Author Topic: Block Attribute (null) value  (Read 3098 times)
V-Man
« on: January 26, 2012, 04:24:03 PM »
I need to search for a particular block name and once found check to see if the attribute is null. If so, I want to delete the block(s) for all instances in the drawing. If the attribute is "filled" in with a value then leave those blocks alone. Any simple code out there to accomplish?
Thnx.
alanjt
  • Standby for witty remark...
Re: Block Attribute (null) value
« Reply #1 on: January 26, 2012, 04:32:17 PM »
Quick and untested...
(defun _EraseBlockReferencesWithNullAttributeValue (blockname attributetag / ss i e)
  (if (setq ss (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 blockname))))
    (repeat (setq i (sslength ss))
        (vl-some
          (function (lambda (a)
                      (and (eq (strcase (vla-get-tagstring a)) (strcase attributetag))
                           (eq (vla-get-textstring a) "")
          (vlax-invoke (vlax-ename->vla-object (setq e (ssname ss (setq i (1- i))))) 'GetAttributes)
         (entdel e)
Dropbox
« Reply #2 on: January 26, 2012, 04:36:19 PM »
Does that include inserts where one insert has a null attribute but another of the same name does not?
« Reply #3 on: January 26, 2012, 04:43:24 PM »
[quote author=alanjt link=topic=40781.msg460478#msg460478 date=1327613537]
[/quote]
Nice  8-)
V-Man
« Reply #4 on: January 26, 2012, 04:52:42 PM »
Yes
irneb
« Reply #5 on: January 27, 2012, 12:46:46 AM »
Pure AutoLisp (no VisualLisp calls):
(defun _EraseBlockReferencesWithNullAttributeValue_A (blockname attributetag / ss n en an ad ToErase)
      (setq n (sslength ss))
      (while (> (setq n (1- n)) -1)
        (setq en      (ssname ss n)
              ToErase nil
              ad      (entget (setq an (entnext en)))
        (while (and (not ToErase) (eq (cdr (assoc 0 ad) "ATTRIB")))
          (setq ToErase (and (eq (cdr (assoc 2 ad)) attributetag) (eq (cdr (assoc 1 ad)) ""))
                ad      (entget (setq an (entnext an)))
        (if ToErase (entdel en))
Also "quick & untested".  :|
V-Man
« Reply #6 on: January 27, 2012, 07:34:03 AM »
ok, how do I call it?
« Reply #7 on: January 27, 2012, 08:01:00 AM »
1 888 THE SWAMP
V-Man
« Reply #8 on: January 27, 2012, 10:24:16 AM »
        (vl-some
         (entdel e)
Thanks, This works great!
irneb
« Reply #9 on: January 30, 2012, 12:34:32 AM »
Same way as you do with Alan's code, the function name simply has a _A suffix to differentiate it from Alan's.
1 888 THE SWAMP
Is that true? I didn't know there was a hotline!  :lmao:
Pad
« Reply #10 on: February 08, 2012, 01:31:43 PM »
Nice lisp
I've been trying to make a couple of edits, so that instead of erasing the selection set it instead moves them to a defined layer.
The first bit was easy, the second bit is easy as long as the layer exists in the drawing.  So I have been trying to add code to check existence and make the layer if necessary but have ended up with a syntax error.
the first bit is this:
  1. ;         (entdel e)
  2.     (command  "_.CHPROP" e "" "_LA" "Clashing-Null" "")
and this is the code i have been trying to integrate:
  1. (if (not (tblsearch "LAYER" "CLASHING-Null")) (command "LAYER" "N" "CLASHING-Null" ""))
  2.
  3.     (command "layer" "F" "CLASHING_LEVELS" ^C)
  4.
  5.     (command ".-layer" "c" "6" "CLASHING_LEVELS" "")
could some one please show me the correct place to put this code?
Also whilst I'm at it, it would be great is the selection set would filter out any blocks which are already on any layers  prefixed with 'clashing-' beforehand.
P
« Last Edit: February 08, 2012, 01:37:00 PM by Pad »
irneb
« Reply #11 on: February 09, 2012, 06:49:47 AM »
You mean like this?
(defun _EraseBlockReferencesWithNullAttributeValue_A (blockname attributetag / ss n en ed an ad ToErase)
  (if (not (tblsearch "LAYER" "CLASHING-Null"))    (command "LAYER" "N" "CLASHING-Null" "")  )  (command "layer" "F" "CLASHING_LEVELS" ^C)  (command ".-layer" "c" "6" "CLASHING_LEVELS" "")
                      (list '(0 . "INSERT") '(66 . 1) (cons 2 blockname) '(8 . "~CLASHING-*"))
              ed (entget en)
              ToErase nil
        (while (and (not ToErase) (eq (cdr (assoc 0 ad)) "ATTRIB"))
          (setq ToErase (and (eq (cdr (assoc 2 ad)) attributetag) (wcmatch (cdr (assoc 1 ad)) ""))
        (if ToErase
          ;; (entdel en)
          (entmod (subst '(8 . "CLASHING-Null") (assoc 8 ed) ed))
irneb
« Reply #12 on: February 09, 2012, 06:58:54 AM »
Or if you prefer alan's VL code, here's a slight optimization of his as well as including your changes:
(defun _EraseBlockReferencesWithNullAttributeValue (blockname attributetag / ss)
  (setq blockname    (strcase blockname)
        attributetag (strcase attributetag)
  (if (and (ssget "_X"
                  (list '(0 . "INSERT") '(66 . 1) (cons 2 blockname) '(8 . "~[Cc][Ll][Aa][Ss][Hh][Ii][Nn][Gg]-*"))
           (setq ss (vla-get-ActiveSelectionSet (vla-get-ActiveDocument (vlax-get-acad-object))))
      (vlax-for e ss
        (if (vl-some (function (lambda (a)
                                 (and (eq (strcase (vla-get-TagString a)) attributetag)
                                      (eq (vla-get-TextString a) "")
          (vla-put-Layer e "CLASHING-Null")
      (vla-Delete ss)
Pad
« Reply #13 on: February 10, 2012, 06:01:58 AM »
thanks Irneb.  Thats brilliant.
Your version works perfectly but your version of Alan's errors:
Command: (_EraseBlockReferencesWithNullAttributeValue "PD" "LEVEL")
bad argument type: numberp: nil
Command: (_EraseBlockReferencesWithNullAttributeValue_A "PD" "LEVEL")
nil
I don't know why.
Thanks!
