Author Topic: Copy Database Object fail  (Read 1991 times)
vario
« on: January 27, 2012, 01:24:56 AM »
Hi!
I have an opened drawing and i would like to modify it and save it as a new drawing.
this process will be repeated for serveral times.
for example, modify the current drawing, delete layouts, add objects and so on. Save it to a new file and repeat the process.
delete other layouts or create other objects and save it to a new file.
i tried to export each layout in a new drawing but this process only works for the first one i export.
the other files are all damaged...
i think the copy process keeps the reference to the current database and if i want to export another layout which was deleted in the process before the new drawing is damaged...
is there a way to copy the current database several times to modify it without damaging?
Re: Copy Database Object fail
« Reply #1 on: January 27, 2012, 03:00:58 AM »
I think you're looking for SaveAS
public void SaveAs(string fileName, DwgVersion version);
Declaring Type: Autodesk.AutoCAD.DatabaseServices.Database
Assembly: Acdbmgd, Version=18.2.0.0
vario
« Reply #2 on: January 27, 2012, 05:03:54 AM »
i know the function, but the problem is, if i modify the drawing several times and save it between the operations the first one is correct, the following drawings are corrupt.
« Reply #3 on: January 27, 2012, 06:16:12 AM »
Why and how are the drawings corrupt.
Perhaps you should show us the code.
