To edit text that contains enter data fields
From the Text tool box, select the Edit Text tool.
Identify the text.
To accept the text, enter another data point.
The Text Editor window opens.
Edit the text.
Text in an enter data field is surrounded by delimiters, such as <<example>>. If there are any enter data field characters in the text, the delimiters enclose the spaces representing the empty placeholders, such as <<123 abc 456 >>.
To remove an enter data field, you can delete either the left or right delimiter, and the matching delimiter is automatically deleted. Although the text between the delimiters remains in the text element, it is no longer part of an enter data field.
