus, you can include a definition of
;;; S::STARTUP in the LISP startup file to perform any setup operations. For more
;;; information about the s::startup function, refer to the Customization Guide.
;;; It should be noted that Autodesk's website is misleading about the load order.
;;; The menus load in the order they were initially loaded in, and *not* always
;;; the user menu first. The only way the user menu loads first is if all menus
;;; were removed and the user's menu was loaded first, then the other menus
;;; subsequently. In most cases people tend to leave Acad's menu there, then
;;; Express Tools (if installed), and then finally the user's menu.
;;; This can be verified by watching the menu load prompts:
;;; AutoCAD menu utilities loaded.
;;; Key files to needed to run this program:
;;; (1.) The "ACAD.lsp" file sets the path for the arch program along with the saved autocad
;;;     environment settings for a clean restore to generic autocad when the arch program
;;;     is unloaded. This is the only file that must be located at each workstation within
;;;     the autocad support directory. It only loads at AutoCAD startup.
;;; (2.) The "ACADDOC.lsp" loads the "ARCH_INITIALIZE.fas" file.
;;; (3.) The "ARCH_INITIALIZE.fas" initialize the setup.
;;; (4.) Custom settings are controled by the "custom_xxx.lsp" file.
;;; (5.) The "ARCH.mnc" loads the "ARCH.mnl" file automatically which contains many
;;;     misc functions required to operate this program.
;;; (6.) The "ARCH_SUBROUTINES.fas" contains all of the subfunctions.
;;; (7.) All bitmaps for the toolbars are compiled in the "ARCH.dll" which is loaded
;;;     automatically.
;;; (8.) The "ARCH.dcl" file must be located in the acad support file search path
;;;     it contains all of the dialog box widgets for the arch program.
;;;     @include "..\\ARCH.dcl"
;;; General Rule is to NOT edit the acad200Xdoc.lsp file because it is an Autocad file
;;; that CAN and WILL be replaced if you install patches. I would suggest using the
;;; acaddoc.lsp for the code. Following is a list of AutoCAD, Express Tools, and
;;; user-defined files in the order they are loaded when you first start the program.
;;; File         For use by:
;;; acad200X.lsp AutoCAD
;;; acad.rx         User
;;; acad.lsp User
;;; acad200Xdoc.lsp AutoCAD
;;; mymenu.mnc User
;;; mymenu.mnl User
;;; s::startup User
;;; To make sure you are pulling the correct acaddoc.lsp copy and paste the following
;;; line to the command line (findfile "acaddoc.lsp") You should get the path returned
;;; and if it is not where you think the file is installed you have more than one file.
zride91
« Reply #13 on: February 06, 2012, 02:31:22 PM »
I don't know...
Logically it all seems to make sense.
I did read this in the Customization Guide:
NoteVBA and AutoLISP® scripts that run at startup should check for whether the AutoCAD process is visible or invisible. If the process is invisible, the script should not execute, because the process may be performing background plotting or publishing operations. To check for whether the AutoCAD process is visible or invisible, you can use the Visible property of the Application object in the AutoCAD Object Model.
I don't really understand it, but the rest of my afternoon will hopefully involve getting more info to this as it sounds like a possibility of what is going on.
Thanks for all resopnses so far.
BlackBox
« Reply #14 on: February 06, 2012, 04:54:23 PM »
  1.     ;; <-- Load/run your script
  2.  )
  3.
« Last Edit: February 06, 2012, 04:57:55 PM by RenderMan »
