I am working on a routine that, at one point, goes into a Do loop and reacts to keystroke input via the GetAsyncKeystroke API. The routine looks at the arrow keys and a couple others and translates those keystrokes into activating flip and angle states of the dynamic block selected--giving the user and interactive tool for block manipulation.
Anyway, the issue I'm having is that when the loop is complete, all of the keystrokes pressed while in the loop come rushing into the command line. I've been very careful to choose keys for the routine which do not have a command or shortcut associated with them. However, the UP arrow key is the kicker. I would like to keep it in the routine because it's obvious when using the others. Plus, even if I don't use it, I'm sure users will still hit it while using the other arrow keys.
What I would like to be able to do, is prevent all of those keystrokes from going back into the command line when the sub is complete.
I've tried using the SetKeyboardState API after each keystroke to try to cover my tracks. But, it doesn't do anything. My guess is that there is some keystroke queue that needs to be cleared prior to exiting the sub. Does anyone know if it exists and, if so, how to clear it? If it doesn't exist, is there some Acad variable I can turn off? Is there a system variable, etc.....?
I've briefly looked at keystroke hooks, but they seem awfully involved and complicated and I'm not even sure if it will do what I want.
Any help?
Oh, and yes I know, I should quit using vba for .NET.....I know. Also, I have no interest in converting my code into lisp. I can use lisp to do some very basic tasks. I could use lisp to set a variable if need be, but I don't want to go "all out" with it.
Thanks in advance.
Here's a snippet of the code:
Do
U = GetAsyncKeyState(VK_UP)
D = GetAsyncKeyState(VK_DOWN)
L = GetAsyncKeyState(VK_LEFT)
R = GetAsyncKeyState(VK_RIGHT)
A = GetAsyncKeyState(VK_RCONTROL)
'Ret = GetAsyncKeyState(VK_RETURN)
'Space = GetAsyncKeyState(VK_SPACE)
S = GetAsyncKeyState(VK_RSHIFT)
If (Rot >= 0 And Rot <= 45) Or (Rot >= 135 And Rot <= 225) Or Rot >= 315 Then
If HasH And (U < 0 Or D < 0) Then
Set objDyn = DynProps(h)
If Hflip = 0 Then
objDyn.Value = 1
objRef.Update
objRef.Highlight True
Exit Do
Else
objDyn.Value = 0
objRef.Update
Exit Do
End If
ElseIf HasV And (R < 0 Or L < 0) Then
Set objDyn = DynProps(v)
If Vflip = 0 Then
objDyn.Value = 1
objRef.Update
Exit Do
Else
objDyn.Value = 0
objRef.Update
Exit Do
End If
ElseIf A < 0 And HasRot Then
Set objDyn = DynProps(t)
objDyn.Value = Rad - (¶ / 2)
objRef.Update
Exit Do
ElseIf S < 0 Then 'Ret < 0 Or Space < 0 Then
Done = True
Exit Do
End If
Else
If HasV And (U < 0 Or D < 0) Then
If Vflip = 0 Then
objDyn.Value = 1
objRef.Update
Exit Do
Else
objDyn.Value = 0
objRef.Update
Exit Do
End If
ElseIf HasH And (R < 0 Or L < 0) Then
If Hflip = 0 Then
objDyn.Value = 1
objRef.Update
Exit Do
Else
objDyn.Value = 0
objRef.Update
Exit Do
End If
objRef.Update
Exit Do
Done = True
Exit Do
End If
End If
LoopI can post more of the code, but I don't think what I'm looking for has much to do with what I already have.
