Author Topic: set parameters and count blocks in associative array  (Read 4170 times)
Eycki
« on: December 09, 2011, 07:16:43 AM »
Hello, I am wondering if it is possible to approach the 2012 Array from AutoCAD and set its properties with .NET
I haven't found a solution on the internet yet, so at this moment I'm using it with the SendStringToExecute command.  It does the job but it's a lot slower as it could be with proper coding.
« Last Edit: December 09, 2011, 09:49:59 AM by Eycki »
kaefer
Re: Approaching Array 2012
« Reply #1 on: December 09, 2011, 07:23:36 AM »
The keyword is Associative Array, like that found here.
Eycki
« Reply #2 on: December 09, 2011, 07:41:56 AM »
I see this article is pretty recent , that is why I didnt found it a couple months ago :-)
Thanks a lot!
Eycki
« Reply #3 on: December 09, 2011, 09:48:56 AM »
Do you have any idea how to count blocks in an associative array?
Re: set parameters and count blocks in associative array
« Reply #4 on: December 09, 2011, 06:28:33 PM »
Yes
Code - C#: [Select]
  1. [Wrapper("AcDbAssocArrayPathParameters"), TypeDescriptionProvider("Autodesk.AutoCAD.ComponentModel.TypeDescriptionProvider`1[[Autodesk.AutoCAD.DatabaseServices.AssocArrayPathParameters, acdbmgd]], acdbmgd")]
  2. public class AssocArrayPathParameters : AssocArrayCommonParameters
  3. {
  4.     // Methods
  5.     public AssocArrayPathParameters();
  6.     protected internal AssocArrayPathParameters(IntPtr unmanagedPointer, [MarshalAs(UnmanagedType.U1)] bool autoDelete);
  7.     public AssocArrayPathParameters(double itemSpacing, double rowSpacing, double levelSpacing, int itemCount, int rowCount, int levelCount, double rowElevation);
  8.     public double GetEndOffset(out string expression, out string evaluatorId);
  9.     internal unsafe AcDbAssocArrayPathParameters* GetImpObj();
  10.     public int GetItemCount(out string expression, out string evaluatorId);
  11.     public double GetItemSpacing(out string expression, out string evaluatorId);
  12.     public double GetStartOffset(out string expression, out string evaluatorId);
  13.     public void SetEndOffset(double offset, string expression, string evaluatorId);
  14.     public void SetItemCount(int count, string expression, string evaluatorId);
  15.     public void SetItemSpacing(double spacing, string expression, string evaluatorId);
  16.     public void SetStartOffset(double offset, string expression, string evaluatorId);
  17.
  18.     // Properties
  19.     public bool AlignItems { [return: MarshalAs(UnmanagedType.U1)] get; [param: MarshalAs(UnmanagedType.U1)] set; }
  20.     public double EndOffset { get; set; }
  21.     public int ItemCount { get; set; }
  22.     public double ItemSpacing { get; set; }
  23.     public MethodType Method { get; set; }
  24.     public EdgeRef Path { get; set; }
  25.     public bool PathDirection { [param: MarshalAs(UnmanagedType.U1)] set; }
  26.     public double StartOffset { get; set; }
  27.
  28.     // Nested Types
  29.     public enum MethodType
  30.     {
  31.         Divide,
  32.         Measure
  33.     }
  34. }
  35.
Code - C#: [Select]
  1. [TypeDescriptionProvider("Autodesk.AutoCAD.ComponentModel.TypeDescriptionProvider`1[[Autodesk.AutoCAD.DatabaseServices.AssocArrayCommonParameters, acdbmgd]], acdbmgd"), Wrapper("AcDbAssocArrayCommonParameters")]
  2. public abstract class AssocArrayCommonParameters : AssocArrayParameters
  3. {
  4.     // Methods
  5.     protected internal AssocArrayCommonParameters(IntPtr unmanagedPointer, [MarshalAs(UnmanagedType.U1)] bool autoDelete);
  6.     internal unsafe AcDbAssocArrayCommonParameters* GetImpObj();
  7.     public int GetLevelCount(out string expression, out string evaluatorId);
  8.     public double GetLevelSpacing(out string expression, out string evaluatorId);
  9.     public int GetRowCount(out string expression, out string evaluatorId);
  10.     public double GetRowElevation(out string expression, out string evaluatorId);
  11.     public double GetRowSpacing(out string expression, out string evaluatorId);
  12.     public void SetLevelCount(int count, string expression, string evaluatorId);
  13.     public void SetLevelSpacing(double spacing, string expression, string evaluatorId);
  14.     public void SetRowCount(int count, string expression, string evaluatorId);
  15.     public void SetRowElevation(double value, string expression, string evaluatorId);
  16.     public void SetRowSpacing(double spacing, string expression, string evaluatorId);
  17.
  18.     // Properties
  19.     public Vector3d BaseNormal { get; set; }
  20.     public FaceRef BasePlane { get; set; }
  21.     public VertexRef BasePoint { get; set; }
  22.     public int LevelCount { get; set; }
  23.     public double LevelSpacing { get; set; }
  24.     public int RowCount { get; set; }
  25.     public double RowElevation { get; set; }
  26.     public double RowSpacing { get; set; }
  27. }
  28.
« Last Edit: December 09, 2011, 06:31:38 PM by Kerry »
Eycki
« Reply #5 on: December 10, 2011, 08:41:13 AM »
The sample code that is downloadable on this page helped me a lot: http://through-the-interface.typepad.com/through_the_interface/2011/03/new-apis-in-autocad-2012.html
Eycki
« Reply #6 on: December 13, 2011, 04:47:51 AM »
OK, I made it work to create an associative array from a dynamic block which I modify first before taking it in the array.
What I want to do now is make a command that modifies parameters which includes replacing the source item thru a new blockreference that I import.  Also the rowspacing, rowcount, columnspacing and columncount will get new values.
To do this I actually delete the array and creat a new one on the same basepoint?  Which is the best solution?
Thanks in advance!
Yes
Code - C#: [Select]
  3. {
  4.     // Methods
  17.
  18.     // Properties
  27.
  28.     // Nested Types
  30.     {
  31.         Divide,
  32.         Measure
  33.     }
  34. }
  35.
Code - C#: [Select]
  3. {
  4.     // Methods
  17.
  18.     // Properties
  27. }
  28.
kaefer
« Reply #7 on: December 13, 2011, 06:03:48 AM »
What happens if you
- select your AssocArray,
- use the GetParameters() method to obtain an AssocArrayParameters object,
- downcast that to AssocArrayPathParameters,
- try to modify it according to your wishes,
- and finally call the Commit() method on AssocArrayPathParameters?
Example in F#, I hope you'll get the gist:
let selectAnArray (ed : Editor) =
    let peo = new PromptEntityOptions("\nSelect an Associative Array: ")
    let per = ed.GetEntity peo
    if per.Status = PromptStatus.OK then
        if AssocArray.IsAssociativeArray per.ObjectId then
            Some per.ObjectId
        else
            ed.WriteMessage("\nNot an Associative Array, please try again...")
            None
    else None
[<CommandMethod "ChangeItemCount">]
let changeItemCount() =
    let db = acadApp.DocumentManager.MdiActiveDocument.Database
    let ed = acadApp.DocumentManager.MdiActiveDocument.Editor
    match selectAnArray ed with
    | None -> ()
    | Some oid ->
        let array = AssocArray.GetAssociativeArray oid
        match array.GetParameters() with
        | :? AssocArrayPathParameters as p ->
            let pir =
                new PromptIntegerOptions(
                    "New value for ItemCount",
                    AllowNegative = false,
                    AllowZero = false,
                    DefaultValue = p.ItemCount,
                    UseDefaultValue = true )
                |> ed.GetInteger
            if pir.Status = PromptStatus.OK then
                p.ItemSpacing <- p.ItemSpacing * float p.ItemCount / float pir.Value
                p.ItemCount <- pir.Value
                p.Commit()
                AssocManager.EvaluateTopLevelNetwork(db, null, 0)
                |> ignore
        | _ -> ()
Edit: Commit() and example added.
« Last Edit: December 13, 2011, 04:27:49 PM by kaefer »
