Author Topic: Update fields in all layouts  (Read 1236 times)
scottcd
« on: January 06, 2012, 08:45:08 AM »
I have the following code:
(defun c:nuf ()
  (vlax-for layout (vla-get-Layouts
    (if (= (vla-get-ModelType layout) :vlax-false)
(command "updatefield" all "")
but not working - how can I get the fields on each layout to be updated ?
Thanks in advance
Scott
AutoCAD Dos R9 - 2018 and BricCAD 18.2
Tharwat
  • Hypersensitive
Re: Update fields in all layouts
« Reply #1 on: January 06, 2012, 08:59:03 AM »
This code worked for me ....  :-)
(defun c:TesT (/ spc ss)
  (setq spc (getvar 'ctab))
  (foreach x (layoutlist)
    (setvar 'ctab x)
    (if (setq ss (ssget "_x" (list '(0 . "MTEXT")(cons 410 x))))
      (command "_.updatefield" ss "")
  (setvar 'ctab spc)
« Last Edit: January 06, 2012, 09:27:01 AM by Tharwat »
scottcd
« Reply #2 on: January 06, 2012, 09:40:33 AM »
Thank you thats great
