Author Topic: Shortcode for 'm2p' ?  (Read 11478 times)
lamarn
« on: January 05, 2012, 09:59:49 AM »
Would it be possible to make a shortcut (one letter) for the snapfunction 'm2p' middle of two points?
I use it a lot and i like simple keyboard strokes.
Thanks anyway.
Hans
alanjt
  • Standby for witty remark...
Re: Shortcode for 'm2p' ?
« Reply #1 on: January 05, 2012, 10:35:40 AM »
Assign it to one of the F* keys or a ctrl+* in the CUI editor.
Dropbox
M-dub
« Reply #2 on: January 05, 2012, 10:44:39 AM »
Why not add it to your PGP file?
« Reply #3 on: January 05, 2012, 10:54:55 AM »
Not sure that would work for transparent commands, I may be wrong however.
alanjt
« Reply #4 on: January 05, 2012, 11:17:33 AM »
AFAIK you can't define osnap overrides in the pgp. They aren't treated the same. I used that to my advantage in this thread.
Dropbox
M-dub
« Reply #5 on: January 05, 2012, 11:37:00 AM »
I had two memories that got crossed... I was just plain wrong.
I think this old topic had something to do with that...
alanjt
« Reply #6 on: January 05, 2012, 11:44:21 AM »
Only cross the streams when Gozer is involved.
Dropbox
Hangman
« Reply #7 on: January 05, 2012, 06:04:08 PM »
I edit the CUI file and set the '2' key as the designation.
Then simply SHIFT + Right Click, hit 2 and you've got the snap.
Hangman  8)
BlackBox
« Reply #8 on: January 05, 2012, 06:22:59 PM »
Another option is *if* you have any macro programmable keys (found on devices like Logitech G13, etc. ), you can simply add a macro for "_m2p", "_nea", "_end", etc. as needed... then it's a single keystroke also without impacting OSNAPs.
stevej
« Reply #9 on: January 05, 2012, 09:41:45 PM »
I use M2P hundreds of times in a day, and I don't know about your version of Autocad, but in 2006 a SHIFT+Right Click or CTRL+Right Click brings up this menu, and it's right there. After years, it's still the quickest way for me to get at it.
Steve
« Reply #10 on: January 06, 2012, 10:37:47 AM »
Like Alan said ... I would assign it to an F key that is not used much  8-) One less click than the Shift right click menu.
Biscuits
« Reply #11 on: January 06, 2012, 11:56:03 AM »
I assigned this to my F1 key.
« Reply #12 on: January 06, 2012, 12:41:48 PM »
But F1 is help!  Oh yeah ... who needs that popping up when missing escape :)
cmwade77
« Reply #13 on: January 06, 2012, 12:48:05 PM »
I have a couple extra buttons on my mouse, I just assigned it to one of them.
M-dub
« Reply #14 on: January 06, 2012, 12:59:02 PM »
Ditto :)
