Author Topic: AutoCAD - First Plug-in Training  (Read 35896 times)
Matt__W
  • I like my water diluted.
Re: AutoCAD - First Plug-in Training
« Reply #15 on: December 22, 2011, 11:15:53 AM »
If you can code in VB or C#, you can learn the other in a weekend.
My mind automatically translated that to: "If you can dodge a wrench, you can dodge a ball."   :-D
Autodesk Expert Elite
« Reply #16 on: December 25, 2011, 10:17:15 PM »
For anyone manually translating the first lesson :
The C# language is strongly typed.
ie
a Swan is a bird           : can't be converted to Ingredients
a Pidgeon is a bird        : can be converted to Ingredients
you can't do this
    Ingredients pieStuff = bird;
because a bird can't be implicitly converted into Ingredients
If you want a  pie you'll need to keep the compiler happy by being explicit about what you want.
   Ingredients pieStuff = (Ingredients )bird;
This will only work IF your bird can be converted into Ingredients.
no guarantees that it will taste great, but at least the compiler won't bitch about your language.
If the VB code is marked
Option Explicit Off Option Strict Off
the compiler will assume your requirements and this code will be accepted
    Dim attRef As AttributeReference = entity
If
Option Explicit On Option Strict On
you'll need to write the asignment like this, with an explicit conversion (which I prefer)
    Dim attRef As AttributeReference = CType(entity, AttributeReference)
A mind in neutral translation of
    Dim attRef As AttributeReference = entityis
    AttributeReference attRef = entity;
In C#,  the compiler requires that your code is explicit  ie written like this at the outset:-
    AttributeReference attRef = (AttributeReference)entity;
Note 1:
I took some artistic licence with the Swan pie example. :)
Note 2:
This difference in requirements is not necessarily a shortcoming in either language ... it's just the way it is :)
« Last Edit: December 29, 2011, 06:12:23 AM by Kerry »
« Reply #17 on: December 26, 2011, 09:02:14 PM »
My computer crashed when I was almost done so I got mad and typed this quickly and went from memory which is a very very bad thing. Someone might want to double check it.
First Example Converted
In VB you 'Import' the namespace and in C# you 'use' the namespace.
So
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
becomes
Here is the KeepStraightOverrule class
    Public Class KeepStraightOverrule
        Inherits TransformOverrule
        'We want to change how an AttributeReference responds to being
        ' transformed (moved, rotated, etc.), so we override its
        ' standard TransformBy function.
        Public Overrides Sub TransformBy(ByVal entity As Entity,
                                         ByVal transform As Matrix3d)
            'Call the normal TransformBy function for the attribute
            ' reference we're overruling.
            MyBase.TransformBy(entity, transform)
            'We know entity must be an AttributeReference because
            ' that is the only entity we registered the overrule for.
            'Set rotation of attribute reference to 0 (horizontal)
            attRef.Rotation = 0.0
    End Class
In VB when a class inherits from another the first line in the class is 'Inherits' then the the name of the class.
In C# you use ':'
In the TransformOverrule class it has a method TransformBy marked as
Public Overridable Sub TransformBy(ByVal entity As Entity, ByVal transform As Matrix3d)
or in C#
public virtual void TransformBy(Entity entity, Matrix3d transform)
Overridable = virtual
The virtual keyword is used to modify a method, property, indexer, or event declaration and allow for it to be overridden in a derived class. For example, this method can be overridden by any class that inherits it:
The Overidable keyword specifies that a property or procedure can be overridden by an identically named property or procedure in a derived class.
A derived class is one that inherits another class.
Also a Sub is method that 'does something' and does not return anything so in C# a 'void' method.
Some of you might wonder how is entity passed with ByVal(Meaning By Value) and in the body of the method the entity is changed and the original entity is changed. When a custom class is used in an argument it is always passed ByRef(By Reference) meaning its memory address not a copy of the value is passed and any changes made in the method will change the original object.
As Kerry mentioned if Option Strict is on then one of the things that will cause a compile error is
Implicit narrowing conversions
Since AttributeReference is derived from Entity and Entity does not contain all the methods as AttributeReference it is considered a narrowing conversion(A conversion with Data loss)
Another example would be
            Dim d As Double = 45.25
            Dim i As Integer = d
With option strict On it will throw a error with it off the compiler will do the conversion.
As Kerry mentioned you must explicitly do the conversion in C#
AttributeReference attRef = entity as AttributeReference;
MyBase(VB) and base(C#) call the 'base'(The class you are inherting from) class method.
Last couple things as my computer crashed and I am lazy and do not feel like retyping but in VB to make a null check you check if 'Is Nothing', and static = Shared.
namespace HorizontalAttributesCSharp
    public class Commands
        private static KeepStraightOverrule myOverrule;
        [CommandMethod("KeepStraight")]
        public static void ImplementOverrule()
            if (myOverrule == null)
                myOverrule = new KeepStraightOverrule();
                Overrule.AddOverrule(RXClass.GetClass(typeof(AttributeReference)), myOverrule, false);
            Overrule.Overruling = true;
    public class KeepStraightOverrule : TransformOverrule
  public override void TransformBy(Entity entity, Matrix3d transform)
            base.TransformBy(entity, transform);
   attRef.Rotation = 0.0;
**********************Edit************************************
Also AddOverule first arguement is a System.Type to read more for VB GetType
and for C# typeof
« Last Edit: December 26, 2011, 09:22:16 PM by Jeff H »
« Reply #18 on: December 26, 2011, 09:41:41 PM »
I have the same translation.
Either we're both correct or both miserably wrong
« Reply #19 on: December 26, 2011, 09:51:45 PM »
If Kerry has the same then looks like I got it correct or what little I cleaned up from here
Kerry or Stephen do you a know way to make the Attribute horizontal on 'Insert' using a overrule, maybe with ObjectOverule.
I see the SetAttributes in  DrawableOverrule but I do not think that is what I need.
If you like Overrules and the example is really good reason why to use them then you need to check out Stephen's class
AutoCADŽ .NET: Practical Examples of Customizing AutoCAD Entity Behavior
« Reply #20 on: December 26, 2011, 10:01:51 PM »
Sorry, haven't played with Overrules at all Jeff.
Recall a couple of mentions on Kean's blog ...
« Reply #21 on: December 26, 2011, 10:45:48 PM »
I tried this and it makes the Attribute appear horizontal during the Jig of the Insert but crashes with a eOpenforWrite error after the rotation is selected
using Autodesk.AutoCAD.GraphicsInterface;
        private static KeepStraightOverruleOnInsert myOverruleInsert;
                myOverruleInsert = new KeepStraightOverruleOnInsert();
                Overrule.AddOverrule(RXClass.GetClass(typeof(AttributeReference)), myOverruleInsert, false);
    public class KeepStraightOverruleOnInsert : DrawableOverrule
        public override int SetAttributes(Drawable drawable, DrawableTraits traits)
            AttributeReference attRef = drawable as AttributeReference;
            return base.SetAttributes(drawable, traits);
When I tried placing it in a OpenClose transaction
I got this error
« Last Edit: December 26, 2011, 10:59:45 PM by Jeff H »
« Reply #22 on: December 27, 2011, 12:03:24 AM »
Using code from Stephen's last example
        public override bool WorldDraw(Drawable drawable, WorldDraw wd)
            return false;
        // Called for each viewport so entity can draw itself differently
        //  depending on the view.
        public override void ViewportDraw(Drawable drawable, ViewportDraw vd)
            // Cast drawable to type AttributeReference (we know it's an
            //  AttributeReference because that's the only class we register our
            //  overrule for).
            // First calculate the transformation matrix to rotate from the
            //  BlockReference's current orientation to the view.
            Point3d org = attRef.Position;
            Vector3d zVec = vd.Viewport.ViewDirection;
            Vector3d yVec = vd.Viewport.CameraUpVector;
            Vector3d xVec = yVec.CrossProduct(zVec).GetNormal();
            Matrix3d viewmat = Matrix3d.AlignCoordinateSystem(org, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, org, xVec, yVec, zVec);
            // Then calculate the additional rotation required to compensate for
            //  the AttributeReference having a rotation.
            Matrix3d rotMat = Matrix3d.Rotation(-attRef.Rotation, attRef.Normal, org);
            // Apply the two transformations
            vd.Geometry.PushModelTransform(viewmat);
            vd.Geometry.PushModelTransform(rotMat);
            //Draw the 'per viewport geometry
            base.ViewportDraw(drawable, vd);
            // Remove the transformation - we don't want any other objects
            //  to draw themselves in the view plane.
            vd.Geometry.PopModelTransform();
This works using a Insert, but is not persisent and need to somehow make it persistent.
And the other problem I have noticed is that it does not keep AttributeReference in the same location when rotated.
For a pic example the block is a dynamic block and the top BlockReference was rotated with a RotationParameter and the overriden TransformBy method places it correctly, but the bottom reference is done during the Insert which the overriden ViewportDraw handles.
« Reply #23 on: December 27, 2011, 02:43:56 AM »
Overriding the Open Method seems to work but does not show during the Insertion Jig.
Also it only worked when applied to BlockReference's then grabbing the AttributeReferences
Overrule.AddOverrule(RXClass.GetClass(typeof(BlockReference)), myOverruleInsert, false);
 public class KeepStraightOverruleOnInsert : ObjectOverrule
        public override void Open(DBObject dbObject, OpenMode mode)
            if (mode == OpenMode.ForWrite)
                BlockReference blkRef = dbObject as BlockReference;
                if (blkRef.AttributeCollection.Count != 0)
                    using (Transaction trx = dbObject.Database.TransactionManager.StartOpenCloseTransaction())
                        foreach (ObjectId attRefId in blkRef.AttributeCollection)
                            AttributeReference attRef = trx.GetObject(attRefId, OpenMode.ForWrite) as AttributeReference;
                        trx.Commit();
            base.Open(dbObject, mode);
Arizona
« Reply #24 on: December 28, 2011, 11:12:21 AM »
Sigh! You C# guys and your semi-colon addictions  8-).
C# versions of the projects will be added eventually (after I've received enough feedback to be confident I don't have to edit too much of the VB.NET code)...
Yes please!
And thank you for the great resource!
David Hall
  • Automatic Duh Generator
« Reply #25 on: December 28, 2011, 01:09:32 PM »
C# versions of the projects will be added eventually (after I've received enough feedback to be confident.
Add me to that!!
gile
  • Marseille, France
« Reply #26 on: December 28, 2011, 02:13:52 PM »
I continue to hold the opinion that VB.NET is more suited to someone learning programming for the first time by working through tutorials like this - the code is that much more readable for mere mortals.
Why !?...
Aren't non English 'mere mortals' ?
Is it more difficult to learn the meaning of a semi-colon than the meaning of "End" ?
Does really implicit casts make easier coding in a strongly typed environment ?
IMO, in the .NET learning curve, the langauge syntax is 'peanuts' comparing to the programmation environment (Framework and API libraries, OOP, and so on...)
Anyway,
If necessary I (or  someone here) can convert the code for members here
I can give a hand this way too (these days I work on the migration of 20 000 VBA code lines to C#, hope I won't become 'Dim' addict).
I can try a F# translation too. F# isn't so 'unreadable' for those comming from LISP (neither 'Dim' nor semi-colon)...
« Reply #27 on: December 29, 2011, 03:57:38 AM »
I'll be jumped upon if I laugh about the 'Dim' addict quote ,,, so I'll just have a quiet smile to myself. :)
I think F# is a GREAT idea. We probably won't get many new dotNet AutoCAD customisers usinf F#, but it may help them to become familiar with reading it ... thus helping with understanding some of the samples floatong around.
« Reply #28 on: December 29, 2011, 05:03:32 AM »
Be careful what you ask for
Get ready for that smile to change to a cringe.
In VB you can always  turn Option Strict & and Explicit OFF and get rid of the Dims
so you can end up with this
attRef = entity
  Private Shared myOverrule
This runs but how much fun do you think it would be to deal with and find bugs with code on a much larger scale but written like this
Module Module1
    Sub Main()
        i = 10
        s = "word"
        d = 5.567
        ''answer = i * s ''-----This will compile but CRASH at runtime.
        answer = i * d   ''-----This will compile and work just fine.
        Console.WriteLine(answer)
        Console.ReadKey()
End Module
The code below compiles just fine
Namespace HorizontalAttributes
    Public Class Commands
        <CommandMethod("KeepStraight")>
        Public Shared Sub ImplementOverrule()
            If myOverrule Is Nothing Then
                myOverrule = New KeepStraightOverrule
                  RXClass.GetClass(GetType(AttributeReference)),
                  myOverrule, False)
            End If
            Overrule.Overruling = True
    End Class
            attRef = entity
    End Class
End Namespace
Arizona
« Reply #29 on: December 29, 2011, 05:55:24 AM »
attRef = entity
I even cringed at that one :-)
