Author Topic: Newly created object to new layer  (Read 1479 times)
cadpro
« on: December 12, 2011, 06:55:47 AM »
I create a polyline  as the code below:
doc.SendStringToExecute("_PLINE" & vbCr, True, False, True)
As soon as this is created, a form pops up where I want to save the created pline into a new layer. I have code to create the new layer. This is called in the save button of the second form as here:
Dim layerId as ObjectId = CreateLayer("testlayer")
Would this be possible?
MexicanCustard
Re: Newly created object to new layer
« Reply #1 on: December 12, 2011, 08:06:24 AM »
Yes, you can create the layer and add it to the object post creation but be careful using the SendStringToExecute.  I was told by ADN members that this doesn't always perform the way you would expect it too.  The string is put in a que to execute but sometimes may not execute during this line of code thus when you go to change the object's layer the object may not exist yet.
fixo
« Reply #2 on: December 12, 2011, 01:57:59 PM »
@cadpro
See this code by Bryco
http://www.theswamp.org/index.php?topic=29216.msg348193#msg348193
this will create polyline as you want just add put the layer you need
