Author Topic: I think my brain went on vacation  (Read 8075 times)
PDJ
« on: February 14, 2005, 03:55:50 PM »
What I'm trying to do is this:
We have 60 villages that we provide telephone support to in the bush here in Alaska.  Each village has it's own directory and under each directory is a map with the villages exchange number as a name (i.e. 231oa.dwg).
What I'm trying to do is write a simple lisp that when loaded will have all my village directories and map names in there so that when I'm in AutoCad, I can just type x231 on the command line and it will open that villages map.
I know that filedia has to be switched to 0 at the start and returned to 1 at the end.
Here's what I have that isn't working so far.. :D
(defun C:X231()
  (command "filedia" "0")
  (command "OPEN" "T:\\PRM\\Birch Creek\\231OA.DWG" )
  (command "filedia" "1")
I'm getting the following as an error:
Unknown command "T:\PRM\BIRCH CREEK\231OA.DWG"
I've tried with without the quotes but then it just gives me a nil..
I'm pretty sure this is a simple fix but, I can think very hard today..  Any help is greatly appreciated.  My brain is fried from a lovely flu virus I've had for the last 4 days..
Thanks!
PDJ
« Reply #1 on: February 14, 2005, 07:13:06 PM »
Is this a toughie?? 24 views so far and no comments or anything??  Hmmm..
« Reply #2 on: February 14, 2005, 07:47:08 PM »
« Reply #3 on: February 14, 2005, 07:48:34 PM »
Here is another one to try.
(command "vbastmt" (strcat
   "AcadApplication.Documents.Open " (chr 34) filnam (chr 34)))
« Reply #4 on: February 14, 2005, 08:01:55 PM »
I use a variation of this :
(defun c:xtest ()
  (if (setq tmp (findfile "F:\\Develop\\test\\Standards-012.DWG"))
    (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) tmp))
    (alert "Can't find file : \n F:\\Develop\\test\\Standards-012.DWG")
PDJ
« Reply #5 on: February 14, 2005, 08:40:57 PM »
Dag nabbit CAB, I tole yas my brain was fried.. hehe..   I think Kerry's is close enough.. Now I just gotta copy it 60 times in my lisp file and change all the name..
Thanks for the help you two!!
« Reply #6 on: February 14, 2005, 08:46:19 PM »
Quote from: PDJ
<snip> .. Now I just gotta copy it 60 times in my lisp file and change all the name.. </snip>
Your kidding right?!
« Reply #7 on: February 14, 2005, 09:38:36 PM »
Set the value of SDI to 1 and you "should" be able to use the (command "open" ...) without incident.
When the SDI interface was implemented, "open" was modified and the problems started.
PDJ
« Reply #8 on: February 15, 2005, 01:19:45 PM »
se7en, that's how many different paths I have to be able to access.  This is the main reason I wanted a routine like this.  If I'm missing something, please let me know..
« Reply #9 on: February 15, 2005, 01:50:31 PM »
PDJ,
Your a beginner at lisp right?
<spell check police>
« Reply #10 on: February 15, 2005, 02:02:30 PM »
"You are a" or "You're a", but not "your a".
<spank.mpg>
« Reply #11 on: February 15, 2005, 02:08:20 PM »
hummm?! Hey while i have your attention officer; Could you tell me if i spelled this right?
BAN!!!
« Reply #12 on: February 15, 2005, 02:25:03 PM »
Quote from: PDJ
PDJ, rather than rewriting a routine for each path, create a routine that will define the lisps for you. By creating a master list that you can add to, delete from, modify at will it will make your job now, and in the future, much easier.
For instance:
(defun c:make_the_lisps (/ master_list)
  (setq master_list '(("231" . "Path-to-231.dwg")
     ("491" . "Path-to-491.dwg")
     ;add all your villages like so
  (foreach village master_list
    (eval (read (strcat "(defun " "c:x" (car village)
" () (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object))\""
(cdr village) "\")))")
This will create a new lisp function that can be called from the command line, as you said you wanted, for each village listed in the master_list. Then you just need to call this one lisp in your acaddoc.lsp file
Is that what you had in mind Se7en?
« Reply #13 on: February 15, 2005, 02:35:25 PM »
*blink*
*sigh*
No.
I was gonna show him 'arguments'.
show-off!
:P :D
« Reply #14 on: February 15, 2005, 03:45:18 PM »
How about this, Paul?
You enter XLD 232 [enter] at the command line.
The space between D & 2 starts the routine.
You will have to maintain the list within the lisp.
You could use a text file read routine to read the list from a text file.
;;  X Load
(defun c:xld (/ ac_list ac filen tmp)
  (setq ac_list
         (list
           (list "231" "T:\\PRM\\Birch Creek\\231OA.DWG")
           (list "232" "T:\\PRM\\Birch Creek\\232OA.DWG")
           (list "233" "T:\\PRM\\Birch Creek\\233OA.DWG")
  (if (setq ac (getstring "\nEnter the area code for the project to load. "))
    (if (setq filen (assoc ac ac_list))
        (setq filen (cdr filen))
         ;;  from Kerry Brown
        (if (setq tmp (findfile filen))
          (vla-activate
          (alert (strcat "Can't find file : " filen))
      (alert (strcat filen " is not in the list."))
(prompt "\n***  XLD loaded, enter XLD followed by the area code to run [XLD 321].")
