Author Topic: Kung fu grips  (Read 5674 times)
McRojo the Irishman
Kung fu grips
« on: December 09, 2003, 06:06:03 PM »
Hey Kiddies,
Is there a way to add a midpoint grip (or have lines automatically divided into N segments) without using pedit?  Say... setting a variable to automatically divide...
daron
Kung fu grips
« Reply #1 on: December 09, 2003, 06:17:29 PM »
break select @. That'll break your lines where you select them.
McRojo the Irishman
Kung fu grips
« Reply #2 on: December 09, 2003, 06:31:35 PM »
Thanks, Daron, but breaking the line is not what I want to do.  I only want a polyline (I should have specified) to act like a line.  When you draw a single line, it has a midpoint grip.  When you draw a single polyline, all you have are two endpoints.  I would like to draw a closed polyline (rectangle) and have the polylines be editable either by midpoint or dividing (by variable) the sides of the rectangle into sections.
Kung fu grips
« Reply #3 on: December 09, 2003, 08:24:44 PM »
Interesting concept....I did a program once to divide a polyline into twice as many segments, then undivide it again...let me see if I can find it..
Kung fu grips
« Reply #4 on: December 09, 2003, 09:19:20 PM »
Sorry.. the proggie was a no go.. it must have been lost in my crash...
McRojo the Irishman
Kung fu grips
« Reply #5 on: December 10, 2003, 11:57:36 AM »
I was thinking about this last night and realized I left out one little bit.
The midpoint grip of a line moves the entire line.  It would be nice if the midpoint of the (p)line  acted as a hinge, so to speak.  I have a program that will allow me to stretch an existing spline into a new shape while keeping the length of the spline the same.  That's the closest thing I have.
I'm going to be teaching a handful of students at an academy for foster kids who didn't make it through the system.  I'd like to be able to start with a square and, by moving grips, change the shape of the square.  It's a visual thing I think might keep an attention level...
Kung fu grips
« Reply #6 on: December 10, 2003, 12:02:23 PM »
Kinda like what you can do with a viewport in Pspace?
McRojo the Irishman
Kung fu grips
« Reply #7 on: December 10, 2003, 12:44:22 PM »
Kinda like exactly, Mark.  Sounds like part of the routine would be found in the VP routine, part pedit (inserting a new grip), and part divide.
Fuccaro
Kung fu grips
« Reply #8 on: January 09, 2004, 07:15:25 AM »
Quote from: McRojo the Irishman
For sure you know this, but please let me repeat for the beginners browsing this forum:
Click the rectangle to select it. Hold the shift key and click two (or more) grips. All the selected grips are red. Release the shift and click a red grip point. Move the mouse and all the selected points will follow you. Click the final position.
This is the way I resize my rectangles...
Hangman
An answer ... Sorta
« Reply #9 on: January 09, 2004, 05:25:24 PM »
Here's what I end up doing, ...
I use two lisp routines here.   The first is crack, then specify a point that I want to crack the pline.  In this case, midpoint.   IF the pline is closed, it mearly opens the pline with the crack but you still have a pline.  (Much like a closed pline rectangle).   You can edit it and close if you wish.   IF the pline is open and I crack it, it breaks the pline into two pieces.  I then use the second lisp file, pljoin and connect the two together to have one closed pline.   I then have a vertex or grip centered on the pline.
I came across a lisp file once that created a vertex anywhere you specify on a pline without breaking or cracking it, but I'd hardly ever use it so I passed it by.   Can't remember just where I saw it at now.   :?
