Author Topic: Copy of Database  (Read 2199 times)
Andrey Bushman
Copy of Database
« on: December 13, 2011, 08:55:26 AM »
How can I quickly to create a copy of Database object?
//db - is Database, not null...
//Variant 1:
Database db1 = (Database) db.Clone();//result: db1 = null;
 //Variant 2:
Database db2 = new Database(false, true);
db2.CopyFrom(db);// result: Fatal Error.
Thanks.
kaefer
Re: Copy of Database
« Reply #1 on: December 13, 2011, 09:19:28 AM »
Database.Wblock Method ()
Description
Creates a new Database object, and then uses the wblockClone mechanism to write the entire contents of the database on which this function is being called out to the new database.
Andrey Bushman
« Reply #2 on: December 13, 2011, 09:33:41 AM »
2 kaefer
Thanks!
