Author Topic: dcl_ComboBox_AddList  (Read 4065 times)
topograph
  • Mosquito
« on: January 10, 2012, 08:06:34 AM »
Hello to all and happy New Year:)
I am OpenDCL rookie and OpenDCL Runtime [7.0.0.2] does not work the way I want :oops:
What is wrong in my code:
(setq lst (list "A" "B" "C"))
(dcl_ComboBox_AddList MyComboBox lst)
returns an empty ComboBox list (???)
(dcl_ComboBox_AddList MyComboBox (list "A" "B" "C"))
works OK.
Who is making a mistake, me or OpenDCL Runtime?
Re: dcl_ComboBox_AddList
« Reply #1 on: January 10, 2012, 02:56:16 PM »
Both should work.
I can't re-test at the moment
... can you post at the OpenDCL forum please ( perhaps post a small test code and .odcl to show the point)
topograph
  • Mosquito
« Reply #2 on: January 10, 2012, 06:03:18 PM »
Thanks Kerry.
I just posted at the OpenDCL forum with some attachments.
Sorry for my bad lisp/OpenDCL but, I want to learn ;)
