Author Topic: Nested Xref Counter in Tree Format  (Read 14190 times)
GDF
« on: December 09, 2011, 11:06:54 AM »
Need help with modifing Tim Willey's code to add a xref counter for each nested xref and print it in a tree format as per his code.
Code can be found here:
http://www.theswamp.org/index.php?topic=34277.msg409437#msg409437
Need to list all xrefs named "BL*" found with model space of the opened drawing:
Then list and count all nested xrefs named "UT*" within each of the xrefs listed above:
Example of text screen:
Main xref: BL-02b
  |- Nested xref: UT-B2a_985hc
  |- Nested xref: UT-B2b_985
  |- Nested xref: UT-B2c_985
  |- Nested xref: UT-B2d_985
 Main xref: BL-04
  |- Nested xref: UT-A1a_760hc
  |- Nested xref: UT-A1b_760
  |- Nested xref: UT-A1c_760
  |- Nested xref: UT-A1d_760
  |- Nested xref: UT-A2a_760
  |- Nested xref: UT-A2b_760
  |- Nested xref: UT-A2c_760
  |- Nested xref: UT-A2d_760
  |- Nested xref: UT-B1b_985
  |- Nested xref: UT-B1c_985
  |- Nested xref: UT-B1d_985
  |- Nested xref: UT-B3a_985
  |- Nested xref: UT-B3b_985
  |- Nested xref: UT-B3c_985
  |- Nested xref: UT-B3d_985
  |- Nested xref: UTB-GAR
« Last Edit: December 12, 2011, 10:55:31 PM by GDF »
ribarm
  • Marko Ribar, architect
Re: Nested Xref Counter in Tree Format
« Reply #1 on: December 09, 2011, 01:27:09 PM »
Not tested, but try something like this way :
EDIT: Code tested
(defun c:PrintXrefNesting ( / mainfilter filter )
    ; Prints nested xref tree to command line, no matter how deep the nesting.
    (setq mainfilter (getstring T "\nInput prefix filter for Main Xrefs : "))
    (setq filter (getstring T "\nInput prefix filter for Nested Xrefs : "))
    (defun FilterNestedXrefs ( lst mainfilter filter / ifillst inewlst newlst )
        (foreach i lst
            (if (and (atom (car i)) (wcmatch (strcase (cdr (assoc 2 (entget (car i))))) (strcase mainfilter)))
                       (if (listp (cdr i))
          (setq ifillst (filternested (cdr i) filter))
                                  (setq inewlst (cons (car i) ifillst))
                  (setq newlst (cons inewlst newlst))
    (setq newlst (cons i newlst))
        (reverse newlst)
    (defun filternested ( lst filter / newlst ii )
        (foreach i lst
    (setq ii i)
            (if (and (atom (car i)) (wcmatch (strcase (cdr (assoc 2 (entget (car i))))) (strcase filter))) () (setq ii nil))
            (cond     ((listp (cdr i)) (filternested (cdr i) filter))
                ((and (atom (cdr i)) (wcmatch (strcase (cdr (assoc 2 (entget (cdr i))))) (strcase filter))) () (setq ii nil))
              ((eq (cdr i) nil) nil)
            (setq newlst (cons ii newlst))
        (reverse newlst)
    (defun GetXrefNesting (/ tempData tempEnt XrefList NonNestedXrefList NestedXrefList )
        (defun GetXrefInfo ( ent / NestList )
            (foreach i (member '(102 . "{BLKREFS") (entget ent))
                (if (equal (car i) 332)
                        (setq NestedList (cons (cdr i) NestedList))
                        (setq NestList
                            (cons
                                (cons
                                    (cdr i)
                                    (GetXrefInfo (cdr i))
                                NestList
            NestList
        (while (setq tempData (tblnext "block" (not tempData)))
            (if (equal (logand (cdr (assoc 70 tempData)) 4) 4)
                    (setq tempEnt (tblobjname "block" (cdr (assoc 2 tempData))))
                    (setq tempEnt (cdr (assoc 330 (entget tempEnt))))
                    (setq XrefList
                        (cons
                            (cons
                                tempEnt
                                (GetXrefInfo tempEnt)
                            XrefList
        (foreach i XrefList
            (if (not (member (car i) NestedList))
                (setq NonNestedXrefList (cons i NonNestedXrefList))
        NonNestedXrefList
    (defun PrintNestedList ( lst spc )
        (foreach
            i
            (vl-sort
                lst
                (function
                    (lambda ( a b )
                            (strcase (cdr (assoc 2 (entget (car a)))))
                            (strcase (cdr (assoc 2 (entget (car b)))))
            (if (and (not (listp (car i))) (car i)) (prompt (strcat "\n" spc " Nested xref: " (cdr (assoc 2 (entget (car i)))))) (prompt (strcat "\n" spc " Nested xref: nil" )) )
            (PrintNestedList (if (cdr i) (cdr i) nil) (strcat "  " spc))
            ;(PrintNestedList (cdr i) (strcat "  |" spc)) [color=red]; second option shown below[/color]
    (foreach
        i
        (vl-sort
            (FilterNestedXrefs (GetXrefNesting) mainfilter filter)
            (function
                (lambda ( a b )
        (prompt (strcat "\n Main xref: " (cdr (assoc 2 (entget (car i)))) " - " (itoa (sslength (ssget "_X" (list '(0 . "INSERT") (assoc 2 (entget (car i))) (cons 410 (getvar 'ctab)))))) ))
        (PrintNestedList (if (and (/= (cadr i) nil) (cdr i)) (vl-remove nil (cdr i)) nil) "  |-")
M.R.
« Last Edit: December 12, 2011, 08:50:42 AM by ribarm »
M.R. on Youtube
GDF
« Reply #2 on: December 09, 2011, 02:35:24 PM »
Thanks Marko. I get nil when entering the filters from your code.
The filters are not really needed, but would be nice to have.
My main question was how to add a counter for the total number for each xref and nested xref found.
Something like:
(defun C:UTC (/ ent_count)
  (setq ent_count (sslength (ssget "a" '((2 . "*UT*")(8 . "0-XREF")))))
  (alert (strcat (rtos ent_count 2 0) " Total Units"))
(defun C:BLC (/ ent_count)
  (setq ent_count (sslength (ssget "a" '((2 . "*BL*")(8 . "0-XREF")))))
  (alert (strcat (rtos ent_count 2 0) " Total Buildings"))
But in Tim's tree format code. for example:
[1]  Main xref: BL-01a
  [2]  |- Nested xref: UT-A1a_760hc
  [4]  |- Nested xref: UT-A1b_760
  [1]  | - Nested xref: UT-A1c_760
  ...and so on.
GDF
« Reply #3 on: December 09, 2011, 04:37:28 PM »
;;;http://www.theswamp.org/index.php?topic=28062.msg337119#msg337119
;;;Tim Willey
In this example the main xref is counted...I want to also count the nested xrefs within the list.
So how do I modify the code below to count all xrefs, main and nested?
(defun c:test ()
(defun GetXrefs (/ tempData tempEnt XrefList)
                (setq tempData (entget (cdr (assoc 330 (entget tempEnt)))))
                (setq XrefList
                    (cons
                        (cons
                            tempEnt
                                (lambda ( x / InsList NestList )
                                    (foreach i x
                                            ((equal (car i) 331)
                                                (setq InsList (cons (cdr i) InsList))
                                            ((equal (car i) 332)
                                                (setq NestList (cons (cdr i) NestList))
                                    (list InsList NestList)
                                (member '(102 . "{BLKREFS") tempData)
                        XrefList
    XrefList
(foreach i (GetXrefs)
        (princ "\nXref name: ")
        (princ (cdr (assoc 2 (entget (car i)))))
        (princ "\n    Inserted amount: ")
        (princ (itoa (length (cadr i))))
        (if (caddr i)
                (princ "\n    Nested xref names: ")
                (foreach j (caddr i)
                    (princ "\n        ")
                    (princ (cdr (assoc 2 (entget j))))
        (princ "\n")
« Reply #4 on: December 09, 2011, 04:47:41 PM »
Perhaps add this?
    (if   (caddr i)
      (progn (princ "\n    Nested xref names: ")
        (princ (itoa (length (caddr i))))
        (foreach j (caddr i) (princ "\n        ") (princ (cdr (assoc 2 (entget j)))))
ribarm
« Reply #5 on: December 09, 2011, 04:57:58 PM »
You should try to incorporate counter into main code - I've modified it and checked and now filters work...
M.R.
M.R. on Youtube
GDF
« Reply #6 on: December 09, 2011, 05:00:56 PM »
Thanks Ron
Xref name: BL-03a
    Inserted amount: 1
    Nested xref names:
    Inserted amount: 6
        UT-C1a_1331hc
        UTB-Gar2
        UT-C2b_1331
        UT-C1c_1331
        UT-C1b_1331
        UT-C1d_1331
Xref name: BL-04a
    Inserted amount: 1
    Nested xref names:
    Inserted amount: 16
        UT-A1a_760hc
        UT-B3d_985
        UT-B3c_985
        UT-B3b_985
        UT-B3a_985
        UT-B1c_985
        UT-B1b_985
        UT-B1d_985
        UT-A2c_760
        UT-A2b_760
        UT-A2d_760
        UT-A1d_760
        UT-A1c_760
        UT-A1b_760
        UT-A2a_760
        UTB-GAR
"\n"
But what I am looking for is the number for each individual unique nested xref.
For example "UT-A2d_760" maybe xrefed in 5 times and "UTB-GAR" only 2 times.
Xref name: BL-04a
    Inserted amount: 1
    Nested xref names:
    Inserted amount: 16  <--not needed
        UT-A1a_760hc  <--want count here
        UT-B3d_985   <--want count here
        UT-B3c_985   <--want count here
GDF
« Reply #7 on: December 09, 2011, 05:23:18 PM »
M.R.
GDF
« Reply #8 on: December 09, 2011, 09:31:42 PM »
We often load multiple copies of the same nested "unit plan" xrefs within the main "building plan" xref...therfore I need a count of how many times the "unit plans" are copied.
I hope this understandable:
Xref name: BL-04a
    Inserted amount: 1
    Nested xref names:
    Inserted amount: 16  <--not needed...this is the total of how many of unique files ther are
        UT-A1a_760hc  <--want count here...of total times the xrefs are copied
        UT-B3d_985   <--want count here...of total times the xrefs are copied
        UT-B3c_985   <--want count here...of total times the xrefs are copied
ribarm
« Reply #9 on: December 10, 2011, 08:27:27 AM »
For main Xrefs, its easy to find number of insertions, but for nested I still don't know how... I've updated  code with filtering xrefs to include number of main Xrefs ( I added - no. after prompting its name)...
If only there is a way to check for (ssget "_X" '((0 . "INSERT") (2 . "nested xref name") (410 . "Model"))) inside of each main xref without opening it...??? :|
M.R.
M.R. on Youtube
ribarm
« Reply #10 on: December 10, 2011, 11:14:08 AM »
I've figured out... Only thing is that you'll have to multiply manually with number of parent xref, all to top most level - main xref to get total numbers of child nested xref... This number shows how many nested xrefs are per 1 parent xref... So here is code :
      (defun nestedxrefcount ( mainname nestedname / bl item n )
        (setq bl (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
        (vlax-for item bl
          (if (= (vla-get-name item) mainname)
              (setq n 0)
              (vlax-for xr item
              (if (= (vl-catch-all-apply 'vla-get-EffectiveName (list xr)) nestedname) (setq n (1+ n)))
      n
        (foreach i lst
                       (if (listp (cdr i))
        (reverse newlst)
        (foreach i lst
    (setq ii i)
        (reverse newlst)
                        (setq NestList
                            (cons
                                (cons
                                    (cdr i)
                                NestList
            NestList
                    (setq XrefList
                        (cons
                            (cons
                                tempEnt
                            XrefList
        (foreach i XrefList
        NonNestedXrefList
    (defun PrintNestedList ( lst spc mainname )
        (foreach
            i
            (vl-sort
                lst
                (function
                    (lambda ( a b )
            (if (and (not (listp (car i))) (car i)) (prompt (strcat "\n" spc " Nested xref: " (cdr (assoc 2 (entget (car i)))) " - " (itoa (nestedxrefcount mainname (cdr (assoc 2 (entget (car i)))))))) (prompt (strcat "\n" spc " Nested xref: nil" )) )
            (PrintNestedList (if (cdr i) (cdr i) nil) (strcat "  " spc) (cdr (assoc 2 (entget (car i)))))
    (foreach
        i
        (vl-sort
            (function
                (lambda ( a b )
        (PrintNestedList (if (and (/= (cadr i) nil) (cdr i)) (vl-remove nil (cdr i)) nil) "  |-" (cdr (assoc 2 (entget (car i)))))
Regards, M.R.
« Last Edit: December 12, 2011, 08:51:15 AM by ribarm »
M.R. on Youtube
GDF
« Reply #11 on: December 10, 2011, 12:35:53 PM »
Marko
Saying thank you does not seem enough. Works perfectly. I tried as best I could to solve it, way out of my zip code of knowledge.
Late last night I was thinking it could only be done with objectdbx coding.
Results from your updated code:
Input prefix filter for Main Xrefs : BL*
Input prefix filter for Nested Xrefs : UT*
 Main xref: BL-01 - 2
  |- Nested xref: UTB2-1119 - 6
  |- Nested xref: UTB5-1048 - 2
 Main xref: BL-02 - 2
  |- Nested xref: UTA2-692 - 4
  |- Nested xref: UTA2-692-HC - 2
  |- Nested xref: UTA4-697 - 8
  |- Nested xref: UTA6-899 - 1
  |- Nested xref: UTA7-969 - 1
  |- Nested xref: UTA8-697 - 2
  |- Nested xref: UTA9-697 - 2
  |- Nested xref: UTB1-969 - 6
  |- Nested xref: UTB2a-1119 - 2
  |- Nested xref: UTB4-1258 - 4
 Main xref: BL-03 - 1
  |- Nested xref: UTA1-599a - 8
  |- Nested xref: UTA1-599b - 8
  |- Nested xref: UTA3-893 - 8
 Main xref: BL-04 - 1
  |- Nested xref: UTA5-899 - 8
  |- Nested xref: UTB3-936 - 12
 Main xref: BL-05 - 1
Thank you  Thank you
GDF
« Reply #12 on: December 10, 2011, 02:24:23 PM »
Having trouble with printing to a file:
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Print Xref Nesting ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;;;Tim Willey
;;;Marko Ribar
(defun PrintXrefNestingIT ( / mainfilter filter )
    ;;Prints nested xref tree to command line, no matter how deep the nesting.
    (setq mainfilter (getstring T "\n* Input prefix filter for Main Xrefs: [BL*] "))
    (if (= mainfilter "")(setq mainfilter "BL*"))
    (setq filter (getstring T "\n* Input prefix filter for Nested Xrefs: [UT*]"))
    (if (= filter "")(setq filter "UT*"))
      (defun nestedxrefcount ( mainname nestedname / bl item )
        (vlax-for item bl
              (setq n 0)
              (vlax-for xr item
      n
        (foreach i lst
                       (if (listp (cdr i))
        (reverse newlst)
        (foreach i lst
    (setq ii i)
        (reverse newlst)
                        (setq NestList
                            (cons
                                (cons
                                    (cdr i)
                                NestList
            NestList
                    (setq XrefList
                        (cons
                            (cons
                                tempEnt
                            XrefList
        (foreach i XrefList
        NonNestedXrefList
    (setq FileName (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4)))
    (startapp "notepad.exe" (strcat (getvar "dwgprefix") FileName " PrintXrefNesting.txt"))
    (setq Opened (open (strcat (getvar "dwgprefix") FileName " PrintXrefNesting.txt") "w"))
        (foreach
            i
            (vl-sort
                lst
                (function
                    (lambda ( a b )
            (if (and (not (listp (car i))) (car i)) (write-line (strcat "\n" spc " Nested xref: " (cdr (assoc 2 (entget (car i)))) " - " (itoa (nestedxrefcount mainname (cdr (assoc 2 (entget (car i))))) Opened)    ) )
            (write-line (strcat "\n" spc " Nested xref: nil") Opened))
    (foreach
        i
        (vl-sort
            (function
                (lambda ( a b )
        (write-line (strcat "\n\n[ ]  Main xref: " (cdr (assoc 2 (entget (car i)))) " - " (itoa (sslength (ssget "_X" (list '(0 . "INSERT") (assoc 2 (entget (car i))) (cons 410 (getvar 'ctab)))))) Opened))
        (PrintNestedList (if (cdr i) (cdr i) nil) "\t\t>" (cdr (assoc 2 (entget (car i)))))
    ;;(vl-filename-base (getvar "dwgname"))
    ;;(setq FileName (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4)))
    ;;(startapp "notepad.exe" (strcat "\\Arch " ARCH#PROJ FileName " PrintXrefNesting.txt"))
    ;;(startapp "notepad.exe" (strcat (getvar "dwgprefix") FileName " PrintXrefNesting.txt"))
    (if Opened (close Opened))
GDF
« Reply #13 on: December 10, 2011, 08:18:54 PM »
Got it working...here is my final routine:
Special thanks to Tim Willey and Marko Ribar.
;;; Tim Willey
;;; Marko Ribar
;;; Prints nested xref tree to command line, no matter how deep the nesting.
(defun PrintXrefNestingIT (/ mainfilter    filter
   opened projectDesc   projectName
   datestring
  (defun ARCH:ProjectName ()
    (setq DirPath (getvar "dwgprefix"))
    (setq ProjectNum (substr DirPath 14 6))
    (setq ARCH#PROJ (substr DirPath 14 6))
    (cond ((/= (atoi ProjectNum) 0) (setvar "users1" ProjectNum)))
    (cond ((/= (getvar "users1") 0)
   (setq ProjectName
  (dos_getini
    "PROJECTS"
    (getvar "users1")
    (strcat ARCH#CUSF "FILE/ARCH_Projects.ini")
    (cond ((= ProjectName nil) (setq ProjectDesc ""))
  ((/= ProjectName nil)
   (setq projectDesc
  (strcat "        Project Name : [" ProjectName "]")
  (defun ARCH:DATE2 (/ DATST MON DAY YEAR HRS)
    (setq DATST (rtos (getvar "CDATE") 2 16)
  MON (substr DATST 5 2)
  DAY (substr DATST 7 2)
  YEAR (substr DATST 1 4)
  HRS (atoi (substr DATST 10 2))
    (cond ((= MON "01") (setq MON2 "January"))
  ((= MON "02") (setq MON2 "Feburary"))
  ((= MON "03") (setq MON2 "March"))
  ((= MON "04") (setq MON2 "April"))
  ((= MON "05") (setq MON2 "May"))
  ((= MON "06") (setq MON2 "June"))
  ((= MON "07") (setq MON2 "July"))
  ((= MON "08") (setq MON2 "August"))
  ((= MON "09") (setq MON2 "September"))
  ((= MON "10") (setq MON2 "October"))
  ((= MON "11") (setq MON2 "November"))
  ((= MON "12") (setq MON2 "December"))
    (cond ((= HRS 00) (setq NHRS (itoa (+ HRS 12))) (setq XTR "a.m."))
  ((< HRS 12) (setq NHRS (itoa HRS)) (setq XTR "a.m."))
  ((= HRS 12) (setq NHRS (itoa HRS)) (setq XTR "p.m."))
  ((> HRS 12) (setq NHRS (itoa (- HRS 12))) (setq XTR "p.m."))
    (setq datestring
   (strcat MON2
   DAY
   YEAR
   NHRS
   (substr DATST 12 2)
   XTR
  (setq mainfilter
(getstring
   T
  (setq filter
(getstring T
  (if (= filter "")
    (setq filter "UT*")
  (prompt "* Please Wait while the Program is Running...")
  (defun nestedxrefcount (mainname nestedname / bl item)
    (vlax-for item bl
  (setq n 0)
  (vlax-for xr item
nestedname
       (setq n (1+ n))
    n
(lst mainfilter filter / ifillst inewlst newlst)
    (foreach i lst
  (if (listp (cdr i))
    (reverse newlst)
  (defun filternested (lst filter / newlst ii)
    (foreach i lst
      (setq ii i)
(strcase filter)
(setq ii nil)
   (strcase filter)
     (setq ii nil)
    (reverse newlst)
tempEnt XrefList
NonNestedXrefList
NestedXrefList
    (defun GetXrefInfo (ent / NestList)
    (setq NestList
   (cons
     (cons
       (cdr i)
     NestList
      NestList
  (setq XrefList
(cons
   (cons
     tempEnt
   XrefList
    (foreach i XrefList
    NonNestedXrefList
  (ARCH:DATE2)
  (ARCH:ProjectName)
1
     FileName
     "w"
  (write-line
    opened
  (write-line projectDesc opened)
  (write-line
    (strcat "        Directory is: ["
    FileName
    opened
  (write-line (strcat "        " datestring) opened)
  (write-line
    opened
  (defun PrintNestedList (lst spc mainname)
    (foreach
      i
       (vl-sort
lst
(function
   (lambda (a b)
(write-line
  (strcat ""
  spc
  " Nested xref: "
  mainname
  opened
(prompt (strcat "\n" spc " Nested xref: nil"))
      (PrintNestedList
(if (cdr i)
  (cdr i)
  nil
(strcat "" spc)
  (foreach
    i
     (vl-sort
       (function
(lambda (a b)
    (write-line
      (strcat "\n\n [ ] Main xref: "
      opened
    (PrintNestedList
      (if (cdr i)
(cdr i)
nil
  (if Opened
    (close Opened)
    FileName
Example of output file:
        Project Name : [Lakes @ University Park]
        Directory is: [F:\Jobs\2008\080331\acad\building\BL-Profile1]
        December 10, 2011 7:17 p.m.
 [ ] Main xref: BL-01 - 2
     > Nested xref: UTB2-1119 - 6
     > Nested xref: UTB5-1048 - 2
 [ ] Main xref: BL-02 - 2
     > Nested xref: UTA2-692 - 4
     > Nested xref: UTA2-692-HC - 2
     > Nested xref: UTA4-697 - 8
     > Nested xref: UTA6-899 - 1
     > Nested xref: UTA7-969 - 1
     > Nested xref: UTA8-697 - 2
     > Nested xref: UTA9-697 - 2
     > Nested xref: UTB1-969 - 6
     > Nested xref: UTB2a-1119 - 2
     > Nested xref: UTB4-1258 - 4
 [ ] Main xref: BL-03 - 1
     > Nested xref: UTA1-599a - 8
     > Nested xref: UTA1-599b - 8
     > Nested xref: UTA3-893 - 8
 [ ] Main xref: BL-04 - 1
     > Nested xref: UTA5-899 - 8
     > Nested xref: UTB3-936 - 12
 [ ] Main xref: BL-05 - 1
GDF
« Reply #14 on: December 10, 2011, 09:01:07 PM »
Minor twicks
;;; original routine by Tim Willey
;;; major editing by Marko Ribar
;;; edited by Gary Fowler
;;; Added output file project header and routine progress bar
   datestring n
   (setq ProjectName
  (dos_getini
    "PROJECTS"
    (getvar "users1")
   (setq projectDesc
    (setq datestring
   (strcat MON2
   DAY
   YEAR
   NHRS
   (substr DATST 12 2)
   XTR
  (setq mainfilter
(getstring
   T
  (setq filter
(getstring T
  (if (= filter "")
    (setq filter "UT*")
  (setq n 1)
  (ACET-UI-PROGRESS-INIT
    "Please Wait while the Program is Running"
    (length rtnList))
    (vlax-for item bl
  (setq n 0)
  (vlax-for xr item
nestedname
       (setq n (1+ n))
    n
    (foreach i lst
  (if (listp (cdr i))
      (ACET-UI-PROGRESS-SAFE n)
      (setq n (+ n 1))
    (reverse newlst)
    (foreach i lst
      (setq ii i)
(strcase filter)
(setq ii nil)
   (strcase filter)
     (setq ii nil)
      (setq n (+ n 1))
    (reverse newlst)
tempEnt XrefList
NonNestedXrefList
NestedXrefList
    (setq NestList
   (cons
     (cons
       (cdr i)
     NestList
        (setq n (+ n 1))
      NestList
  (setq XrefList
(cons
   (cons
     tempEnt
   XrefList
    (foreach i XrefList
      (setq n (+ n 1))
    NonNestedXrefList
  (ARCH:DATE2)
  (ARCH:ProjectName)
1
     FileName
     "w"
  (write-line
    opened
  (write-line
    FileName
    opened
  (write-line
    opened
    (foreach
      i
       (vl-sort
lst
(function
   (lambda (a b)
(write-line
  (strcat ""
  spc
  " Nested xref: "
  mainname
  opened
      (PrintNestedList
(if (cdr i)
  (cdr i)
  nil
(strcat "" spc)
    (setq n (+ n 1))
  (foreach
    i
     (vl-sort
       (function
(lambda (a b)
    (write-line
      opened
    (PrintNestedList
      (if (cdr i)
(cdr i)
nil
  (if Opened
    (close Opened)
    FileName
  (ACET-UI-PROGRESS-DONE)
GDF
« Reply #15 on: December 10, 2011, 10:59:14 PM »
Updated code...I'm done.
;;; Added output file with project header and routine progress bar and xref paths
   datestring n
;;;Function: xrefs-list
;;;Purpose: get information regarding xrefs
;;;Arguments: none
;;;Returns: rtlist - a list of lists, one for each xref, as follows:
;;; (nth 0 (car rtlist)) = filename
;;; (nth 1 (car rtlist)) = fullfilename
;;; (nth 2 (car rtlist)) = foundpath
;;; (nth 3 (car rtlist)) = ismodified - vlax:true/vlax:false
;;; (nth 4 (car rtlist)) = reference count
;;;Mike Weaver
  (defun xrefs-list (/ rtlist)
    (setq n (+ n 1))
    (write-line (strcat "\n List Of Saved Xref Paths:") opened)
    (write-line
      (strcat
      opened
    (vlax-for
      objFileDep
(vla-get-filedependencies
      (if (= "Acad:XRef" (vla-get-feature objFileDep))
(setq
  rtlist (cons
   (cons
     (vla-get-filename objFileDep)
     ;;(list
     ;;(vla-get-fullfilename objFileDep)
     ;;(vla-get-foundpath objFileDep)
     ;;(vla-get-ismodified objFileDep)
     ;;(vla-get-referencecount objFileDep)
     (write-line
       (strcat " " (vla-get-fullfilename objFileDep))
       opened
   rtlist
    rtlist
  ;;(foreach i rtlist (write-line (strcat " " (nth 1 (car rtlist))) opened))
   (setq ProjectName
  (dos_getini
    "PROJECTS"
    (getvar "users1")
   (setq projectDesc
    (setq datestring
   (strcat MON2
   DAY
   YEAR
   NHRS
   (substr DATST 12 2)
   XTR
  (setq mainfilter
(getstring
   T
  (setq filter
(getstring T
  (if (= filter "")
    (setq filter "UT*")
  (setq n 1)
    (length rtnList)
    (vlax-for item bl
  (setq n 0)
  (vlax-for xr item
nestedname
       (setq n (1+ n))
    n
    (foreach i lst
  (if (listp (cdr i))
      (setq n (+ n 1))
    (reverse newlst)
    (foreach i lst
      (setq ii i)
(strcase filter)
(setq ii nil)
   (strcase filter)
     (setq ii nil)
      (setq n (+ n 1))
    (reverse newlst)
tempEnt XrefList
NonNestedXrefList
NestedXrefList
    (setq NestList
   (cons
     (cons
       (cdr i)
     NestList
(setq n (+ n 1))
      NestList
  (setq XrefList
(cons
   (cons
     tempEnt
   XrefList
    (foreach i XrefList
      (setq n (+ n 1))
    NonNestedXrefList
  (ARCH:DATE2)
  (ARCH:ProjectName)
1
     FileName
     "w"
  (write-line
    opened
  (write-line
    FileName
    opened
  (write-line
    opened
    (foreach
      i
       (vl-sort
lst
(function
   (lambda (a b)
(write-line
  (strcat ""
  spc
  " Nested xref: "
  mainname
  opened
      (PrintNestedList
(if (cdr i)
  (cdr i)
  nil
(strcat "" spc)
    (setq n (+ n 1))
  (foreach
    i
     (vl-sort
       (function
(lambda (a b)
    (write-line
      (strcat "\n [ ] Main xref: "
      opened
    (PrintNestedList
      (if (cdr i)
(cdr i)
nil
  (xrefs-list)
  (if Opened
    (close Opened)
    FileName
Output file:
        December 10, 2011 9:59 p.m.
 F:\Jobs\2008\080331\ACAD\building\BL-01.dwg
 F:\Jobs\2008\080331\ACAD\building\BL-02.dwg
 F:\Jobs\2008\080331\ACAD\building\BL-04.dwg
 F:\Jobs\2008\080331\ACAD\building\BL-05.dwg
 F:\Jobs\2008\080331\ACAD\building\BL-03.dwg
 F:\Jobs\2008\080331\ACAD\units\UTB2-1119.dwg
 F:\Jobs\2008\080331\ACAD\units\UTB5-1048.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA4-697.dwg
 F:\Jobs\2008\080331\ACAD\units\UTB1-969.dwg
 F:\Jobs\2008\080331\ACAD\units\UTB4-1258.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA2-692-HC.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA6-899.dwg
 F:\Jobs\2008\080331\ACAD\units\UTB2a-1119.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA2-692.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA9-697.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA7-969.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA8-697.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA5-899.dwg
 F:\Jobs\2008\080331\ACAD\units\UTB3-936.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA3-893.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA1-599b.dwg
 F:\Jobs\2008\080331\ACAD\units\UTA1-599a.dwg
« Last Edit: December 10, 2011, 11:19:40 PM by GDF »
ribarm
« Reply #16 on: December 11, 2011, 01:50:40 AM »
I see that you didn't noticed that I forgot to localize n variable in :
and seeing that you uses n later on in your bigger code I suggest that you modify :
(defun nestedxrefcount (mainname nestedname / bl item n)
also I don't know ab this line :
    (length rtnList)
variable rtnList is global and is called from your session...
maybe I am wrong, but I thought you wanted
    (length (xrefs-list))
and finally, I would consider showing in your report Nested from Nested Xrefs (notice space characters in between "" (strcat "   " spc)) :
      (PrintNestedList
(if (cdr i)
  (cdr i)
  nil
(strcat "  " spc)
Regards, M.R.
« Last Edit: December 11, 2011, 04:23:43 AM by ribarm »
M.R. on Youtube
ribarm
« Reply #17 on: December 11, 2011, 05:07:26 AM »
So this final version should give you no errors after execution on text screen... Still you should check for progress - does it ends at 100%... Test it once with ;(acet-ui-progress-done) and if it all OK (100% and no errors on text screen), then put it back without ;
(defun c:PrintXrefNestingIT (/ mainfilter   filter
   datestring n
;;;Arguments: none
;;;Mike Weaver
  (defun Flatten ( l )
    (if (atom l) (list l)
      (append (Flatten (car l)) (if (cdr l) (Flatten (cdr l))))
    (write-line
      (strcat
      opened
    (vlax-for
      objFileDep
(setq
  rtlist (cons
   (cons
     ;;(list
     (write-line
       opened
   rtlist
    rtlist
   (setq ProjectName
  (dos_getini
    "PROJECTS"
    (getvar "users1")
   (setq projectDesc
    (setq datestring
   (strcat MON2
   DAY
   YEAR
   NHRS
   (substr DATST 12 2)
   XTR
  (setq mainfilter
(getstring
   T
   "\n* Input prefix filter for Main Xrefs: [*] "
    (setq mainfilter "*")
  (setq filter
(getstring T
    "\n* Input prefix filter for Nested Xrefs: [*] "
  (if (= filter "")
    (setq filter "*")
    (vlax-for item bl
  (setq n 0)
  (vlax-for xr item
nestedname
       (setq n (1+ n))
    n
    (foreach i lst
  (if (listp (cdr i))
    (reverse newlst)
    (foreach i lst
      (setq ii i)
(strcase filter)
(setq ii nil)
   (strcase filter)
     (setq ii nil)
    (reverse newlst)
tempEnt XrefList
NonNestedXrefList
NestedXrefList
    (setq NestList
   (cons
     (cons
       (cdr i)
     NestList
      NestList
  (setq XrefList
(cons
   (cons
     tempEnt
   XrefList
    (foreach i XrefList
    NonNestedXrefList
  (setq n 1)
    (length (Flatten (FilterNestedXrefs (GetXrefNesting) mainfilter filter)))
  (ARCH:DATE2)
  (ARCH:ProjectName)
1
     FileName
     "w"
  (write-line
    opened
  (write-line
    FileName
    opened
  (write-line
    opened
    (foreach
      i
       (vl-sort
lst
(function
   (lambda (a b)
(write-line
  (strcat ""
  spc
  " Nested xref: "
  mainname
  opened
      (PrintNestedList
(if (cdr i)
  (cdr i)
  nil
(strcat "  " spc)
    (setq n (+ n 1))
  (foreach
    i
     (vl-sort
       (function
(lambda (a b)
    (write-line
      opened
    (setq n (+ n 1))
    (PrintNestedList
nil
  (xrefs-list)
  (if Opened
    (close Opened)
    FileName
Regards, M.R.
« Last Edit: December 12, 2011, 08:49:08 AM by ribarm »
M.R. on Youtube
GDF
« Reply #18 on: December 11, 2011, 04:41:30 PM »
Marko
Thanks for the feedback, I still need to some error and var checking. It works smoothly with no errors. I'm sure to break it later on. Thanks for the corrections! I have since added the word "Total" after the count.
I like your YouTube videos.
Thanks again for your help.
Gary
« Last Edit: December 11, 2011, 04:49:35 PM by GDF »
GDF
« Reply #19 on: December 11, 2011, 10:14:02 PM »
Marko, If your looking for another challenge, what about adding a total count per each of the Nested xrefs per each of the Main xrefs?
Will this require another function to count up the total of all Nested xrefs per each Main xref?
Modifing the "PrintNestedList" function to include this totaling up process?
Can you point me in the right direction.
        Project Name : [Merritt Lakeside Sr Village]
        Directory is: [F:\Jobs\2009\091138\acad\building\BL-Profile2]
        December 11, 2011 8:18 p.m.
 [ ] Main xref: BL-01 - 2 Total
     > Nested xref: UTA2 - 7 Total
     > Nested xref: UTA3 - 6 Total
     > Nested xref: UTA5 - 3 Total
     > Nested xref: UTB1 - 3 Total
     > Nested xref: UTB3b - 6 Total
     > Nested xref: UTB3c - 6 Total
     > Nested xref: UTB4a - 6 Total
     > Nested xref: UTB4b - 6 Total
        Total Count (2 x 37 = 74 Grand Total)  <-- new output
       (2 Main xrefs) x (Nested xref total) = Grand Total
ribarm
« Reply #20 on: December 12, 2011, 06:22:45 AM »
All I can do is to count Xrefs per branch, and in format like this :
        Directory is: [C:\Documents and Settings\Marica\Desktop\xrefs\xrefss]
        December 12, 2011 2:28 p.m.
 [ ] Main xref: xrefs2 - 1
     > Nested xref: Drawing2 - 1
       > Nested xref: ex2 - 3
         > Nested xref: ex4 - 2
---------- Total count per branch : 2 ----------
---------- Total count per branch : 3 ----------
     > Nested xref: Drawing3 - 1
     > Nested xref: Drawing4 - 1
 [ ] Main xref: xrefs3 - 1
     > Nested xref: Drawing1 - 2
       > Nested xref: ex1 - 2
         > Nested xref: ex3 - 1
         > Nested xref: ex4 - 1
       > Nested xref: ex2 - 1
---------- Total count per branch : 5 ----------
 C:\Documents and Settings\Marica\Desktop\xrefs\xrefs3.dwg
 C:\Documents and Settings\Marica\Desktop\xrefs\Drawing1.dwg
 C:\Documents and Settings\Marica\Desktop\xrefs\Drawing3.dwg
 C:\Documents and Settings\Marica\Desktop\xrefs\Drawing4.dwg
 C:\Documents and Settings\Marica\Desktop\xrefs\Drawing2.dwg
 C:\Documents and Settings\Marica\Desktop\xrefs\ex1.dwg
 C:\Documents and Settings\Marica\Desktop\xrefs\ex2.dwg
 C:\Documents and Settings\Marica\Desktop\xrefs\ex3.dwg
 C:\Documents and Settings\Marica\Desktop\xrefs\ex4.dwg
 C:\Documents and Settings\Marica\Desktop\xrefs\xrefs2.dwg
You can see that firstly it counts last branch, and when needed to separate results it prints counts from previous branch... So if you have only 1 branch like in your case it will do fine, but you must multiply branch with number of main xref count manually...
   datestring n
;;;Arguments: none
;;;Mike Weaver
    (write-line
      (strcat
      opened
    (vlax-for
      objFileDep
(setq
  rtlist (cons
   (cons
     ;;(list
     (write-line
       opened
   rtlist
    rtlist
   (setq ProjectName
  (dos_getini
    "PROJECTS"
    (getvar "users1")
   (setq projectDesc
    (setq datestring
   (strcat MON2
   DAY
   YEAR
   NHRS
   (substr DATST 12 2)
   XTR
  (setq mainfilter
(getstring
   T
  (setq filter
(getstring T
  (if (= filter "")
    (setq filter "*")
    (vlax-for item bl
  (setq n 0)
  (vlax-for xr item
nestedname
       (setq n (1+ n))
    n
    (foreach i lst
  (if (listp (cdr i))
    (reverse newlst)
    (foreach i lst
      (setq ii i)
(strcase filter)
(setq ii nil)
   (strcase filter)
     (setq ii nil)
    (reverse newlst)
tempEnt XrefList
NonNestedXrefList
NestedXrefList
    (setq NestList
   (cons
     (cons
       (cdr i)
     NestList
      NestList
  (setq XrefList
(cons
   (cons
     tempEnt
   XrefList
    (foreach i XrefList
    NonNestedXrefList
  (setq n 1)
  (ARCH:DATE2)
  (ARCH:ProjectName)
1
     FileName
     "w"
  (write-line
    opened
  (write-line
    FileName
    opened
  (write-line
    opened
  (defun PrintNestedList (lst spc mainname / lstn k)
    (foreach
      i
       (setq lstn (vl-sort
lst
(function
   (lambda (a b)
(write-line
  (strcat ""
  spc
  " Nested xref: "
  mainname
  opened
      (PrintNestedList
(if (cdr i)
  (cdr i)
  nil
(strcat "  " spc)
    (setq n (+ n 1))
(setq k 0)
(foreach i lstn
  (setq k (+ k (nestedxrefcount mainname (cdr (assoc 2 (entget (car i))))) ))
(if lstn (write-line (strcat "---------- Total count per branch : " (itoa k) " ----------") opened))
  (foreach
    i
     (vl-sort
       (function
(lambda (a b)
    (write-line
      opened
    (setq n (+ n 1))
    (PrintNestedList
nil
  (xrefs-list)
  (if Opened
    (close Opened)
    FileName
M.R.
« Last Edit: December 12, 2011, 08:49:43 AM by ribarm »
M.R. on Youtube
ribarm
« Reply #21 on: December 12, 2011, 08:55:21 AM »
I've changed to this :
    (PrintNestedList
nil
I think that only with this intervention filters work OK as they should...
Marko
Gary
You're welcome...
M.R.
M.R. on Youtube
GDF
« Reply #22 on: December 12, 2011, 11:17:40 AM »
Marko
Thanks again.
One last question. Had been working at home, so this in the office this morning, I ran the previous routine.
I get this error on some drawing files that has a nested xref that does not match the filter entered.
One of the nested xrefs starts with "E" for example. I think this is happening because of the filted counting of a nested xref that does not exist. Can't do the math with nil? I don't know.
  • BL*
  • UT*
* Please Wait while the Program is Running...; error: bad argument type:
lentityp nil
Gary
GDF
« Reply #23 on: December 12, 2011, 12:04:17 PM »
Marko
Thanks again.
  • BL*
  • UT*
lentityp nil
Gary
I disabled the acet progress abr and it fixed the error, but no nested xrefs were listed in the main xref that did not match the filter:
 [ ] Main xref: BL-01 - 1 Total
    Missing nested xrefs, because xref name was filtered out
 [ ] Main xref: BL-02 - 1 Total
     > Nested xref: UTA20750-HC - 3 Total
     > Nested xref: uta20781 - 9 Total
     > Nested xref: UTB10950-a - 3 Total
     > Nested xref: UTB10950-hc - 3 Total
     > Nested xref: utb31032 - 12 Total
       Total Count = 30
     > Nested xref: ElevLobby1 - 1 Total
     > Nested xref: UTA20750-HCa - 3 Total
     > Nested xref: UTA2a-MEN - 1 Total
     > Nested xref: UTA2a-STORAGE - 1 Total
     > Nested xref: UTA2a-WOMEN - 1 Total
     > Nested xref: utb31032 - 15 Total
       Total Count = 31
ribarm
« Reply #24 on: December 12, 2011, 12:12:32 PM »
lentityp nil
Gary
Gary, that's wright it doesn't show data for nested xrefs that do not match filter, and that means also for main xref filter...
Tell me is this error happening with my latest intervention on code?
M.R.
M.R. on Youtube
GDF
« Reply #25 on: December 12, 2011, 12:23:40 PM »
Marko
I tried it on both codes. Same problem with in the same drawing.
The nested xref starts with an E and is filtered out. This occurs here:
[ ] Main xref: BL-01 - 1 Total (here it does not work)
And again here: (but here it works and is filtered out)
       Total Count = 30
ribarm
« Reply #26 on: December 12, 2011, 01:25:15 PM »
Gary, as far as I know, you don't have nested Xrefs that starts with E in all your main Xrefs, and this is why it don't shows any of them... You must have E* nested xrefs within all of your main Xrefs to recognize them and show them... Tell me though, does error occurs?
M.R.
Look, this filter I've made isn't really as expected, but this is as much near to what it should be. I would created real list from Tim's list of xrefs if that wasn't so complex, so I just excluded all possible next nested filter matches if not occur in all parent element associations of original list, and parent element association is referenced only on main xrefs and filter only on first nested branch of xrefs...
« Last Edit: December 12, 2011, 02:15:47 PM by ribarm »
M.R. on Youtube
GDF
« Reply #27 on: December 12, 2011, 03:30:00 PM »
Marko
I do have nested Xrefs that starts with "E" and "O" in some of Nested Xrefs, but not all. I can not get the filter input prefix to work, for any condition. I am just trying to understand what is wrong. You have been very nice to help me (even doing the work). My programming abilities are limited.
I can't even get this to work: testing --> (setq mainfilter "*" filter "UT*")
Result:
 [ ] Main xref: BL-01 = 2 Count
 [ ] Main xref: BL-02 = 2 Count
 [ ] Main xref: BL-CLUB = 1 Count
Testing ---> (setq mainfilter "*" filter "*")
Result:
     > Nested xref: ElevLobby1 = 1 Count    <--filter out
     > Nested xref: Outine = 5 Count   <-- filter out
     > Nested xref: UTA10780 = 5 Count
     > Nested xref: UTA10780r = 2 Count
     > Nested xref: UTA20780 = 1 Count
     > Nested xref: UTA20780-HC = 1 Count
     > Nested xref: UTA20780r = 1 Count
     > Nested xref: UTB21028 = 8 Count
     > Nested xref: UTB21028-HC = 2 Count
     > Nested xref: UTB21028r = 4 Count
     > Nested xref: UTB21028r-HC = 1 Count
       Total Count = 31/Main Xref
     > Nested xref: ElevLobby2 = 1 Count   <-- filter out
     > Nested xref: UTA10780 = 4 Count
     > Nested xref: UTA20780 = 2 Count
     > Nested xref: UTB21028rx = 1 Count
     > Nested xref: UTB21028x = 2 Count
       Total Count = 30/Main Xref
     > Nested xref: BL-Dormer6 = 1 Count   <-- filter out
     > Nested xref: KeyPlan = 2 Count   <-- filter out
     Total Count = 8/Main Xref
Anyway you have done WAY more than I could ever have expected. Thanks.
Gary
« Last Edit: December 12, 2011, 03:39:04 PM by GDF »
ribarm
« Reply #28 on: December 12, 2011, 07:17:47 PM »
Here I revised my code for the last time... Now filters work as they really expected... Still I am not sure why do you have wrong results with mainfilter * and filter *... But I fixed issue of showing nested xrefs if they exist in main xref (no matter if exist in all xrefs)... So here is code :
   datestring n
;;;Arguments: none
;;;Mike Weaver
    (write-line
      (strcat
      opened
    (vlax-for
      objFileDep
(setq
  rtlist (cons
   (cons
     ;;(list
     (write-line
       opened
   rtlist
    rtlist
   (setq ProjectName
  (dos_getini
    "PROJECTS"
    (getvar "users1")
   (setq projectDesc
    (setq datestring
   (strcat MON2
   DAY
   YEAR
   NHRS
   (substr DATST 12 2)
   XTR
  (setq mainfilter
(getstring
   T
  (setq filter
(getstring T
  (if (= filter "")
    (setq filter "*")
    (vlax-for item bl
  (setq n 0)
  (vlax-for xr item
nestedname
       (setq n (1+ n))
    n
    (foreach i lst
  (if (listp (cdr i))
    (reverse newlst)
    (foreach i lst
      (setq ii i)
(strcase filter)
(setq ii nil)
      (cond ((if (and (listp (cdr i)) (member (car i) ii)) (filternested (cdr i) filter) (setq ii nil)))
  (not (eq (cdr i) nil))
    (reverse newlst)
tempEnt XrefList
NonNestedXrefList
NestedXrefList
    (setq NestList
   (cons
     (cons
       (cdr i)
     NestList
      NestList
  (setq XrefList
(cons
   (cons
     tempEnt
   XrefList
    (foreach i XrefList
    NonNestedXrefList
  (setq n 1)
    (length (Flatten (progn
               (setq kk nil)
       (foreach k (vl-remove nil (FilterNestedXrefs (GetXrefNesting) mainfilter filter))
(setq k (vl-remove nil k))
(setq kk (cons k kk))
       (reverse kk)
  (ARCH:DATE2)
  (ARCH:ProjectName)
1
     FileName
     "w"
  (write-line
    opened
  (write-line
    FileName
    opened
  (write-line
    opened
  (defun PrintNestedList (lst spc mainname / lstn k kk )
    (foreach
      i
       (setq lstn (vl-sort
lst
(function
   (lambda (a b)
(write-line
  (strcat ""
  spc
  " Nested xref: "
  mainname
  opened
      (PrintNestedList
(if (cdr i)
  (cdr i)
  nil
(strcat "  " spc)
    (setq n (+ n 1))
(setq k 0)
(foreach i lstn
(if lstn (write-line (strcat spc " *** Total count per branch : " (itoa k) " *** ") opened))
  (foreach
    i
     (vl-sort
               (setq kk nil)
       (reverse kk)
       (function
(lambda (a b)
    (write-line
      opened
    (setq n (+ n 1))
    (PrintNestedList
nil
  (xrefs-list)
  (if Opened
    (close Opened)
    FileName
Regards, M.R.
« Last Edit: December 14, 2011, 06:11:03 AM by ribarm »
M.R. on Youtube
GDF
« Reply #29 on: December 12, 2011, 10:53:55 PM »
Marko
Thanks again. Tried it here at home and your new code has solved the problem. Will try it at the office on more files tomorrow.
I see where you updated the code...I'm totally lost in how it works. Thanks again for you hard work and patience. This routine will be a great time saver in reviewing our project files with nested xrefs.
Gary
Updated Output File:
        December 12, 2011 10:52 p.m.
 [X] Parent Drawing: BL-Profile2
    [ ] Main Xref: BL-01 = 2 Count
       [ ] Nested Xref: UTA2 = 6 Count
       [ ] Nested Xref: UTA3 = 6 Count
       [ ] Nested Xref: UTA5 = 3 Count
       [ ] Nested Xref: UTB1 = 3 Count
       [ ] Nested Xref: UTB3b = 6 Count
       [ ] Nested Xref: UTB3c = 6 Count
       [ ] Nested Xref: UTB4a = 6 Count
       [ ] Nested Xref: UTB4b = 6 Count
           Total Count = 42 Nested/Main
    [ ] Main Xref: BL-02 = 2 Count
       [ ] Nested Xref: UTB3a = 6 Count
       [ ] Nested Xref: UTB4c = 6 Count
           Total Count = 30 Nested/Main
    [ ] Main Xref: BL-CLUB = 1 Count
 F:\Jobs\2009\091138\ACAD\building\BL-01.dwg
 F:\Jobs\2009\091138\ACAD\building\BL-02.dwg
 F:\Jobs\2009\091138\ACAD\club\BL-CLUB.dwg
 F:\Jobs\2009\091138\ACAD\units\UTA2.dwg
 F:\Jobs\2009\091138\ACAD\units\UTB1.dwg
 F:\Jobs\2009\091138\ACAD\units\UTA5.dwg
 F:\Jobs\2009\091138\ACAD\units\UTB3b.dwg
 F:\Jobs\2009\091138\ACAD\units\UTB4b.dwg
 F:\Jobs\2009\091138\ACAD\units\UTB4a.dwg
 F:\Jobs\2009\091138\ACAD\units\UTA3.dwg
 F:\Jobs\2009\091138\ACAD\units\UTB3c.dwg
 F:\Jobs\2009\091138\acad\building\Key.dwg
 F:\Jobs\2009\091138\ACAD\units\UTB4c.dwg
 F:\Jobs\2009\091138\ACAD\units\UTB3a.dwg
« Last Edit: December 12, 2011, 11:55:34 PM by GDF »
GDF
« Reply #30 on: December 13, 2011, 08:27:17 PM »
Here is the final version. Special thanks to Marko!
Example of print out file:
        December 13, 2011 7:19 p.m.
       [ ] Nested Xref: Key    = 1 Count
           Total Nested per each Main Xref      = 43 Count
           Total Nested per each Main Xref      = 31 Count
Updated code:
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Project Name Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun ARCH:ProjectName (/)
  (setq ARCH#PROJ (nth 3 (ARCH:Split (getvar "dwgprefix") "\\")))
  (cond ((/= (atoi ARCH#PROJ) 0) (setvar "users1" ARCH#PROJ)))
   (setq ARCH#PNAM
  (dos_getini
    "PROJECTS"
    (getvar "users1")
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Date Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
    (setq ARCH#DATE ;datestring
   (strcat MON2
   DAY
   YEAR
   NHRS
   (substr DATST 12 2)
   XTR
;;; prints nested xref tree to command line, no matter how deep the nesting.
;;; http://www.theswamp.org/index.php?topic=28062.msg337119#msg337119
;;; major editing and rewrite by Marko Ribar
;;; added output file with project header and routine progress bar and xref paths
(defun PrintXrefNestingIT  (/ mainfilter filter opened projectDesc projectName datestring n)
  (princ "\n*** ------ Print Xref Nested Routine ----- ***")
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Sub Routines ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;;; External routines: (ARCH:DATE2) and (ARCH:ProjectName)
  (defun Flatten  (l)
    (if (atom l)
      (list l)
              (if (cdr l)
                (Flatten (cdr l))))))
  ;; Function: xrefs-list
  ;; Purpose: get information regarding xrefs
  ;; Arguments: none
  ;; Returns: rtlist - a list of lists, one for each xref, as follows:
  ;; by Mike Weaver
    (write-line
      (strcat
      opened)
    (vlax-for
           objFileDep  (vla-get-filedependencies
        (setq rtlist
               (cons
                 (cons
                   ;;(list
                   (write-line (strcat " " (vla-get-fullfilename objFileDep)) opened))
                 rtlist))))
    rtlist)
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Main Routine ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  (setq mainfilter (getstring T "\n* Input prefix filter for Main Xrefs: [*] "))
    (setq mainfilter "*"))
  (setq filter (getstring T "\n* Input prefix filter for Nested Xrefs: [*] "))
  (if (= filter "")
    (setq filter "*"))
    (vlax-for
           item  bl
          (setq n 0)
          (vlax-for
                 xr  item
              (setq n (1+ n)))))))
    n)
  (defun FilterNestedXrefs  (lst mainfilter filter / ifillst inewlst newlst)
    (foreach
           i  lst
               (wcmatch
        (progn (if (listp (cdr i))
                 (progn (setq ifillst (filternested (cdr i) filter))
                        (setq newlst (cons inewlst newlst)))
                 (setq newlst (cons i newlst))))))
    (reverse newlst))
    (foreach
           i  lst
      (setq ii i)
        (setq ii nil))
               (setq ii nil)))
            ((and (atom (cdr i)) (not (eq (cdr i) nil))) ())
            ((eq (cdr i) nil) nil))
      (setq newlst (cons ii newlst)))
    (reverse newlst))
  (defun GetXrefNesting  (/ tempData tempEnt XrefList NonNestedXrefList NestedXrefList)
      (foreach
          (progn (setq NestedList (cons (cdr i) NestedList))
                 (setq NestList (cons (cons (cdr i) (GetXrefInfo (cdr i))) NestList)))))
      NestList)
        (progn (setq tempEnt (tblobjname "block" (cdr (assoc 2 tempData))))
               (setq XrefList (cons (cons tempEnt (GetXrefInfo tempEnt)) XrefList)))))
    (foreach
           i  XrefList
        (setq NonNestedXrefList (cons i NonNestedXrefList))))
    NonNestedXrefList)
  (setq n 1)
    (length
      (Flatten
          (setq kk nil)
          (foreach
                 k
            (setq kk (cons k kk)))
          (reverse kk)))))
  (ARCH:DATE2)
  (ARCH:ProjectName)
                             "Arch "
                             ARCH#PROJ
                             FileName
                     "w"))
  (write-line
    opened)
  (cond ((= ARCH#PNAM nil) (setq ProjectDesc ""))
        ((/= ARCH#PNAM nil)
         (setq projectDesc (strcat "        Project Name : [" ARCH#PNAM "]"))))
  (write-line
    (strcat "        Directory is: [" (getvar "dwgprefix") FileName "]")
    opened)
  (write-line (strcat "        " ARCH#DATE) opened) ;DATE-STRING
  (write-line
    opened)
  (write-line (strcat "\n [X] Parent Drawing: " FileName) opened)
  (defun PrintNestedList  (lst spc mainname / lstn k kk)
    (foreach
           i  (setq lstn (vl-sort
                           lst
                           (function
                             (lambda (a b)
                               (< (strcase (cdr (assoc 2 (entget (car a)))))
                                  (strcase (cdr (assoc 2 (entget (car b))))))))))
        (write-line
          (strcat ""
                  spc
                  " Nested Xref: "
                  "\t = "
                  " Count")
          opened)
        (prompt (strcat "\n" spc " Nested Xref: nil")))
      (PrintNestedList
        (if (cdr i)
          (cdr i)
          nil)
        (strcat "  " spc)
      (setq n (+ n 1)))
    (setq k 0)
    (foreach
           i  lstn
      (setq k (+ k (nestedxrefcount mainname (cdr (assoc 2 (entget (car i))))))))
    (progn (if lstn
             (write-line
               opened))
           (if lstn
             (write-line
               (strcat "           Total Nested per each Main Xref      = "
                       (itoa k)
                       " Count\n")
               opened))
  (foreach
         i
         (vl-sort
           (progn (setq kk nil)
                  (foreach
                         k  (vl-remove
                              nil
                  (reverse kk))
           (function
             (lambda (a b)
    (write-line
      (strcat "    [ ] Main Xref: "
              "\t\t\t = "
              (itoa (sslength
                      (ssget "_X"
              " Count")
      opened)
    (setq n (+ n 1))
    (PrintNestedList
        nil)
  (xrefs-list)
  (if Opened
    (close Opened))
  (startapp
    "notepad.exe"
            "Arch "
            ARCH#PROJ
            FileName
  (princ))
« Last Edit: December 13, 2011, 08:34:19 PM by GDF »
ribarm
« Reply #31 on: December 14, 2011, 06:08:29 AM »
Gary, I would still suggest you that you use this line for count sum :
Imagine that you don't have only one branch of Xrefs like this :
        December 14, 2011 12:06 p.m.
         > *** Total count per branch : 2 ***
       > *** Total count per branch : 3 ***
     > *** Total count per branch : 5 ***
In this case, this way of summing counter would be more appropriate... I will update my code above...
M.R.
M.R. on Youtube
GDF
« Reply #32 on: December 14, 2011, 09:02:41 AM »
Thanks again...it's almost beer Friday...
Koenig
« Reply #33 on: December 23, 2011, 05:46:47 AM »
Hi guys, this is looking exactly like the tool i've been looking for, for a long time now. I'm currently employed at a company that produces modular housing units, which means a lot of x-ref work i acad.
To ease the process of summing up the different elements used in each unit, i'd like to implement your work with this programming, but being a novice at lisps and programming, i have no idea how to make this work.
Please guide me and help me elliminate the slave work of counting elements 'by hand'?
And ofc, a wish of happy hollidays to you all.
Rune Christensen,
BM Byggeindustri, Hobro
Denmark
ribarm
« Reply #34 on: December 23, 2011, 07:42:21 AM »
I removed sub with showing project description - not necessary for my needs...
Here is *.lsp that should work on all CAD environments...
Use APPLOAD command and select *.lsp ... Execution is : PRINTXREFNESTINGIT
(defun c:PrintXrefNestingIT ( / Flatten xrefs-list ARCH:DATE2 mainfilter filter nestedxrefcount FilterNestedXrefs filternested GetXrefNesting n kk k datestring FileName opened PrintNestedList projectDesc projectName ACET:UI-PROGRESS-FACTOR )
  (defun xrefs-list nil
    (write-line "----------------------------------------------------------------------" opened)
    (vlax-for
      objFileDep
        (write-line
          opened
  (defun ARCH:DATE2 (/ DATST MON DAY YEAR HRS MON2 NHRS XTR)
      ( (= MON "01") (setq MON2 "January") )
      ( (= MON "02") (setq MON2 "Feburary") )
      ( (= MON "03") (setq MON2 "March") )
      ( (= MON "04") (setq MON2 "April") )
      ( (= MON "05") (setq MON2 "May") )
      ( (= MON "06") (setq MON2 "June") )
      ( (= MON "07") (setq MON2 "July") )
      ( (= MON "08") (setq MON2 "August") )
      ( (= MON "09") (setq MON2 "September") )
      ( (= MON "10") (setq MON2 "October") )
      ( (= MON "11") (setq MON2 "November") )
      ( (= MON "12") (setq MON2 "December") )
      ( (= HRS 00) (setq NHRS (itoa (+ HRS 12))) (setq XTR "a.m.") )
      ( (< HRS 12) (setq NHRS (itoa HRS)) (setq XTR "a.m.") )
      ( (= HRS 12) (setq NHRS (itoa HRS)) (setq XTR "p.m.") )
      ( (> HRS 12) (setq NHRS (itoa (- HRS 12))) (setq XTR "p.m.") )
    (setq datestring (strcat MON2 " " DAY ", " YEAR " " NHRS ":" (substr DATST 12 2) " " XTR))
  (setq mainfilter
    (getstring
      T
  (setq filter
    (getstring T
  (if (= filter "")
    (setq filter "*")
    (vlax-for item bl
          (setq n 0)
          (vlax-for xr item
              (setq n (1+ n))
    n
    (foreach i lst
          (if (listp (cdr i))
    (reverse newlst)
    (foreach i lst
      (setq ii i)
      (if (not (and (atom (car i)) (wcmatch (strcase (cdr (assoc 2 (entget (car i))))) (strcase filter))))
        (setq ii nil)
        ( (if (and (listp (cdr i)) (member (car i) ii)) (filternested (cdr i) filter) (setq ii nil)) )
        ( (and (atom (cdr i)) (not (eq (cdr i) nil)))
          nil
        ( (eq (cdr i) nil)
          nil
    (reverse newlst)
  (defun GetXrefNesting ( / GetXrefInfo tempData tempEnt XrefList NonNestedXrefList NestedXrefList NestedList )
            (setq NestList
              (cons
                (cons
                  (cdr i)
                NestList
      NestList
          (setq XrefList
            (cons
              (cons
                tempEnt
              XrefList
    XrefList
  (setq n 1)
    (length
      (Flatten
          (setq kk nil)
          (reverse kk)
  (ARCH:DATE2)
  (setq opened (open (strcat (getvar "dwgprefix") FileName " PrintXrefNesting.txt") "w"))
  (write-line
    opened
  (write-line (strcat "        Directory is: [" (getvar "dwgprefix") FileName "]") opened)
  (write-line
    opened
  (defun PrintNestedList ( lst spc mainname / lstn k kk )
    (foreach i (setq lstn (vl-sort lst (function (lambda ( a b ) (< (strcase (cdr (assoc 2 (entget (car a))))) (strcase (cdr (assoc 2 (entget (car b))))))))))
        (write-line
          (strcat "" spc " Nested xref: " (cdr (assoc 2 (entget (car i)))) " - " (itoa (nestedxrefcount mainname (cdr (assoc 2 (entget (car i)))))))
          opened
      (PrintNestedList
        (if (cdr i)
          (cdr i)
          nil
        (strcat "  " spc)
      (setq n (1+ n))
    (setq k 0)
    (foreach i lstn
  (foreach i
    (vl-sort
        (setq kk nil)
        (reverse kk)
      (function
        (lambda ( a b )
    (if (ssget "_A" (list '(0 . "INSERT") (assoc 2 (entget (car i))) (cons 410 (if (= 1 (getvar 'cvport)) (getvar 'ctab) "Model"))))
        (write-line
          (strcat "\n [ ] Main xref: " (cdr (assoc 2 (entget (car i)))) " - " (itoa (sslength (ssget "_A" (list '(0 . "INSERT") (assoc 2 (entget (car i))) (cons 410 (if (= 1 (getvar 'cvport)) (getvar 'ctab) "Model")))))))
          opened
        (setq n (1+ n))
        (PrintNestedList
  (if (> (vla-get-count (vla-get-filedependencies (vla-get-activedocument (vlax-get-acad-object)))) 0)
    (xrefs-list)
  (if Opened
    (close Opened)
    FileName
Regards, M.R.
:wink:
« Last Edit: October 05, 2022, 04:34:18 AM by ribarm »
M.R. on Youtube
Koenig
« Reply #35 on: December 27, 2011, 05:32:38 AM »
It works and it is exactly what i was looking for. Thanks guys! This lisp just removed a lot of slavework from my job and added a nice system om element-management.
Best wishes for a great 2012 for you all.
GDF
« Reply #36 on: December 28, 2011, 11:13:09 AM »
Update code for xref nesting with my personal filters and formatting of the print out file with added text padding. I know there is a better more cleaner way of coding this. My personal xrefs print out results are only needed two levels deep. The main reason being to count up the unit plans per building plan within an overall "profile" building with multiple buildings.
The padding format for the text print out is only to pretty up the printed results. Thanks again to Marko for his help. The updated code will of course have to be modified to work for your environment. I have included the updated code and a printed test example.
Gary
« Last Edit: December 28, 2011, 11:17:37 AM by GDF »
ribarm
« Reply #37 on: May 31, 2018, 04:51:56 AM »
Inspired by Lee's blockhierarchy.lsp, I developed further more Xref nesting to account and for nesting of blocks...
http://www.cadtutor.net/forum/showthread.php?48702-Find-nested-blocks/page3&p=#21
HTH., M.R.
M.R. on Youtube
