Author Topic: COPY MULTIPLE BLOCKS AND PLACE ON LINE (BY ORDER SELECTED)  (Read 4552 times)
Verticalmojo#2
« on: January 16, 2012, 04:41:41 PM »
Hello Swampers!!
Its been awhile since I posted here!
I'm trying to find a lisp routine that does the following.
1. select blocks
2. copy blocks
3. places blocks on a line (in order selected) * it would be nice if it places the block to its original form
Attached is a visual of what I am trying to do....
Ive been searching everywhere and I cant seem to find this simple routine... Can you guys help? I figured if its out there you guys would know where to find it if its not already here. Thanks in advance!
~Mario
alanjt
  • Standby for witty remark...
Re: COPY MULTIPLE BLOCKS AND PLACE ON LINE (BY ORDER SELECTED)
« Reply #1 on: January 16, 2012, 04:47:05 PM »
Search "CopyAlongCurve" and "SpaceAlongCurve" for several good examples.
Would you be copying selected blocks a specified distance or dividing them evenly along the selected curve?
Dropbox
Verticalmojo#2
« Reply #2 on: January 16, 2012, 04:53:33 PM »
separated 4' from base-point to base point...
Thanks for the info, I'm searching right now...
Verticalmojo#2
« Reply #3 on: January 16, 2012, 05:35:17 PM »
I have searched with the mentioned keywords but still not having any luck.
Anymore suggestions would greatly be appreciated.
« Reply #4 on: January 16, 2012, 06:11:42 PM »
This does not copy to a line but will place them in a row 48" apart.
;;Allows individual pick of blocks
(defun c:cb2 (/ b co p ss)
  (if (setq p (getpoint "\nPick a point to place block: "))
    (while (setq ss (ssget ":L:S" '((0 . "insert"))))
      (setq b (vlax-ename->vla-object (ssname ss 0)))
      (setq co (vlax-invoke b 'copy))
      (vlax-invoke co 'move (vlax-get co 'insertionpoint) p)
      (setq p (list (+ 48. (car p)) (cadr p) (caddr p)))
;;Pick multiple blocks at once
(defun c:cb (/ ss2lst e co p ss)
  (defun ss2lst (ss / e n out)
    (setq n -1)
    (if ss
      (while (setq e (ssname ss (setq n (1+ n)))) (setq out (cons (vlax-ename->vla-object e) out)))
  (if (and (setq ss (ss2lst (ssget ":L" '((0 . "insert")))))
    (foreach b ss
« Last Edit: January 17, 2012, 09:47:05 AM by ronjonp »
Verticalmojo#2
« Reply #5 on: January 16, 2012, 11:21:55 PM »
This is what I get.....
Select objects: 1 found, 2 total
Select objects:
Invalid complex object.
Command:
fixo
« Reply #6 on: January 17, 2012, 05:10:48 AM »
Found in my old library
(defun C:DCP(/ *error* ang ccl clr clt dist step istep dym dyp i n-divide next-divide-pt osm pag pal pmd pt1 pt2 ss stp)
  (defun *error*  (msg)   ; create standard error handler
          (command "._undo" "_end")
      (command)
      (cond ((not msg))   ; normal exit, no error
    ((member msg '("Function cancelled" "quit / exit abort"))) ; escape
    ((princ (strcat "\nError: " msg))   ; display fatal error
     (cond (*debug* (vl-bt)))))   ; if in debug mode, dump backtrace
      (setvar 'cmdecho 1)                        ; restore environments
(if osm
  (setvar 'osmode osm)
(if clr
  (setvar 'clayer clr)
(if ccl
  (setvar 'cecolor ccl)
(if clt
  (setvar 'celtype clt)
(if pal
  (setvar 'polarang pal)
(if pag
  (setvar 'polaraddang pag)
(if stp
  (setvar 'snaptype stp)
(if pmd
  (setvar 'polarmode pmd)
(if dym
  (setvar 'dynmode dym)
(if dyp
  (setvar 'dynprompt dyp)
  (command "._undo" "_begin")
  (setvar 'cmdecho 0)
  (setq dym (getvar 'dynmode))
  (setvar 'dynmode 3)
   (setq dyp (getvar 'dynprompt))
   (setvar 'dynprompt 1)
   (setq clr (getvar 'clayer))
  (setvar 'clayer "0")
   (setq ccl (getvar 'cecolor))
  (setvar 'cecolor "BYLAYER")
   (setq clt (getvar 'celtype))
  (setvar 'celtype "BYLAYER")
   (setq osm (getvar 'osmode))
   (setvar 'osmode 0)
  (setq pal (getvar 'polarang))
  (setvar 'polarang 45.0)
  (setq pag (getvar 'polaraddang))
  (setvar 'polaraddang "0;45;90;135;180;225;270;315")
  (setq stp (getvar 'snaptype))
  (setvar 'snaptype 1)
  (setq pmd (getvar "polarmode"))
  (setvar 'polarmode 6)
  (command "._ucs" "_w")
  (setq ss (ssadd))
(setq ss (ssget))
   (setq orig (getpoint "\nSpecify base point: "))
  (setq pt1 (getpoint "\nStart point: "))
  (setq pt2 (getpoint pt1 "\nEnd point: "))
  (setq dist (distance pt1 pt2))
  (setq ang (angle pt1 pt2))
  (setq num (getint "\nNumber of copies: "))
  (setq step (/ dist (1+ num)))
  (setq istep step)
  (setq  i 1)
  (while (<= i num)
    (setq inspt (polar pt1 ang istep))
  (command "._copybase" orig ss "")
  (command "._pasteclip" inspt)
    (setq istep (+ istep step))
    (setq i (1+ i))
    (*error* nil)
~'J'~
« Reply #7 on: January 17, 2012, 08:36:56 AM »
Another, quickly written:
  1. ;; Copy Blocks to Curve  -  Lee Mac  -  2012  -  www.lee-mac.com
  2. ;;
  3. ;; Prompts for a Curve Object to which blocks are to be copied and
  4. ;; a spacing for blocks along the curve, then continuously prompts
  5. ;; for selection of a block and copies the block to align with the
  6. ;; curve.
  7. ;;
  8. ;; Prompts will cease when either the user right-clicks / Enter, or
  9. ;; the curve is not long enough to fit another block with the
  10. ;; specified spacing.
  11. ;;
  12. ;; Blocks retain layer / linetype / lineweight etc properties, but
  13. ;; are set to 1:1 scale and rotated to align with the curve.
  14.
  15. (defun c:CopyBlocksToCurve
  16.
  17.     (
  18.         /
  19.         *error*
  20.         _SelectIf
  21.         _IsCurveObject
  22.         _MakeReadable
  23.
  24.         blk dis ent len msg obj pt1 spc
  25.     )
  26.
  27.     (defun *error* ( msg )
  28.         (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
  29.             (princ (strcat "\nError: " msg))
  30.         )
  31.         (princ)
  32.     )
  33.
  34.     (defun _SelectIf ( msg pred )
  35.         (
  36.             (lambda ( f / e )
  37.                 (while
  38.                     (progn (setvar 'ERRNO 0) (setq e (car (entsel msg)))
  39.                         (cond
  40.                             (   (= 7 (getvar 'ERRNO))
  41.                                 (princ "\nMissed, try again.")
  42.                             )
  43.                             (   (eq 'ENAME (type e))
  44.                                 (if (and f (null (f e)))
  45.                                     (princ "\nInvalid Object.")
  46.                                 )
  47.                             )
  48.                         )
  49.                     )
  50.                 )
  51.                 e
  52.             )
  53.             (eval pred)
  54.         )
  55.     )
  56.
  57.     (defun _IsCurveObject ( ent )
  58.         (null
  59.             (vl-catch-all-error-p
  60.                 (vl-catch-all-apply 'vlax-curve-getendparam (list ent))
  61.             )
  62.         )
  63.     )
  64.
  65.     (defun _MakeReadable ( a )
  66.         (
  67.             (lambda ( a )
  68.                 (if (and (< (/ pi 2.0) a) (<= a (/ (* 3.0 pi) 2.0)))
  69.                     (+ a pi)
  70.                     a
  71.                 )
  72.             )
  73.             (rem (+ a pi pi) (+ pi pi))
  74.         )
  75.     )
  76.
  77.     (if
  78.         (and
  79.             (setq ent (_SelectIf "\nSelect Object to Align Blocks to: " '_IsCurveObject))
  80.             (progn
  81.                 (setq len (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)))
  82.                 (while
  83.                     (and
  84.                         (setq spc (getdist (strcat "\nSpecify Block Spacing (less than " (rtos len 2 2) "): ")))
  85.                         (< len spc)
  86.                     )
  87.                     (princ "\nSpacing is greater than Object Length!")
  88.                 )
  89.                 spc
  90.             )
  91.             (setq dis 0.0)
  92.         )
  93.         (while
  94.             (and
  95.                 (setq pt1 (vlax-curve-getpointatdist ent dis))
  96.                 (princ
  97.                     (strcat
  98.                         "\n" (rtos len 2 2) " Length available for " (itoa (1+ (fix (/ len spc)))) " block(s)."
  99.                     )
  100.                 )
  101.                 (setq blk
  102.                     (_SelectIf "\nSelect Block <Exit>: "
  103.                        '(lambda ( x ) (eq "INSERT" (cdr (assoc 0 (entget x)))))
  104.                     )
  105.                 )
  106.             )
  107.             (setq obj (vla-copy (vlax-ename->vla-object blk)))
  108.             (vla-put-insertionpoint obj (vlax-3D-point pt1))
  109.             (foreach prop
  110.                '(
  111.                     (XEffectiveScaleFactor XScaleFactor)
  112.                     (YEffectiveScaleFactor YScaleFactor)
  113.                     (ZEffectiveScaleFactor ZScaleFactor)
  114.                 )
  115.                 (vlax-put-property obj
  116.                     (if (vlax-property-available-p obj (car prop) t)
  117.                         (car  prop)
  118.                         (cadr prop)
  119.                     )
  120.                     1.0
  121.                 )
  122.             )
  123.             (vla-put-rotation obj
  124.                 (_MakeReadable
  125.                     (angle '(0.0 0.0 0.0)
  126.                         (vlax-curve-getfirstderiv ent (vlax-curve-getparamatpoint ent pt1))
  127.                     )
  128.                 )
  129.             )
  130.             (setq dis (+ dis spc)
  131.                   len (- len spc)
  132.             )
  133.         )
  134.     )
  135.     (princ)
  136. )
« Reply #8 on: January 17, 2012, 09:23:50 AM »
Select objects:
Command:
Updated the code above. Give it a try ... or use Lee's solution  8-)
ribarm
  • Marko Ribar, architect
« Reply #9 on: January 17, 2012, 11:48:05 AM »
Doesn't A2012 have array by path command???
As far as I know it is the main feature of A2012...
M.R.
M.R. on Youtube
« Reply #10 on: January 17, 2012, 12:36:17 PM »
My guess is that the OP is trying to select the blocks within the building and then
automatically paste them on that line you see on the bottom outside the building.
 Actually you could sort by the attribute with the 3V1-n string. 8-)
Verticalmojo#2
« Reply #11 on: January 17, 2012, 12:37:30 PM »
thanks for all  the responses!
 I think that ronjonp's updated routine is pretty darn close to what I'm looking for. Only thing is the blocks that are being copied have been mirrored and/or rotated so they don't align as nicely as I would like to have it. Would that be a easy add to the routine?
CAB - thats correct...
« Reply #12 on: January 17, 2012, 12:53:44 PM »
Mine should align to the curve and set the scale to 1.0, resetting any mirroring.  :-)
Verticalmojo#2
« Reply #13 on: January 17, 2012, 01:09:50 PM »
I had trouble getting it to work before you mentioned that, but I tried it again and it works great! Thanks!
« Reply #14 on: January 17, 2012, 01:16:56 PM »
I see no problem with the code - glad you got it working  :-)
