Author Topic: Copy and rotate (kopieren und drehen)  (Read 25568 times)
Hugo
« on: January 02, 2012, 05:05:20 AM »
Can I make it better
Thank you
Kann man das besser machen
Danke
(defun c:copydreh ()
        (setvar "cmdecho" 0)
  (while(setq el (car (entsel)))
        (setq el1 (entget el))
        (setq p1 (cdr (assoc 10 el1)))
        (command "_copy" (ssadd el) "" p1 pause)
        (setq en (entget(entlast)))
        (princ "\nPress [Tab] to Rotate Text <Accept>: ")
       (while (= 9 (cadr (grread nil 2)));;(while (= 9 (cadr (grread nil 2)))
          (setq rt(assoc 50 en)
                en(entmod (subst (cons 50 (rem (+ (/ pi 2.) (cdr rt)) (+ pi pi))) rt en))
       );while
        (setvar "cmdecho" 1)
  );while
);defun
pBe
Re: Copy and rotate (kopieren und drehen)
« Reply #1 on: January 02, 2012, 07:13:14 AM »
        (command "_copy" (ssadd el) "" (trans p1 0 1) pause)
        ;(setq en (entget (entlast)))
    (setq en (vlax-ename->vla-object (entlast)))
          (setq rt (vla-get-rotation en))
             ;   en
             ;(entmod (subst (cons 50 (rem (+ (/ pi 2.) (cdr rt)) (+ pi pi))) rt en))
              (vla-put-rotation en (rem (+ (/ pi 2.) rt) (+ pi pi)) )
       );while
  );while
Trans <---- UCS Issues
vla-put-rotation <----More Annotative Text/Mtext Friendly  :-D
DEVITG
« Reply #2 on: January 02, 2012, 07:50:48 AM »
What about  Express tool MOCORO?
Hugo
« Reply #3 on: January 02, 2012, 08:20:00 AM »
@ pBe
Thank you
even better would be before turning and then copy
noch besser wäre vorher drehen und dann kopieren
Danke
@Devitg
with Mocoron I'm not as fast
mit Mocoro bin ich nicht so schnell
Tharwat
  • Hypersensitive
« Reply #4 on: January 02, 2012, 08:33:54 AM »
Localizing variables and filtration of selection sets would be much more better to avoid any error or crash of codes  :wink:
Hugo
« Reply #5 on: January 02, 2012, 09:54:44 AM »
@Tharwat
Yes, thank you
Ja danke
« Reply #6 on: January 05, 2012, 11:59:32 AM »
Here is one of my old routine that may be of interest to you.
;;;  CopyRotate.lsp by Charles Alan Butler
;;;         Copyright 2008
;;;  by Precision Drafting & Design All Rights Reserved.
;;;  Contact at TheSwamp.org
;;;   Version 5.2  Sep 04, 2008
;;; DESCRIPTION
;;; User pick base point then selects object(s)
;;; Paste mode until Escape is pressed
;;; Once placed user selects rotation angle
;;; Command Line Usage
;;; Command: copyr
;;;;;  Copy objects, then paste & rotate new copy
(defun c:copyr (/ pt npt ss elast ssnew ale_lastent ale_ss-after *error*
                MoveStarted osmodetmp usrosmode)
  (princ "\nVwerion 5 CopyR lisp")
  ;; error function & Routine Exit
  (defun *error* (msg)
      (not
        (member
            msg
           '("console break" "Function cancelled" "quit / exit abort" "")
    ) ; endif
    (and usrosmode (setvar "osmode" usrosmode))
    (and usrormode (setvar "orthomode" usrormode))
    (if (and MoveStarted ssnew)
      (command "._erase" ssnew "")
  ;; Rune Wold and Michael Puckett - modified ale_lastent ale_ss-after
  (defun ale_lastent (/ entnam outval)
    (and
      (setq outval (entlast))
      (while (setq entnam (entnext outval))
        (setq outval entnam)
    outval
  (defun ale_ss-after (entnam / entnxt selset)
      ((not entnam) (ssget "_X"))
      ((setq entnxt (entnext entnam))
       (setq selset (ssadd entnxt))
       (while (setq entnxt (entnext entnxt))
         (if (entget entnxt)
           (ssadd entnxt selset)
       selset
  (setq usrosmode (getvar "osmode")) ; reset when routine ends
  (setq usroRmode (getvar "orthomode")) ; reset when routine ends
  (setq osmodetmp (getvar "osmode")) ; temp setting
  (setq ormodetmp (getvar "orthomode")) ; temp setting
  (if (and (null (prompt "\nSelect objects to copy:"))
           (setq ss (ssget))
           (setq pt (getpoint "\nPick base point:"))
      (setvar "osmode" 0)
      (command "._copybase" pt ss "") ; get object(s) to copy
      (command "._undo" "_begin")
      (setq elast (ale_lastent))
      (command "._pasteclip" pt) ; Create a Copy in the drawing, then move it
      (setq ssnew (ale_ss-after elast))
      (while
          (setq MoveStarted t)
  (setvar "osmode" 0)
  (setvar "orthomode" 0)
          (command "._move" ssnew ""  pt)
          ;;(setvar "osmode" osmodetmp)
          (command pause)
          (if (or (and (null npt) (setq npt (getvar "lastpoint")))
                  (> (distance pt (setq npt (getvar "lastpoint"))) 0.0001))
              ;;  allow user to rotate
              (setvar "orthomode" 1)
              (command "._rotate" ssnew "" "_non" npt)
              (command pause)
              (setq MoveStarted nil)
              (command "._undo" "_end")
              ;;  get last item in database
      (setvar "osmode" 0)
              ;;  get new items pasted.
              t ; stay in loop
      ) ; while
    ) ; progn
  ) ; endif
  (*error* "")
BlackBox
« Reply #7 on: January 05, 2012, 12:24:29 PM »
This needs some updating, but here's one written a while back that uses the acet-ss-drag-move function:
(defun c:CORO () (c:CopyRotate))
(defun c:CopyRotate  (/ *error* ss p1 p2)
  (princ "\rCOPYROTATE ")
    (if flag
      (command "._erase" ss2 ""))
    (and oldCmdecho (setvar 'cmdecho oldCmdecho))
    (and oldMenuecho (setvar 'menuecho oldMenuecho))
    (and oldNomutt (setvar 'nomutt oldNomutt))
    (cond ((not msg))                                                   ; Normal exit
          ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
          ((princ (strcat "\n** Error: " msg " ** "))))                 ; Fatal error, display it
    (princ))
  ((lambda (oldCmdecho oldMenuecho oldNomutt e flag ss2)
     (prompt "\nSelect object(s) to copy rotate: ")
     (if (and (setq ss (ssget "_:L"))
              (setq p1 (getpoint "\nSpecify base point: "))
              (setq p2 (acet-ss-drag-move
                         ss
                         p1
                         "\nLocate new object(s): "
                         T)))
         (prompt "\nEnter rotation angle: ")
         (setvar 'cmdecho 0)
         (setvar 'menuecho 6)
         (setvar 'nomutt 1)
         (command "._copy" ss "" "_non" p1 "_non" p2)
         (while (/= nil (setq e (entnext e))) (ssadd e ss2))
         (command "._rotate" ss2 "" p2)
         (setq flag nil)))
     (*error* nil))
    (getvar 'cmdecho)
    (getvar 'menuecho)
    (getvar 'nomutt)
    (entlast)
    T
    (ssadd)))
« Reply #8 on: January 05, 2012, 12:33:09 PM »
Another,
(defun c:cr ( / s )
    (if (setq s (ssget "_:L")) (command "_.rotate" s "" pause "_C" pause))
BlackBox
« Reply #9 on: January 05, 2012, 12:57:25 PM »
Sure, if you like to copy/rotate in place:-P
Edit - more accurately, about the base point. The others allow for direct placement is all.
BlackBox
« Reply #10 on: January 05, 2012, 01:05:19 PM »
Streamlined version of my earlier post (removed the system variable changes, and error handling):
(defun c:CORO  (/ e ss p1 p2 ss2)
  (setq e (entlast))
                      ss
                      p1
                      T))
           (setq ss2 (ssadd)))
      (command "._rotate" ss2 "" p2)))
  (princ))
« Reply #11 on: January 05, 2012, 01:17:59 PM »
Watch out for when 'entlast' is an attributed block, or 3D Polyline; and also for the setting of COPYMODE:wink:
As a simple command call version, I would suggest perhaps:
(defun c:cr ( / c s )
    (if (setq c (getvar 'COPYMODE)) (setvar 'COPYMODE 1))
        (command
            "_.copy"   s "" "_non" '(0 0 0) "_non" "@"
            "_.move"   s "" pause pause
            "_.rotate" s "" "_non" (getvar 'LASTPOINT) pause
    (if c (setvar 'COPYMODE c))
<< Edit, added extra "_non" >>
« Last Edit: January 05, 2012, 01:22:55 PM by Lee Mac »
BlackBox
« Reply #12 on: January 05, 2012, 01:22:42 PM »
*Touches finger to tip of nose*
*Points finger at Lee*
alanjt
  • Standby for witty remark...
« Reply #13 on: January 05, 2012, 01:51:29 PM »
(defun c:CAR (/ *error* ss p1 p2 add temp lst ang)
    (and *AcadDoc* (vla-endundomark *AcadDoc*))
    (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
  (vla-startundomark
    (cond (*AcadDoc*)
          ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
           (setq p2 (acet-ss-drag-move ss p1 "\nSpecify second point: " T))
           (progn (setq add (ssadd)
                        p1  (trans p1 1 0)
                        p2  (trans p2 1 0)
                  (vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*))
                    (vlax-invoke (setq temp (vla-copy x)) 'move p1 p2)
                    (ssadd (vlax-vla-object->ename temp) add)
                    (setq lst (cons temp lst))
                  (vla-delete ss)
                  T
           (setq ang (acet-ss-drag-rotate add (trans p2 0 1) T))
    (foreach x lst (vlax-invoke x 'rotate p2 ang))
  (*error* nil)
Dropbox
BlackBox
« Reply #14 on: January 05, 2012, 02:10:24 PM »
Nice usage of acet-ss-drag-rotate, Alan. :beer:
I really need to go over the acet* functions again. LoL
