Author Topic: CUT OFF PROBLEM  (Read 3618 times)
m4rdy
CUT OFF PROBLEM
« on: December 29, 2011, 12:54:51 AM »
Merry Christmas to everyone here,
I know this has been discussed in http://www.theswamp.org/index.php?topic=34464.msg397353#msg397353 and , I had a problhttp://www.theswamp.org/index.php?topic=8943.0
But i can't modify the the routine from david,cab,tim.
This problem is pure math that beyond my knowledge.
I need to find the pattern of cut steel bars with minimum waste or left overs.
As the example:
1. List data cut order :
‘((23 7.65) (10 5.30) (54 3.67) (67 2.66) (44 9.71) (120 4.0))
(23 7.65) means 23 pcs with each length 7.65m’
(10 5.30) => 10  pcs 5.30m’
2. List data stock :
‘(750 12.0) represent 750 pcs with each length 12.0 m’
Goal :
Find the most minimum of waste (amount of left-overs) cut from stock.
Example of result :
‘((37  (4.0  4.0  4.0))
(10 (4.0 5.3 2.66 0.04))
(23 (7.65 3.67 0.68))
(4 (3.67 3.67 3.67 0.99)
(44 (9.71 2.29))
(19 (3.67 2.66 2.66 2.66 0.35))
This result means :
37 pcs with cut pattern 4.0m + 4.0m + 4.0m equal 12m (stock length)
10 pcs with cut pattern 4.0m + 5.3m + 2.66m + 0.04m (0.04m is waste) etc.
The total needed from stock 37+10+23+4+44+19 = 137 pcs @ 12m’
Calculating waste :
1.   Total length of waste
37*0 + 10*0.04 + 23*0.68 + 4*0.99 + 44*2.29 + 19*0.35 = 127.41m’
2.   Total length needed from stock
137*12 = 1644m’
So waste = 127.41/1644 = 0.0775.
I hope my explanation is clear enough.
This is reference :
en.wikipedia.org/wiki/Cutting_stock_problem
http://delphiforfun.org/Programs/Cutting%20Stock.htm
Thank you.
mardi
Autocad 2007, Windows XP
Re: CUT OFF PROBLEM
« Reply #1 on: December 29, 2011, 12:23:33 PM »
Not sure you were working with the latest versions.
http://www.theswamp.org/index.php?topic=26955.msg326631#msg326631
Maybe this will get you closer to your goal.
;;  key search words: drop cutoff pipe waste
;;  This is a revised version fixing bugs in earler versions
(defun c:test (/ lst maxlen explst)
  (setq lst'((23 7.65) (10 5.30) (54 3.67) (67 2.66) (44 9.71) (120 4.0)))
  (setq maxlen 12.01)
  (mapcar (function
            (lambda (x) (if explst
                          (repeat (car x) (setq explst (cons (cadr x) explst)))
                            (setq explst (list (cadr x)))
                            (repeat (1- (car x)) (setq explst (cons (cadr x) explst)))
                        ))) lst)
  (print (setq clst (get_cutlist explst maxlen)))
          (print "Number of Lengths ")(princ (length clst))
        ;(print "Drops")
        ;(mapcar '(lambda(x) (print (- MaxLen (apply '+ x)))) clst)
;;  CAB 03/10/06
;;  updated 12/27/06
;;  updated 01/22/09
;;  updated 01/23/09
(defun get_cutlist (lst maxlen / cutlst itm ptr tl x finallst remove-at tmp tp)
  ;;  (RemoveNth 3 '(0 1 2 3 4 5))  CAB 12/27/2006
  (defun removeNth (i lst)
    (setq i (1+ i))
    (vl-remove-if '(lambda (x) (zerop (setq i (1- i)))) lst)
  ;; sort the list with largest first
  (setq lst (mapcar '(lambda (x) (nth x lst)) (vl-sort-i lst '>)))
  ;;  catch any length over MaxLen & break them
  (if (not (vl-every '(lambda (x) (<= x MaxLen)) lst))
      (while (> (setq tmp (car lst)) MaxLen)
        (setq lst (cdr (append lst (list MaxLen (- tmp MaxLen)))))
  ;;  step through lst
  (if (= (length lst) 1)
    (setq finallst (list lst))
      (while lst
        (setq cutlst (list (car lst)) ; start new cutlist w/ first item
              lst    (reverse (cdr lst)) ; remove first item
              eol    (1- (length lst)) ; point to end of list
              tl     (apply '+ cutlst) ; total length so far
              ptr    0
        ;; build the cutlst
        (while
            ((null lst) nil)
            ((> ptr eol) nil)
            ((< (+ (nth ptr lst) tl) MaxLen)
             (setq cutlst (cons (nth ptr lst) cutlst)
                   tl     (+ tl (car cutlst))
                   lst    (removeNth ptr lst)
                   eol    (1- eol)
            ((setq ptr (1+ ptr)))
        ;;  no more cuts fit, go to next
        (setq finallst (cons cutlst finallst)
              cutlst   nil
              lst      (reverse lst)
  finallst
« Last Edit: December 29, 2011, 12:46:53 PM by CAB »
m4rdy
Re: CUT OFF PROBLEM
« Reply #2 on: December 29, 2011, 11:13:06 PM »
You're right, I missed that one in my searching.
Thank you Alan,
I'll study your routine.
mardi
roy_043
  • BricsCAD 18
Re: CUT OFF PROBLEM
« Reply #3 on: September 14, 2015, 11:02:26 AM »
I have stumbled upon this older topic and while analysing CAB's code have noticed two issues. I am just mentioning them here for those 'following along':
  • The 'catch any length over MaxLen & break them' code only breaks once.
  • The line: '((setq ptr (1+ ptr)))' is not required because of the way lst is ordered. It will only slow things down.
The function get_cutlist with these issues fixed:
  1. (defun get_cutlist (lst maxLen / RemoveNth cutLst eol finalLst ptr tl tmp)
  2.
  3.   ;;  (RemoveNth 3 '(0 1 2 3 4 5))  CAB 12/27/2006
  4.   (defun RemoveNth (i lst)
  5.     (setq i (1+ i))
  6.     (vl-remove-if '(lambda (x) (zerop (setq i (1- i)))) lst)
  7.   )
  8.
  9.   ;;  sort the list with largest first
  10.   (setq lst (mapcar '(lambda (x) (nth x lst)) (vl-sort-i lst '>)))
  11.   ;;  catch any length over maxLen & break them
  12.   (if (> (car lst) maxLen)
  13.     (progn
  14.       (while (> (setq tmp (car lst)) maxLen)
  15.         (setq lst (cdr lst))
  16.         (repeat (fix (/ tmp maxLen))
  17.           (setq lst (append lst (list maxLen)))
  18.         )
  19.         (if (/= 0.0 (rem tmp maxLen))
  20.           (setq lst (append lst (list (rem tmp maxLen))))
  21.         )
  22.       )
  23.       (setq lst (mapcar '(lambda (x) (nth x lst)) (vl-sort-i lst '>)))
  24.     )
  25.   )
  26.   ;;  step through lst
  27.   (if (= (length lst) 1)
  28.     (setq finalLst (list lst))
  29.     (progn
  30.       (while lst
  31.         (setq cutLst (list (car lst))    ; start new cutlist with first item
  32.               lst    (reverse (cdr lst)) ; remove first item
  33.               eol    (1- (length lst))   ; point to end of list
  34.               tl     (apply '+ cutLst)   ; total length so far
  35.               ptr    0
  36.         )
  37.         ;;  build the cutLst
  38.         (while
  39.           (and
  40.             (<= ptr eol)
  41.             (<= (+ (nth ptr lst) tl) maxLen) ; '<=' instead of '<' ?
  42.           )
  43.           (setq cutLst (cons (nth ptr lst) cutLst)
  44.                 tl     (+ tl (car cutLst))
  45.                 lst    (RemoveNth ptr lst)
  46.                 eol    (1- eol)
  47.           )
  48.         )
  49.         ;;  no more cuts fit, go to next
  50.         (setq finalLst (cons cutLst finalLst)
  51.               cutLst   nil
  52.               lst      (reverse lst)
  53.         )
  54.       )
  55.     )
  56.   )
  57.   finalLst
  58. )
ymg
Re: CUT OFF PROBLEM
« Reply #4 on: September 14, 2015, 11:37:57 AM »
Roy,
FWIW, I had a thread a while back on this subject.
You may find it here:  The Cutting Stock Problem (Optimizing Cutting of Rebar or Other Material)
ymg
roy_043
  • BricsCAD 18
Re: CUT OFF PROBLEM
« Reply #5 on: September 14, 2015, 01:09:15 PM »
Thanks Ymg. Actually your thread has led me to this one and it is already on my list of interesting topics worth studying.
ymg
Re: CUT OFF PROBLEM
« Reply #6 on: September 14, 2015, 04:16:02 PM »
Roy,
I had done comparison of Cab's and David's way back in april.
They both boil down to first fit binpack.
Although it does give you some measure of optimization, it is very
often below what could be done.
ymg
roy_043
  • BricsCAD 18
Re: CUT OFF PROBLEM
« Reply #7 on: September 15, 2015, 03:27:40 AM »
Yes Ymg, you confirm my findings. These algorithms have limited optimization.
