I have gotten to a point where I am pleased with the functions of the following code, however, there seems to be some issues with exiting AutoCAD after running the routine. I presume that this is tied to the LDD portion of code (although I could very well be wrong). Can anyone please read through (possibly even test) the code and give me any feedback you may have on why I am crashing AutoCAD.
A couple of things:
-For testing purposes the style of block to be used is simply an attribute (i.e. "Elev") with a rectangle around it, this must be pre-defined in the drawing
-There must be a Surface/TIN in the LDD project (set current)
-When prompted for Centerline, select any location within the Surface
(defun C:Addsurf (/ acadObj1 aecApp1 aecProj aecSurfs aecSurf aecUtil pt# e-n selev newelev acadObj2 aecApp2 aecDoc PrefDoc Hscale xsf ysf rta typ ctyp ipt atr emsg elevdif elevc)
(setq acadObj2 (vlax-get-acad-object))
(setq aecApp2 (vla-getinterfaceobject acadObj2 "Aecc.Application"))
(setq aecDoc (vlax-get aecApp2 "ActiveDocument"))
(setq PrefDoc (vlax-get aecDoc "preferences"))
(setq Hscale (vlax-get PrefDoc "DatabaseScale"))
(if (= XSF nil) (setq XSF hscale))
(if (= YSF nil) (setq YSF xsf))
(if (= RTA nil) (setq RTA 0.0))
(if Addsurf:BLK
(setq TYP (strcat "\nBlock to Insert: <" Addsurf:BLK "> "))
(setq CTYP (getstring TYP))
(if (= CTYP "") ;; If user presses Enter
(setq Addsurf:BLK Addsurf:BLK) ;; leave the block the same as it was
(setq Addsurf:BLK CTYP) ;; No, a new value was entered, use new value
(setq Addsurf:BLK (getstring "\nBlock to Insert: "))
(if chelev
(setq chelev (rtos chelev))
(setq elevdif (strcat "\nElevation Change: <" chelev "> "))
(setq chelev (atof
(if (= (setq elevc (getstring elevdif)) "") chelev elevc
(setq chelev (atof (getstring "\nElevation Change: ")))
(setq acadObj1 (vlax-get-acad-object)
aecApp1 (vla-getinterfaceobject acadObj1 "Aecc.Application")
aecProj (vlax-get aecApp1 "Activeproject")
aecSurfs (vlax-get aecProj "Surfaces")
aecSurf (vlax-get aecSurfs "Currentsurface")
aecUtil (vlax-get (vlax-get aecApp1 "activedocument") "Utility")
(if (and (= aecSurf "")
(> (vlax-get aecSurfs "count") 0)
(setq aecSurf (vlax-get (vlax-invoke aecSurfs "item" 0) "name"))
) ;; End if
(if (= aecSurf "")
(princ "\nNo surfaces defined, try again after creating a surface.")
(setq aecSurf (vlax-invoke aecSurfs "item" aecSurf))
(while (setq pt# (getpoint "\nPoint along centerline: "))
(setq e-n (vlax-invoke aecutil "xytoeastnorth" pt#))
(setq selev (vlax-invoke aecSurf "getelevation" (car e-n) (cadr e-n)))
;; Add/Subtract Elevation
(setq newelev (+ selev chelev))
(setq IPT (getpoint "\nInsertion point: "))
(setq ATR (rtos newelev 2 2))
(command "INSERT" Addsurf:BLK IPT XSF YSF RTA ATR)
(setq objList (reverse '(acadObj1 aecApp1 aecProj aecSurfs aecSurf aecUtil)))
(setq emsg (vl-catch-all-apply 'vlax-release-object 'objList))
(vl-catch-all-error-message emsg)
