Author Topic: Contractor using Revit  (Read 7388 times)
MexicanCustard
« on: January 18, 2012, 06:42:39 PM »
We're a mechanical contractor using AutoCAD with a 3rd party addon to run mechanical piping and plumbing.  Our system is for 3D coordination and continues on through fabrication. We're a prefabrication heavy contractor.  We've been using this system and creating utilities for this system for the last 10 years so there is a lot of customization(Lisp and .NET) that has to migrate in whatever direction we go.  We've come to a point where the new software and technology far exceeds our current software's ability.  We've been on a path to migrate to AutoCAD MEP over the last 4 months but are starting to get pressure to move towards Revit MEP instead.  So my question is, what are the differences in AutoCAD MEP and Revit MEP as far as a contractor is concerned?  I understand the differences in the core products. I'm more interested in the differences in abilities like drawing pipe sleeves, drawing hangers, and creating BOMs. I'm also interested in anyone who is taking a model from Revit to fabrication.
Strykface, I hope you happen upon this since I know your one of those guys that has been in both worlds of MEP and you also work on the contractor side. I would really appreciate any opinion you might have on this subject.  Thanks in advance to anyone reading this.
StykFacE
Re: Contractor using Revit
« Reply #1 on: January 18, 2012, 09:08:38 PM »
Thanks for the personal reference, much appreciated. PS: Might want to print this out and read on the crapper.
Now that I'm well into Revit MEP I can surely give you a much more educated response, although only with the two programs themselves, not on the programming side of either.
It will be hard to justify using Revit MEP as a contractor for a few reasons:
1. AutoCAD MEP comes with a ton of ANSI standard catalogs of fittings for pipe. There's not much missing right out of the box. Revit MEP has jack sh*t. You can download a lot of fitting Families off the internet but their way of designing a family might not fit your own mold, and tag all their own brand names in the Families that you can't get rid of. Not too important but still. Anyways, you have a looooong road ahead of you if you're a fabrication heavy contractor because the content simply doesn't exist OOTB, and it's scarce on the web.
2. Revit MEP has it's own way of displaying things. It takes more time to create little details, and in AutoCAD MEP where you need to make a very detailed ISO-Views and quickly make edits, you can by using the ConvertTo3DSolids command and then using FLATSHOT. Bam, perfectly flattened ISO view that's ready to be edited freely using standard 2D tools. Well, you don't really have that freedom in Revit because it's not a 'drafting' program. You'll find that you simply lock a 3D view, and use Detail tools to "whip up" something that resembles a specific detail for the fab guys. This is technically a good thing because everything's parametric in Revit MEP so nothing is broken.
3. The learning curve. Basically, it'll become a vertical climb. You and whoever else will despise it on every level in the beginning as most people do. The reason I say this is because it's important to know that the AutoCAD vertical product platform (eg: ACA, AMEP, etc) was taken from the Revit platform. Think about it, Project Navigator, Views, Parametric Constraints for AEC Objects, Display/Style Manager, System and Object based entities instead of lines circles and squares on Layers, Annotative Scaling, Scheduling, etc. The list goes on. Revit is definitely built for the engineer in mind, but recently it's shown vast improvements where a mechanical contractor could easily adopt it, if they are willing to accept Revit for what it is and give it a shot. Then you begin to see things clearly, understanding that Revit really is intuitive and you wished AutoCAD did so many things like Revit.
Now here are the things that Revit is more than capable of from what I can see, which means now we're getting into the area where a mechanical contractor would benefit from. Granted, I'm not meaning right OOTB, It'll take some major overhaul but once you get things in gear, the BOM possibilities are endless, since everything can be scheduled in Revit and with ease, as long as the Families are well thought out.
Pipe sleeves, hangers, etc... I've seen things like that be done by a friend of mine who's a Revit guru, and some of the things he's created are nothing short of phenomenal and I'm dead serious. He's created sleeves for mechanical steam piping for coordinating blockouts in the CMU walls from pipe penetrations, and scheduled them. He's created hangers for duct and pipe that constrain to the pipe, and constrained to the Revit Structure beams, and scheduled them. AutoCAD MEP can only dream of this level of informational connection. He's been on Revit since 1999 or whenever it came out, so his experience dates back to v1.0.
Another good selling point for a contractor use is the arrival of Revit Server. The last big job we did I was talking to the BIM Manager (Revit guru as well) for the G.C. and they just recently installed and setup Revit Server and they have it working pretty well. Basically, in short, this means instantaneous live coordination. If you're working in a 90MB Revit file and you move a six foot long 8" diameter duct over by two feet, it doesn't resend the 90MB file, it only sends the packet of information for that single piece of duct that changed when you sync with your Central model. This is something that I definitely see more G.C.'s adopting and quickly, since it's putting the coordination part of BIM where it truly needs to be. AutoCAD MEP can't and would never be able to have capabilities like this.
In conclusion of my new book I just wrote, I will say this: You will hate Revit at first being a mechanical contractor heavy into prefab. But stick with it... in fact, do what you can and export to AutoCAD MEP native AEC objects to finish up (I've heard Revit MEP 2012 can now export as native AutoCAD MEP objects, but don't hold me accountable since I've yet to actually try it). And if that doesn't work, see what you can do with an IFC Export to get it into AutoCAD MEP. It'll take a loooong time to get Revit where you'll want it and that's simply a choice you as a company will have to make. This is simply my own personal 7 years experience with both programs as used by a mechanical contractor. 7 years of AutoCAD MEP (ABS back then) and past 2 years of Revit.
Hope this helps some.  :kewl:
MexicanCustard
« Reply #2 on: January 19, 2012, 09:27:54 AM »
Thank you very much for that response.  I was hoping you would post with that much insight.  We've come to a very tough decision and we're trying to immerse ourselves in as much information as possible and this definitely will be included in that.  Thank you again for taking the time to respond.
StykFacE
« Reply #3 on: January 19, 2012, 09:43:40 AM »
No prob. I'll throw this out there: if your company is wanting some more info for any reason, I'll be happy to do a phone conversation with you or even if you wanted to conference with some higher ups at your company.
Also note that you can buy the Revit MEP Suite which gives you Revit MEP and AutoCAD MEP and the costs is only slightly higher than just having one of the two by themselves. That's how I initially got started which made it easy since I had options depending on the job, and in my downtime I had both programs to tinker with and learn.
