Author Topic: AutoCAD - First Plug-in Training  (Read 36026 times)
« on: December 20, 2011, 08:44:35 PM »
Just noticed this ..
not sure how long it's been available, and haven't had a good look at it yet.
http://usa.autodesk.com/adsk/servlet/index?id=18162650&siteID=123112
Regards
kdub
Re: AutoCAD - First Plug-in Training
« Reply #1 on: December 20, 2011, 09:05:05 PM »
Thanks Kerry, should prove useful for a lot of folks.
alanjt
  • Standby for witty remark...
« Reply #2 on: December 20, 2011, 09:53:36 PM »
Very nice. Thanks for sharing Kerry.
Dropbox
BlackBox
« Reply #3 on: December 20, 2011, 10:27:23 PM »
Yes, thanks for sharing this Kerry.
Cheers! :beer:
SGP2012
« Reply #4 on: December 20, 2011, 11:06:53 PM »
You found it then. Its only been up for a week or so. I was going to announce it here when it was complete.
Its in Beta right now - the accompanying videos will be ready soon. Feel free to email comments to myfirstplugin@autodesk.com (or discuss it here, of course :-)). All feedback gratefully received - good or bad.
BTW For anyone interested in Revit or Inventor programming, this follows on from the My First Plug-in tutorials for those products. You can find links at www.autodesk.com/developrevit and www.autodesk.com/developinventor.
« Reply #5 on: December 20, 2011, 11:16:21 PM »
Good stuff!!
Thanks a ton Stephen!!!
« Reply #6 on: December 20, 2011, 11:17:11 PM »
Thanks Stephen, quite awesome, and on a number of levels.
BlackBox
« Reply #7 on: December 20, 2011, 11:30:48 PM »
Can't wait to dig through the .NET tutorial(s) Stephen; many thanks!
« Last Edit: December 21, 2011, 06:19:08 AM by RenderMan »
« Reply #8 on: December 21, 2011, 03:49:26 AM »
Looks like the samples and tutorials favour VB.Net ...
Stephen,
when the bugs are ironed out can the samples be provided in C# as well as vb to save beginning C# customisers having to translate the code.
If necessary I (or  someone here) can convert the code for members here,  but I believe including the source with your downloads would be better.
Thanks for the iniative.
Regards
kdub.
SGP2012
« Reply #9 on: December 21, 2011, 08:49:29 PM »
Sigh! You C# guys and your semi-colon addictions  8-).
C# versions of the projects will be added eventually (after I've received enough feedback to be confident I don't have to edit too much of the VB.NET code), but I may not create a C# version of the webpages. I continue to hold the opinion that VB.NET is more suited to someone learning programming for the first time by working through tutorials like this - the code is that much more readable for mere mortals.
« Reply #10 on: December 21, 2011, 09:02:25 PM »
Sorry, I forgot it was aimed at mortals.   :lmao:
I thought I noticed C# code in either the Inventor or Revit section.
« Reply #11 on: December 21, 2011, 09:46:26 PM »
Bring on the VB!! Generally speaking, VB is easier to translate to C# than vice versa.
There, I said it. :laugh:
BlackBox
« Reply #12 on: December 22, 2011, 01:02:44 AM »
I Jumped (am jumping?) straight from Visual LISP --> VB.NET  :evil:
I still want to learn C# syntax (for personal edification), however I went with VB.NET when I started learning the .NET API for the simple reason that it was easier to read, and was more closely 'written' with the familiar syntax of Visual LISP (ActiveX --> VBA --> VB.NET).
« Reply #13 on: December 22, 2011, 11:07:22 AM »
If you can code in VB or C#, you can learn the other in a weekend.
It is getting to know the framework that takes time.
Matt__W
  • I like my water diluted.
« Reply #14 on: December 22, 2011, 11:13:49 AM »
FINALLY!!!  Right up my alley.  It gets tiring seeing all of the C-base code samples and trying to translate to VB.
Thanks!!
Autodesk Expert Elite
