Author Topic: DCL2LSP  (Read 13065 times)
77077
Re: DCL2LSP
« Reply #15 on: November 08, 2014, 10:50:32 AM »
Here is your TestDialog.dcl example implemented into my version of TestDialog.lsp... Above and below lines are always the same and lines (write-line "..." fn) are obtained from my dcl2lsp.lsp... I've tested my TestDialog.lsp and it works (shows your *.dcl)...
M.R.
very nice ! marko
« Last Edit: November 09, 2014, 09:01:44 PM by 77077 »
d2010
Re: DCL2LSP
« Reply #16 on: November 12, 2014, 03:55:45 PM »
Here is my simple code, but vary powerful if you want to implement dcl content into lsp file... Of course, you have to edit main lsp with these lines :
You view  my source lisp,  :coolsmiley:or text files.................
You view  my gif  - image
77077
Re: DCL2LSP
« Reply #17 on: November 12, 2014, 09:21:58 PM »
The virus ??? load those vlx ,  Black screen , cad can't exit.
Re: DCL2LSP
« Reply #18 on: November 12, 2014, 09:35:18 PM »
Anyone else have problems with this attachment ??
I'm not prepared to try it, sorry.
If so, please send me a message urgently.
kruuger
Re: DCL2LSP
« Reply #19 on: November 13, 2014, 01:32:51 AM »
The virus :? load those vlx ,  Black screen , cad can't exit.
no. everything is fine. try on virtual machine.
program nicely display image in dcl.
maybe your pc is to slow.
kruuger
