I am curious if this is even possible, at this point it seems to be WAY over my head. I'm working with Revit Exports to AutoCAD, and I'm trying to use a script and lisps to clean the DWGs up after the export.
I just love how well Autodesk products work with other Autodesk products...
My problem is that my designers in Revit have all these sections cut all over the place that do not get referenced into a sheet, they are just used for working/design purposes. When we print the Revit sheets, there is an option in Revit to ignore printing the section marks that are not referenced into sheets, so it is not a big deal to just leave them (until you export to DWG).
Now in my exported AutoCAd files, I have all these section marks with hyphens in them, all over the place. Of course the hyphens are not attributes in the section marker block, they are MTEXT seperate from teh sectiom mark block.
Anyone think that there even could be a way through lisp to search the MODEL for the section blocks, and see if there is MTEXT with "---" AND MTEXT with "-" within the area of the circle part of the block, then if found delete that instance of the section block AND the "-" and "---", then go on searching the model for more??
Thank you
